Structure and functions handling the specific settings related to a cs_equation_t structure. More...
#include "cs_defs.h"#include <assert.h>#include <ctype.h>#include <stdlib.h>#include <string.h>#include <bft_error.h>#include <bft_mem.h>#include <bft_printf.h>#include "cs_boundary_zone.h"#include "cs_cdo_advection.h"#include "cs_cdo_bc.h"#include "cs_hodge.h"#include "cs_log.h"#include "cs_mesh_location.h"#include "cs_sles.h"#include "cs_source_term.h"#include "cs_volume_zone.h"#include "cs_equation_param.h"
Include dependency graph for cs_equation_param.c:Functions | |
| static cs_param_sles_class_t | _get_petsc_or_hypre (const cs_param_sles_t *slesp, const char *keyname) |
| Check if PETSc or HYPRE is available and return the possible solver class. More... | |
| static void | _set_key (cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval) |
| Set a parameter attached to a keyname in a cs_equation_param_t structure. More... | |
| cs_equation_param_t * | cs_equation_param_create (const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc) |
| Create a cs_equation_param_t structure with the given parameters. The remaining parameters are set with default values;. More... | |
| void | cs_equation_param_copy_from (const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fld_id) |
| Copy the settings from one cs_equation_param_t structure to another one. The name is not copied. More... | |
| void | cs_equation_param_copy_bc (const cs_equation_param_t *ref, cs_equation_param_t *dst) |
| Copy only the part dedicated to the boundary conditions and the DoF (degrees of freedom) enforcement from one cs_equation_param_t structure to another one. More... | |
| void | cs_equation_param_clear (cs_equation_param_t *eqp) |
| Free the contents of a cs_equation_param_t. More... | |
| cs_equation_param_t * | cs_equation_param_free (cs_equation_param_t *eqp) |
| Free a cs_equation_param_t. More... | |
| void | cs_equation_param_set (cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval) |
| cs_param_sles_t * | cs_equation_param_get_sles_param (cs_equation_param_t *eqp) |
| Get the pointer to the set of parameters to handle the SLES solver associated to this set of equation parameters. More... | |
| void | cs_equation_param_set_sles (cs_equation_param_t *eqp) |
| Set parameters for initializing SLES structures used for the resolution of the linear system. Settings are related to this equation. More... | |
| void | cs_equation_param_lock_settings (cs_equation_param_t *eqp) |
| Lock settings to prevent from unwanted modifications. More... | |
| void | cs_equation_param_unlock_settings (cs_equation_param_t *eqp) |
| Unlock settings. Be sure that is really wanted (inconsistency between the setup logging and what is used may appear) More... | |
| void | cs_equation_param_ensure_consistent_settings (cs_equation_param_t *eqp) |
| At this stage, the numerical settings should not be modified anymore by the user. One makes a last set of modifications if needed to ensure a consistent numerical settings. More... | |
| void | cs_equation_param_log (const cs_equation_param_t *eqp) |
| Print the detail of a cs_equation_param_t structure. More... | |
| bool | cs_equation_param_has_robin_bc (const cs_equation_param_t *eqp) |
| Ask if the parameter settings of the equation has requested the treatment of Robin boundary conditions. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_value (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val) |
| Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here a constant value is set to all the unknows belonging to the given zone with name z_name. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_qov (cs_equation_param_t *eqp, const char *z_name, double quantity) |
| Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here the value set to each unknown belonging to the given zone with name z_name is such that the integral over the cells of the zone returns the requested quantity. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here the initial value for each unknown associated to the zone with name z_name is set according to an analytical function. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Case of a definition by a DoF function. More... | |
| void | cs_equation_add_xdef_bc (cs_equation_param_t *eqp, cs_xdef_t *xdef) |
| Set a boundary condition from an existing cs_xdef_t structure The lifecycle of the cs_xdef_t structure is now managed by the current cs_equation_param_t structure. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_value (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_real_t *values) |
| Define and initialize a new structure to set a boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_array (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length) |
| cs_xdef_t * | cs_equation_add_bc_by_field (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_field_t *field) |
| cs_xdef_t * | cs_equation_add_bc_by_analytic (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define and initialize a new structure to set a boundary condition related to the given equation param structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_time_func (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_time_func_t *t_func, void *input) |
| Define and initialize a new structure to set a boundary condition related to the given equation param structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t Definition relying on a cs_time_func_t function pointer. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_dof_func (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Define and initialize a new structure to set a boundary condition related to the given cs_equation_param_t structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More... | |
| cs_xdef_t * | cs_equation_find_bc (cs_equation_param_t *eqp, const char *z_name) |
| Return pointer to existing boundary condition definition structure for the given equation param structure and zone. More... | |
| void | cs_equation_remove_bc (cs_equation_param_t *eqp, const char *z_name) |
| Remove boundary condition from the given equation param structure for a given zone. More... | |
| void | cs_equation_remove_ic (cs_equation_param_t *eqp, const char *z_name) |
| Remove initial condition from the given equation param structure for a given zone. More... | |
| void | cs_equation_add_sliding_condition (cs_equation_param_t *eqp, const char *z_name) |
| Define and initialize a new structure to set a sliding boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More... | |
| void | cs_equation_add_diffusion (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the Laplacian operator for the equation associated to the given cs_equation_param_t structure Laplacian means div-grad (either for vector-valued or scalar-valued equations) More... | |
| void | cs_equation_add_curlcurl (cs_equation_param_t *eqp, cs_property_t *property, int inversion) |
| Associate a new term related to the curl-curl operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_graddiv (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the grad-div operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_time (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the time derivative operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_advection (cs_equation_param_t *eqp, cs_adv_field_t *adv_field) |
| Associate a new term related to the advection operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_advection_scaling_property (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a scaling property to the advection. More... | |
| int | cs_equation_add_reaction (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the reaction operator for the equation associated to the given cs_equation_param_t structure. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_val (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a constant value. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an analytical function. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a DoF function. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_array (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an array. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_value (cs_equation_param_t *eqp, const char *z_name, double *val) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant value. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_qov (cs_equation_param_t *eqp, const char *z_name, double *quantity) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant quantity distributed over the associated zone's volume. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using an analytical function. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a DoF function. More... | |
| cs_enforcement_param_t * | cs_equation_add_vertex_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_vertices, const cs_lnum_t vertex_ids[], const cs_real_t ref_value[], const cs_real_t vtx_values[]) |
| Add an enforcement of the value of degrees of freedom located at the mesh vertices. The spatial discretization scheme for the given equation has to be CDO vertex-based or CDO vertex+cell-based schemes. More... | |
| cs_enforcement_param_t * | cs_equation_add_edge_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_edges, const cs_lnum_t edge_ids[], const cs_real_t ref_value[], const cs_real_t edge_values[]) |
| Add an enforcement of the value of degrees of freedom located at the mesh edges. The spatial discretization scheme for the given equation has to be CDO edge-based schemes. More... | |
| cs_enforcement_param_t * | cs_equation_add_face_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t ref_value[], const cs_real_t face_values[]) |
| Add an enforcement of the value of degrees of freedom located at the mesh faces. The spatial discretization scheme for the given equation has to be CDO face-based schemes. More... | |
| cs_enforcement_param_t * | cs_equation_add_cell_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[]) |
| Add an enforcement of the value related to the degrees of freedom associated to the list of selected cells. More... | |
| cs_enforcement_param_t * | cs_equation_add_or_replace_cell_enforcement (cs_equation_param_t *eqp, int enforcement_id, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[]) |
| Add a new enforcement if enforcement_id does not exist or replace it otherwise. Enforcement of the value related to the degrees of freedom associated to the list of selected cells. More... | |
| static const cs_real_t | _weak_pena_bc_coef_by_default = 100. |
| static const cs_real_t | _strong_pena_bc_coef_by_default = 1e12 |
| static const char | _err_empty_eqp [] |
static |
| [in] | slesp | pointer to a cs_param_sles_t structure |
| [in] | keyname | name of the key to handle |
static |
| [in,out] | eqp | pointer to a cs_equation_param_t structure |
| void cs_equation_add_advection | ( | cs_equation_param_t * | eqp, |
| cs_adv_field_t * | adv_field | ||
| [in] | adv_field | pointer to a cs_adv_field_t structure |
| void cs_equation_add_advection_scaling_property | ( | cs_equation_param_t * | eqp, |
| cs_property_t * | property | ||
| [in] | property | pointer to a cs_property_t structure |
| cs_xdef_t* cs_equation_add_bc_by_analytic | ( | cs_equation_param_t * | eqp, |
| const cs_param_bc_type_t | bc_type, | ||
| const char * | z_name, | ||
| cs_analytic_func_t * | analytic, | ||
| void * | input | ||
| [in] | bc_type | type of boundary condition to add |
| [in] | z_name | name of the associated zone (if NULL or "" if all cells are considered) |
| [in] | analytic | pointer to an analytic function defining the value |
| cs_xdef_t* cs_equation_add_bc_by_array | ( | cs_equation_param_t * | eqp, |
| cs_flag_t | loc, | ||
| cs_real_t * | array, | ||
| bool | is_owner, | ||
| bool | full_length | ||
| [in] | z_name | name of the related boundary zone |
| [in] | is_owner | transfer the lifecycle to the cs_xdef_t struct. (true or false) |
| [in] | full_length | if true, size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection. |
| cs_xdef_t* cs_equation_add_bc_by_dof_func | ( | cs_equation_param_t * | eqp, |
| cs_flag_t | loc_flag, | ||
| void * | input | ||
| [in] | loc_flag | location where values are computed |
| [in] | func | pointer to cs_dof_func_t function |
| cs_xdef_t* cs_equation_add_bc_by_field | ( | cs_equation_param_t * | eqp, |
| cs_field_t * | field | ||
| cs_xdef_t* cs_equation_add_bc_by_time_func | ( | cs_equation_param_t * | eqp, |
| cs_time_func_t * | t_func, | ||
| void * | input | ||
| [in] | t_func | pointer to an analytic function defining the value |
| cs_xdef_t* cs_equation_add_bc_by_value | ( | cs_equation_param_t * | eqp, |
| cs_real_t * | values | ||
| [in] | values | pointer to a array storing the values |
| cs_enforcement_param_t* cs_equation_add_cell_enforcement | ( | cs_equation_param_t * | eqp, |
| cs_lnum_t | n_cells, | ||
| const cs_real_t | ref_value[], | ||
| const cs_real_t | cell_values[] | ||
One assumes that values are interlaced if eqp->dim > 1 ref_value or elt_values has to be defined. If both parameters are defined, one keeps the definition in elt_values
| [in] | n_cells | number of selected cells |
| [in] | cell_ids | list of cell ids |
| [in] | ref_value | ignored if NULL |
| [in] | cell_values | list of associated values, ignored if NULL |
| void cs_equation_add_curlcurl | ( | cs_equation_param_t * | eqp, |
| cs_property_t * | property, | ||
| int | inversion | ||
| [in] | inversion | > 0: true, false otherwise |
| void cs_equation_add_diffusion | ( | cs_equation_param_t * | eqp, |
| cs_enforcement_param_t* cs_equation_add_edge_dof_enforcement | ( | cs_equation_param_t * | eqp, |
| cs_lnum_t | n_edges, | ||
| const cs_lnum_t | edge_ids[], | ||
| const cs_real_t | edge_values[] | ||
| [in] | n_edges | number of edges to enforce |
| [in] | edge_ids | list of edges |
| [in] | ref_value | default values or ignored (may be NULL) |
| [in] | edge_values | list of associated values, ignored if NULL |
| cs_enforcement_param_t* cs_equation_add_face_dof_enforcement | ( | cs_equation_param_t * | eqp, |
| cs_lnum_t | n_faces, | ||
| const cs_lnum_t | face_ids[], | ||
| const cs_real_t | face_values[] | ||
| [in] | n_faces | number of faces to enforce |
| [in] | face_ids | list of faces |
| [in] | face_values | list of associated values, ignored if NULL |
| void cs_equation_add_graddiv | ( | cs_equation_param_t * | eqp, |
| cs_xdef_t* cs_equation_add_ic_by_analytic | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | analytic | pointer to an analytic function |
| cs_xdef_t* cs_equation_add_ic_by_dof_func | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | loc_flag | where information is computed |
| [in] | func | pointer to a DoF function |
| cs_xdef_t* cs_equation_add_ic_by_qov | ( | cs_equation_param_t * | eqp, |
| double | quantity | ||
| [in] | z_name | name of the associated zone (if NULL or "" all cells are considered) |
| [in] | quantity | quantity to distribute over the mesh location |
| cs_xdef_t* cs_equation_add_ic_by_value | ( | cs_equation_param_t * | eqp, |
| cs_real_t * | val | ||
| [in] | val | pointer to the value |
| cs_enforcement_param_t* cs_equation_add_or_replace_cell_enforcement | ( | cs_equation_param_t * | eqp, |
| int | enforcement_id, | ||
| [in] | enforcement_id | id of the enforcement to handle |
| int cs_equation_add_reaction | ( | cs_equation_param_t * | eqp, |
| void cs_equation_add_sliding_condition | ( | cs_equation_param_t * | eqp, |
| const char * | z_name | ||
| cs_xdef_t* cs_equation_add_source_term_by_analytic | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | func | pointer to an analytical function |
| cs_xdef_t* cs_equation_add_source_term_by_array | ( | cs_equation_param_t * | eqp, |
| [in] | full_length | if true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection. |
| cs_xdef_t* cs_equation_add_source_term_by_dof_func | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | loc_flag | location of element ids given as parameter |
| cs_xdef_t* cs_equation_add_source_term_by_val | ( | cs_equation_param_t * | eqp, |
| void cs_equation_add_time | ( | cs_equation_param_t * | eqp, |
| cs_enforcement_param_t* cs_equation_add_vertex_dof_enforcement | ( | cs_equation_param_t * | eqp, |
| cs_lnum_t | n_vertices, | ||
| const cs_lnum_t | vertex_ids[], | ||
| const cs_real_t | vtx_values[] | ||
| [in] | n_vertices | number of vertices to enforce |
| [in] | vertex_ids | list of vertices |
| [in] | vtx_values | list of associated values, ignored if NULL |
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_analytic | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_dof_func | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_qov | ( | cs_equation_param_t * | eqp, |
| double * | quantity | ||
| [in] | quantity | pointer to quantity to distribute over the zone |
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_value | ( | cs_equation_param_t * | eqp, |
| double * | val | ||
| void cs_equation_add_xdef_bc | ( | cs_equation_param_t * | eqp, |
| cs_xdef_t * | xdef | ||
| [in] | xdef | pointer to the cs_xdef_t structure to transfer |
| cs_xdef_t* cs_equation_find_bc | ( | cs_equation_param_t * | eqp, |
| void cs_equation_param_clear | ( | cs_equation_param_t * | eqp | ) |
The cs_equation_param_t structure itself is not freed, but all its sub-structures are freed.
This is useful for equation parameters which are accessed through field keywords.
| [in,out] | eqp | pointer to a cs_equation_param_t |
| void cs_equation_param_copy_bc | ( | const cs_equation_param_t * | ref, |
| cs_equation_param_t * | dst | ||
| [in] | ref | pointer to the reference cs_equation_param_t |
| [in,out] | dst | pointer to the cs_equation_param_t to update |
| void cs_equation_param_copy_from | ( | const cs_equation_param_t * | ref, |
| cs_equation_param_t * | dst, | ||
| bool | copy_fld_id | ||
| [in] | copy_fld_id | copy also the field id or not |
| cs_equation_param_t* cs_equation_param_create | ( | const char * | name, |
| cs_equation_type_t | type, | ||
| int | dim, | ||
| cs_param_bc_type_t | default_bc | ||
Create a cs_equation_param_t structure.
| [in] | name | name of the equation |
| [in] | type | type of equation |
| [in] | dim | dim of the variable associated to this equation |
| [in] | default_bc | type of boundary condition set by default |
| void cs_equation_param_ensure_consistent_settings | ( | cs_equation_param_t * | eqp | ) |
| cs_equation_param_t* cs_equation_param_free | ( | cs_equation_param_t * | eqp | ) |
| cs_param_sles_t* cs_equation_param_get_sles_param | ( | cs_equation_param_t * | eqp | ) |
| bool cs_equation_param_has_robin_bc | ( | const cs_equation_param_t * | eqp | ) |
| [in] | eqp | pointer to a cs_equation_param_t |
| void cs_equation_param_lock_settings | ( | cs_equation_param_t * | eqp | ) |
| void cs_equation_param_log | ( | const cs_equation_param_t * | eqp | ) |
| void cs_equation_param_set | ( | cs_equation_param_t * | eqp, |
| cs_equation_key_t | key, | ||
| const char * | keyval | ||
| void cs_equation_param_set_sles | ( | cs_equation_param_t * | eqp | ) |
| void cs_equation_param_unlock_settings | ( | cs_equation_param_t * | eqp | ) |
| void cs_equation_remove_bc | ( | cs_equation_param_t * | eqp, |
If no matching boundary condition is found, the function returns silently.
| void cs_equation_remove_ic | ( | cs_equation_param_t * | eqp, |
static |
static |
static |
