#include <cs_lagr.h>
Collaboration diagram for cs_lagr_source_terms_t:Data Fields | |
| int | ltsdyn |
| int | ltsmas |
| int | ltsthe |
| int | itsli |
| int | itske |
| int | itste |
| int | itsti |
| int | itsmas |
| int | nstits |
| int | npts |
| int | ntxerr |
| cs_real_t | vmax |
| cs_real_t | tmamax |
| cs_real_t * | st_val |
2-way coupling and source term information.
| int itske |
| int itsli |
implicit source term for the continuous phase velocity and for the turbulent energy if the
model is used
| int itsmas |
mass source term
| int itste |
explicit thermal source term for the thermal scalar of the continuous phase
| int itsti |
implicit thermal source term for the thermal scalar of the continuous phase
| int ltsdyn |
| int ltsmas |
activation (=1) or not (=0) of the two-way coupling on the mass. Useful if iilagr = CS_LAGR_TWOWAY_COUPLING, physical_model = 1 and impvar = 1
| int ltsthe |
| int npts |
number of time steps for source terms accumulations
| int nstits |
number of absolute time steps (including the restarts) after which a time-average of the two-way coupling source terms is calculated. Indeed, if the flow is steady (isttio=1), the average quantities that appear in the two-way coupling source terms can be calculated over different time steps, in order to get a better precision. if the number of absolute time steps is strictly inferior to nstits, the code considers that the flow has not yet reached its steady state (transition period) and the averages appearing in the source terms are reinitialized at each time step, as it is the case for unsteady flows (isttio=0). Useful if iilagr = CS_LAGR_TWOWAY_COUPLING and isttio=1
| int ntxerr |
number of cells, whose vulumetric rate DODO (concentration ?)is greather than 0.8
| cs_real_t* st_val |
source term values
| cs_real_t tmamax |
maximum massic concentration reached
| cs_real_t vmax |
maximum volumetric concentration reached
