The examples provided here are only concern inlet boundary conditions. Other boundary condition types are not specific to the pulverized coal model, so generic examples apply (and as usual, the GUI is recommended).
Note that turbulence variables BC's are usually computed automatically, based on definitions using cs_boundary_conditions_inlet_set_turbulence_hyd_diam or cs_boundary_conditions_inlet_set_turbulence_internsity.
Secondary or tertiary air inlet, for zone 'inlet', using either the base pulverized coal model or the pulverized coal with moisture model (with Lagrangian particle tracking).
const char *names[] = {"scalar1", "scalar2"};
for (int i = 0; i < 2; i++) {
if (eqp == NULL)
continue;
val);
void cs_boundary_conditions_open_set_mass_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant mass flow rate to an inlet or outlet.
Definition: cs_boundary_conditions.c:3275
void cs_boundary_conditions_inlet_set_turbulence_hyd_diam(const cs_zone_t *zone, cs_real_t hd)
Base the inlet turbulence values on a a circular duct with smooth wall (see ref cs_turbulence_bc_ke_h...
Definition: cs_boundary_conditions.c:3617
void cs_boundary_conditions_open_set_velocity_by_value(const cs_zone_t *z, const cs_real_t u[3])
Assign a constant velocity to an open (inlet/outlet) boundary.
Definition: cs_boundary_conditions.c:3088
cs_coal_bc_inlet_t * cs_coal_boundary_conditions_get_inlet(const cs_zone_t *zone)
Return pointer to coal boundary conditions inlet structure.
Definition: cs_coal_boundary_conditions.c:264
Definition: cs_defs.h:319
cs_equation_param_t * cs_equation_param_by_name(const char *eqname)
Return the cs_equation_param_t structure associated to a cs_equation_t structure based on the equatio...
Definition: cs_equation.c:614
cs_xdef_t * cs_equation_add_bc_by_value(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_real_t *values)
Define and initialize a new structure to set a boundary condition related to the given equation struc...
Definition: cs_equation_param.c:2590
@ CS_PARAM_BC_DIRICHLET
Definition: cs_param_types.h:479
const double cs_physical_constants_celsius_to_kelvin
Definition: cs_physical_constants.c:408
double precision, dimension(:,:,:), allocatable u
Definition: atimbr.f90:113
Inlet definition for pulverized coal combustion.
Definition: cs_coal_boundary_conditions.h:60
cs_real_t t_air
Definition: cs_coal_boundary_conditions.h:77
int ientat
Definition: cs_coal_boundary_conditions.h:64
int inmoxy
Definition: cs_coal_boundary_conditions.h:66
const char * name
Definition: cs_zone.h:57
Primary air and coal inlet, for zone 'primary_inlet'.
(z, 1.46e-03);
int icha = 0;
void cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant air mass flow rate to an inlet.
Definition: cs_coal_boundary_conditions.c:333
cs_combustion_model_t * cs_glob_combustion_model
Definition: cs_combustion_model.c:120
int ientcp
Definition: cs_coal_boundary_conditions.h:65
cs_real_t qimpcp[CS_COMBUSTION_MAX_COALS]
Definition: cs_coal_boundary_conditions.h:68
cs_real_t timpcp[CS_COMBUSTION_MAX_COALS]
Definition: cs_coal_boundary_conditions.h:69
cs_real_t distch[CS_COMBUSTION_MAX_COALS][CS_COMBUSTION_MAX_CLASSES_PER_COAL]
Definition: cs_coal_boundary_conditions.h:75
int n_classes_per_coal[CS_COMBUSTION_MAX_COALS]
Definition: cs_coal.h:82
Definition: cs_combustion_model.h:104
cs_coal_model_t * coal
Definition: cs_combustion_model.h:107
