Time scheme descriptor. More...
#include <cs_parameters.h>
Collaboration diagram for cs_time_scheme_t:Data Fields | |
| int | time_order |
| int | istmpf |
| int | isno2t |
| int | isto2t |
| double | thetsn |
| double | thetst |
| double | thetvi |
| double | thetcp |
| int | iccvfg |
Members of the time scheme structure are publicly accessible, to allow for concise syntax, as they are expected to be used in many places.
| iccvfg |
indicates whether the dynamic field should be frozen or not:
| isno2t |
Specifies the time scheme for the source terms of the momentum equation, apart from convection and diffusion (for instance: head loss, transposed gradient, ...).
| istmpf |
Time order of the mass flux scheme The chosen value for istmpf will automatically determine the value given to the variable thetfl.
| isto2t |
Specifies the time scheme for the source terms of the turbulence equations i.e. related to
), apart from convection and diffusion.
| thetcp |
-scheme for the extrapolation of the physical property
"specific heat" when the extrapolation has been activated (see time_extrapolated field key int), according to the formula
The value of
= thetcp is deduced from the value chosen for the specific heat. Generally, only the value 0.5 is used.
| thetsn |
-scheme for the source terms
in the Navier-Stokes equations when the source term extrapolation has been activated (see isno2t), following the formula
The value
= thetsn is deduced from the value chosen for isno2t. Generally only the value 0.5 is used.
| thetst |
-scheme for the extrapolation of the nonlinear explicit source terms $S_e$ of the turbulence equations when the source term extrapolation has been activated (see isto2t), following the formula
The value of
is deduced from the value chosen for isto2t. Generally, only the value 0.5 is used.
| thetvi |
"total viscosity" when the extrapolation has been activated (see time_extrapolated key word), according to the formula
The value of
= thetvi is deduced from the value chosen for time_extrapolated key word for the viscosity. Generally, only the value 0.5 is used.
| time_order |
Global time order of time stepping
