Code-code coupling with source terms.
More...
| subroutine | csc2ts (n_elts, elt_ids, f_id, f_dim, reverse, cw1_received, cw2_received, crvexp, crvimp) |
◆ csc2ts()
| subroutine csc2ts |
integer |
n_elts, |
integer, dimension(n_elts) |
elt_ids, |
integer |
f_id, |
integer |
f_dim, |
integer |
reverse, |
double precision, dimension(f_dim,n_elts) |
cw1_received, |
double precision, dimension(f_dim,f_dim,n_elts) |
cw2_received, |
double precision, dimension(f_dim, ncelet) |
crvexp, |
double precision, dimension(f_dim, f_dim, ncelet) |
crvimp |
- Parameters
| [in] | n_elts | number of local (distant in reverse mode) overlapped cells |
| [in] | elt_ids | localisation of coupling cells |
| [in] | f_id | field index |
| [in] | f_dim | field dimension |
| [in] | reverse | reverse mode if 1 |
| [in] | cw1_received | distant variable array or explicit part for reverse mode |
| [in] | cw2_received | implicit part for reverse mode |
| [in,out] | crvexp | explicit source term |
| [in,out] | crvimp | working table for implicit part |
