| integer, dimension(1), target | ivoid1 |
| integer, dimension(1, 1), target | ivoid2 |
| double precision, dimension(1), target | rvoid1 |
| double precision, dimension(1, 1), target | rvoid2 |
| integer, dimension(:), pointer, save | itypfb |
| | boundary condition type at the boundary face ifac (see cs_user_boundary_conditions) More...
| integer, dimension(:), pointer, save | itrifb |
| | indirection array allowing to sort the boundary faces according to their boundary condition type itypfb More...
| integer, dimension(:), pointer | izfppp |
| | to identify boundary zones associated with boundary faces (specific physics models) More...
| integer(c_int), pointer, save | nfpt1d |
| | number of boundary faces which are coupled with a wall 1D thermal module. See the user subroutine cs_user_1d_wall_thermal More...
| integer(c_int), pointer, save | nfpt1t |
| | global number of boundary faces which are coupled with a wall 1D thermal module. (ie sum over all ranks of nfpt1d) More...
| integer(c_int), pointer, save | ibm_porosity_mode |
| | Activate the computation. More...
| logical(c_bool), pointer, save | compute_porosity_from_scan |
| integer, save | ncepdc |
| | number of cells in which a pressure drop is imposed. More...
| integer, dimension(:), allocatable | icepdc |
| | number of the ncepdc cells in which a pressure drop is imposed. See {iicepd} More...
| real(c_double), dimension(:,:), allocatable, target | ckupdc |
| | value of the coefficients of the pressure drop tensor of the ncepdc cells in which a pressure drop is imposed. Note the 6 values are interleaved as follows: (k11, k22, k33, k12, k23, k13). See ickpdc More...
| type(c_ptr) | p_ckupdc = c_null_ptr |
| integer, save | ncetsm |
| | number of the ncetsm cells in which a mass source term is imposed. See iicesm also More...
| integer, dimension(:), allocatable, target | icetsm |
| | number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_volume_mass_injection_* functions More...
| integer, dimension(:), allocatable | izctsm |
| | zone where a mass source term is imposed. More...
| integer, dimension(:,:), allocatable, target | itypsm |
| | type of mass source term for each variable More...
| double precision, dimension(:,:), allocatable, target | smacel |
| | value of the mass source term for pressure. For the other variables, eventual imposed injection value. See the user subroutine cs_user_mass_source_terms More...
| double precision, dimension(:), allocatable, target | gamcav |
| | liquid-vapor mass transfer term for cavitating flows and its derivative with respect to pressure More...
| double precision, dimension(:), allocatable, target | dgdpca |
| double precision, dimension(:,:), allocatable | xref_cond |
| | reference point for wall condensation, used in forced and mixed convection regimes More...
Module for pointer variables.
