Module for definition of general parameters. More...
Modules | |
| module | paramx |
| integer | nscamx |
| maximum number of scalars solutions of an advection equation, apart from the variables of the turbulence model | |
| integer | nvarmx |
| maximal number of variables = nscamx + 12 (u,v,w,P,Rij,e,alp) More... | |
| integer | iindef |
| pointer for undefined type face (non-standard case) More... | |
| integer | ientre |
| if itypfb=ientre: inlet face. More... | |
| integer | isolib |
| if itypfb=isolib: free outlet face (or more precisely free inlet/outlet with forced pressure) More... | |
| integer | isymet |
| if itypfb=isymet: symmetry face (or wall without friction). More... | |
| integer | iparoi |
| if itypfb=iparoi: smooth solid wall face, impermeable and with friction. More... | |
| integer | iparug |
| if itypfb=iparug: rough solid wall face, impermeable and with friction. More... | |
| integer | iesicf |
| if itypfb=iesicf: imposed inlet/outlet for compressible flow (for example, supersonic inlet). More... | |
| integer | isspcf |
| if itypfb=isspcf: supersonic outlet for compressible flow. More... | |
| integer | isopcf |
| if itypfb=isopcf: mixed outlet for compressible flow with a given pressure. More... | |
| integer | iephcf |
| if itypfb=iephcf: mixed inlet for compressible flow with given total pressure and total enthalpy (reservoir boundary conditions). More... | |
| integer | ieqhcf |
| integer | icscpl |
| code/code coupling condition More... | |
| integer | icscpd |
| code/code coupling condition with decentered flux More... | |
| integer | ifrent |
| if itypfb=ifrent: free entrance based on Bernoulli equation when the flow is incoming, standard outlet when outgoing More... | |
| integer | ifresf |
| if itypfb=ifresf: free surface for mobile mesh boundary condition More... | |
| integer | i_convective_inlet |
| if itypfb=i_convective_inlet: inlet face where the total mass flux is prescribed. More... | |
| integer | ibfixe |
| boundary condition type for mesh velocity in ALE: fixed wall More... | |
| integer | igliss |
| boundary condition type for mesh velocity in ALE: sliding wall More... | |
| integer | ivimpo |
| boundary condition type for mesh velocity in ALE: imposed velocity. More... | |
| integer | ibalfs |
| Boundary condition type for mesh velocity in ALE for modelling free surface ( | |
| integer | nstrmx |
| maximum number of structures in ALE More... | |
| integer | cs_f_user_head_losses |
| integer | cs_user_boundary_conditions |
| integer | cs_user_cooling_towers |
| integer | cs_user_extra_operations |
| integer | cs_user_initialization |
| integer | cs_user_mass_source_terms |
| integer | cs_user_metal_structures_source_terms |
| integer | cs_user_parameters |
| integer | cs_user_physical_properties |
| integer | cs_user_turbulence_source_terms |
| integer | cs_user_turbulence_source_terms2 |
| integer | cs_user_atmo_soil |
| integer | cs_user_physical_properties_smagorinsky_c |
| integer | usalcl |
| integer | usatdv |
| integer | usati1 |
| integer | usatph |
| integer | usatsoil |
| integer | ushist |
| integer | usporo |
| integer | ussmag |
| integer | usstr1 |
| integer | usstr2 |
| integer | ustsnv |
| integer | ustsvv |
| integer | usthht |
| integer | usvosy |
| integer | usvpst |
| integer | usvist |
