| void | cs_volume_mass_injection_flag_zones (void) |
| | Flag volume zones with the appropriate CS_VOLUME_ZONE_MASS_SOURCE_TERM flag when at least one volume mass injection on that zone is present. More...
| void | cs_volume_mass_injection_build_lists (cs_lnum_t n_cells, cs_lnum_t cell_num[], int cell_zone_id[]) |
| | Build the list and zone ids of cells with volume mass injection. More...
| void | cs_volume_mass_injection_eval (int nvar, cs_lnum_t ncesmp, int itypsm[], cs_real_t smacel[]) |
| | Evaluate contributions to volume mass injection. More...
| void | cs_volume_mass_injection_get_arrays (const cs_field_t *f, cs_lnum_t *ncesmp, cs_lnum_t **icetsm, int **itpsmp, cs_real_t **smcelp, cs_real_t **gamma) |
| | Return pointers to the mass source term arrays. More...
◆ cs_volume_mass_injection_build_lists()
| void cs_volume_mass_injection_build_lists |
cs_lnum_t |
n_cells, |
cs_lnum_t |
cell_num[], |
int |
cell_zone_id[] |
- Parameters
| [in] | n_cells | number of cells in mass source term zones |
| [out] | cell_num | numbers (1-based) cells in mass source term zones |
| [out] | cell_zone_id | associated zone ids |
◆ cs_volume_mass_injection_eval()
| void cs_volume_mass_injection_eval |
int |
nvar, |
cs_lnum_t |
ncesmp, |
int |
itypsm[], |
cs_real_t |
smacel[] |
- Parameters
| [in] | itypsm | mass source type for the working variable size: [nvar][ncesmp] |
| [in] | smacel | values of the variables associated to the mass source (for the pressure variable, smacel is the mass flux) size: [nvar][ncesmp] |
◆ cs_volume_mass_injection_flag_zones()
| void cs_volume_mass_injection_flag_zones |
void |
This is necessary for the reverse zone indexing required by the legacy code to function with defintions that are partially unrolled an not purely zone-based.
◆ cs_volume_mass_injection_get_arrays()
- Parameters
| [in] | f | pointer to associated field |
| [out] | ncesmp | number of cells with mass source terms |
| [out] | icetsm | pointet to source mass cells list (1-based numbering) |
| [out] | itpsmp | mass source type for the working variable |
| [out] | s_type | mass source types (0: ambient value, 1: s_val value) |
| [out] | smcelp | pointer to mass source values |
| [out] | gamma | pointer to flow mass value |
