Preparation of sending velocity variables for coupling between two instances of code_saturne via boundary faces. Received indformation will be transformed into boundary condition in subroutine csc2cl.
More...
| subroutine | cscpce (n_elts, f_id, f_dim, reverse, elt_ids, coopts, cw1_to_send, cw2_to_send) |
◆ cscpce()
| subroutine cscpce |
integer |
n_elts, |
integer |
f_id, |
integer |
f_dim, |
integer |
reverse, |
integer, dimension(n_elts) |
elt_ids, |
double precision, dimension(3,n_elts) |
coopts, |
double precision, dimension(f_dim,n_elts) |
cw1_to_send, |
double precision, dimension(f_dim,f_dim,n_elts) |
cw2_to_send |
- Parameters
| [in] | n_elts | number of distant points |
| [in] | f_id | field index |
| [in] | f_dim | field dimension |
| [in] | reverse | reverse mode |
| [in] | elt_ids | connectivity |
| [in] | coopts | coordinates of the distants points |
| [out] | cw1_to_send | work array for the variable to be exchanged |
| [out] | cw2_to_send | work array for the variable to be exchanged |
