8.1
cs_turbulence_model.h File Reference
+ Include dependency graph for cs_turbulence_model.h:
Data Structures
struct  cs_turb_model_t
 Turbulence model general options descriptor. More...
struct  cs_turb_ref_values_t
struct  cs_turb_rans_model_t
 RANS turbulence model descriptor. More...
struct  cs_turb_les_model_t
 LES turbulence model descriptor. More...
struct  cs_turb_hybrid_model_t
 Hybrid turbulence model descriptor. More...
Enumerations
enum  cs_turb_model_type_t {
  CS_TURB_NONE = 0 , CS_TURB_MIXING_LENGTH = 10 , CS_TURB_K_EPSILON = 20 , CS_TURB_K_EPSILON_LIN_PROD = 21 ,
  CS_TURB_K_EPSILON_LS = 22 , CS_TURB_K_EPSILON_QUAD = 23 , CS_TURB_RIJ_EPSILON_LRR = 30 , CS_TURB_RIJ_EPSILON_SSG = 31 ,
  CS_TURB_RIJ_EPSILON_EBRSM = 32 , CS_TURB_LES_SMAGO_CONST = 40 , CS_TURB_LES_SMAGO_DYN = 41 , CS_TURB_LES_WALE = 42 ,
  CS_TURB_V2F_PHI = 50 , CS_TURB_V2F_BL_V2K = 51 , CS_TURB_K_OMEGA = 60 , CS_TURB_SPALART_ALLMARAS = 70
enum  { CS_TURB_TYPE_NONE = 0 , CS_TURB_RANS = 1 , CS_TURB_LES = 2 , CS_TURB_HYBRID = 3 }
enum  { CS_TURB_ALGEBRAIC = 0 , CS_TURB_FIRST_ORDER = 1 , CS_TURB_SECOND_ORDER = 2 }
enum  {
  CS_HYBRID_NONE = 0 , CS_HYBRID_DES = 1 , CS_HYBRID_DDES = 2 , CS_HYBRID_SAS = 3 ,
  CS_HYBRID_HTLES = 4
void cs_turb_model_init (void)
 Initialize turbulence model structures. More...
void cs_set_type_order_turbulence_model (void)
 Initialize type and order members of turbulence model structure. More...
void cs_set_glob_turb_model (void)
 Set global pointer to turbulence model structure. More...
cs_turb_model_tcs_get_glob_turb_model (void)
 Provide write access to turbulence model structure. More...
void cs_turb_compute_constants (int phase_id)
 Compute turbulence model constants, some of which may depend on the model choice. More...
cs_turb_ref_values_tcs_get_glob_turb_ref_values (void)
 Provide access to cs_glob_turb_ref_values. More...
cs_turb_rans_model_tcs_get_glob_turb_rans_model (void)
 Provide access to cs_glob_turb_rans_model. More...
cs_turb_les_model_tcs_get_glob_turb_les_model (void)
 Provide access to cs_glob_turb_les_model. More...
cs_turb_hybrid_model_tcs_get_glob_turb_hybrid_model (void)
 Provide access to cs_glob_turb_hybrid_model. More...
void cs_turb_model_log_setup (void)
 Print the turbulence model parameters to setup.log. More...
void cs_turb_constants_log_setup (void)
 Print the turbulent constants to setup.log. More...
void cs_turb_init_ref_quantities (void)
 Compute characteristic length for turbulence if not already done. More...
void cs_clip_turbulent_fluxes (int flux_id, int ivartt)
 Clipping for the turbulence flux vector. More...
void cs_turbulence_function_k (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
 Return or estimate the value of the turbulent kinetic energy over specified elements. More...
void cs_turbulence_function_eps (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
 Return or estimate the value of the turbulent dissipation over specified elements. More...
void cs_turbulence_function_rij (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
 Return or estimate the value of the Reynolds stresses over specified elements. More...
const cs_turb_model_tcs_glob_turb_model
const cs_turb_ref_values_tcs_glob_turb_ref_values
const cs_turb_rans_model_tcs_glob_turb_rans_model
const cs_turb_les_model_tcs_glob_turb_les_model
const cs_turb_hybrid_model_tcs_glob_turb_hybrid_model
double cs_turb_xkappa
double cs_turb_vdriest
double cs_turb_cstlog
double cs_turb_cstlog_rough
double cs_turb_cstlog_alpha
double cs_turb_apow
double cs_turb_bpow
double cs_turb_dpow
double cs_turb_cmu
double cs_turb_cmu025
double cs_turb_ce1
double cs_turb_ce2
double cs_turb_ce4
double cs_turb_crij1
double cs_turb_crij2
double cs_turb_crij3
double cs_turb_crij_c0
double cs_turb_crijp1
double cs_turb_crijp2
double cs_turb_cssge2
double cs_turb_cssgs1
double cs_turb_cssgs2
double cs_turb_cssgr1
double cs_turb_cssgr2
double cs_turb_cssgr3
double cs_turb_cssgr4
double cs_turb_cssgr5
double cs_turb_cebms1
double cs_turb_cebms2
double cs_turb_cebmr1
double cs_turb_cebmr2
double cs_turb_cebmr3
double cs_turb_cebmr4
double cs_turb_cebmr5
double cs_turb_csrij
double cs_turb_cebme2
double cs_turb_cebmmu
double cs_turb_xcl
double cs_turb_xa1
double cs_turb_xct
double cs_turb_xclt
double cs_turb_xceta
double cs_turb_cpale1
double cs_turb_cpale2
double cs_turb_cpale3
double cs_turb_cpale4
double cs_turb_cpalc1
double cs_turb_cpalc2
double cs_turb_cpalct
double cs_turb_cpalcl
double cs_turb_cpalet
double cs_turb_ckwsk1
double cs_turb_ckwsk2
double cs_turb_ckwsw1
double cs_turb_ckwsw2
double cs_turb_ckwbt1
double cs_turb_ckwbt2
double cs_turb_ckwgm1
double cs_turb_ckwgm2
double cs_turb_ckwa1
double cs_turb_ckwc1
double cs_turb_cddes
double cs_turb_csas
double cs_turb_csas_eta2
double cs_turb_chtles_bt0
double cs_turb_cnl1
double cs_turb_cnl2
double cs_turb_cnl3
double cs_turb_cnl4
double cs_turb_cnl5
double cs_turb_csab1
double cs_turb_csab2
double cs_turb_csasig
double cs_turb_csav1
double cs_turb_csaw1
double cs_turb_csaw2
double cs_turb_csaw3
double cs_turb_cssr1
double cs_turb_cssr2
double cs_turb_cssr3
double cs_turb_ccaze2
double cs_turb_ccazsc
double cs_turb_ccaza
double cs_turb_ccazb
double cs_turb_ccazc
double cs_turb_ccazd
double cs_turb_xlesfl
double cs_turb_ales
double cs_turb_bles
double cs_turb_csmago
double cs_turb_xlesfd
double cs_turb_csmago_max
double cs_turb_csmago_min
double cs_turb_cdries
double cs_turb_cv2fa1
double cs_turb_cv2fe2
double cs_turb_cv2fc1
double cs_turb_cv2fc2
double cs_turb_cv2fct
double cs_turb_cv2fcl
double cs_turb_cv2fet
double cs_turb_cwale
double cs_turb_xiafm
double cs_turb_etaafm
double cs_turb_c1trit
double cs_turb_c2trit
double cs_turb_c3trit
double cs_turb_c4trit
double cs_turb_cthafm
double cs_turb_cthdfm
double cs_turb_cthebdfm
◆ anonymous enum
anonymous enum
Enumerator
CS_TURB_TYPE_NONE
CS_TURB_RANS
CS_TURB_LES
CS_TURB_HYBRID
◆ anonymous enum
anonymous enum
Enumerator
CS_TURB_ALGEBRAIC
CS_TURB_FIRST_ORDER
◆ anonymous enum
anonymous enum
Enumerator
CS_HYBRID_NONE
CS_HYBRID_DES
CS_HYBRID_DDES
CS_HYBRID_SAS
CS_HYBRID_HTLES
◆ cs_turb_model_type_t
Enumerator
CS_TURB_NONE
CS_TURB_K_EPSILON
CS_TURB_LES_WALE
CS_TURB_V2F_PHI
CS_TURB_V2F_BL_V2K
CS_TURB_K_OMEGA
◆ cs_clip_turbulent_fluxes()
void cs_clip_turbulent_fluxes ( int  flux_id,
int  variance_id
[in]flux_idturbulent flux index
[in]variance_idscalar variance index
◆ cs_get_glob_turb_hybrid_model()
cs_turb_hybrid_model_t* cs_get_glob_turb_hybrid_model ( void  )
needed to initialize structure with GUI
◆ cs_get_glob_turb_les_model()
cs_turb_les_model_t* cs_get_glob_turb_les_model ( void  )
◆ cs_get_glob_turb_model()
cs_turb_model_t* cs_get_glob_turb_model ( void  )
◆ cs_get_glob_turb_rans_model()
cs_turb_rans_model_t* cs_get_glob_turb_rans_model ( void  )
◆ cs_get_glob_turb_ref_values()
cs_turb_ref_values_t* cs_get_glob_turb_ref_values ( void  )
◆ cs_set_glob_turb_model()
void cs_set_glob_turb_model ( void  )
This global pointer provides a read-only access to the structure.
◆ cs_set_type_order_turbulence_model()
void cs_set_type_order_turbulence_model ( void  )
◆ cs_turb_compute_constants()
void cs_turb_compute_constants ( int  phase_id)
[in]phase_idturbulent phase id (-1 for single phase flow)
◆ cs_turb_constants_log_setup()
void cs_turb_constants_log_setup ( void  )
◆ cs_turb_init_ref_quantities()
void cs_turb_init_ref_quantities ( void  )
◆ cs_turb_model_init()
void cs_turb_model_init ( void  )
◆ cs_turb_model_log_setup()
void cs_turb_model_log_setup ( void  )
◆ cs_turbulence_function_eps()
void cs_turbulence_function_eps ( int  location_id,
cs_lnum_t  n_elts,
const cs_lnum_t elt_ids,
void *  input,
void *  vals
Returned values are zero for turbulence models other than RANS.
This function matches the cs_eval_at_location_t function profile.
[in]location_idbase associated mesh location id
[in]n_eltsnumber of associated elements
[in]elt_idsids of associated elements, or NULL if no filtering is required
[in,out]inputignored
[in,out]valspointer to output values (size: n_elts*dimension)
◆ cs_turbulence_function_k()
void cs_turbulence_function_k ( int  location_id,
cs_lnum_t  n_elts,
void *  input,
void *  vals
◆ cs_turbulence_function_rij()
void cs_turbulence_function_rij ( int  location_id,
cs_lnum_t  n_elts,
void *  input,
void *  vals
◆ cs_glob_turb_hybrid_model
const cs_turb_hybrid_model_t* cs_glob_turb_hybrid_model
extern
◆ cs_glob_turb_les_model
const cs_turb_les_model_t* cs_glob_turb_les_model
extern
◆ cs_glob_turb_model
const cs_turb_model_t* cs_glob_turb_model
extern
◆ cs_glob_turb_rans_model
const cs_turb_rans_model_t* cs_glob_turb_rans_model
extern
◆ cs_glob_turb_ref_values
const cs_turb_ref_values_t* cs_glob_turb_ref_values
extern
◆ cs_turb_ales
double cs_turb_ales
extern
Constant used to define, for each cell $\Omega_i$, the width of the (implicit) filter:
  • $\overline{\Delta}=xlesfl(ales*|\Omega_i|)^{bles}$
Useful if and only if iturb = 40 or 41.
◆ cs_turb_apow
double cs_turb_apow
extern
Werner and Wengle coefficient
◆ cs_turb_bles
double cs_turb_bles
extern
Constant used to define, for each cell $Omega_i$, the width of the (implicit) filter:
◆ cs_turb_bpow
double cs_turb_bpow
extern
◆ cs_turb_c1trit
extern
Coefficient of turbulent DFM flow model.
◆ cs_turb_c2trit
extern
◆ cs_turb_c3trit
extern
◆ cs_turb_c4trit
extern
◆ cs_turb_ccaza
extern
Constants of the Cazalbou rotation/curvature correction.
◆ cs_turb_ccazb
extern
◆ cs_turb_ccazc
extern
◆ cs_turb_ccazd
extern
◆ cs_turb_ccaze2
extern
◆ cs_turb_ccazsc
extern
◆ cs_turb_cddes
extern
Constant $ C_{DDES} $ for the $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST) and hybrid_turb=1.
◆ cs_turb_cdries
extern
Van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant:
  • $ (1-\exp^{(-y^+/cdries}) $.
◆ cs_turb_ce1
double cs_turb_ce1
extern
Constant $C_{\varepsilon 1}$ for all the RANS turbulence models except for the v2f and the $k-\omega$ models. Useful if and only if iturb= 20, 21, 30 or 31 ( $k-\varepsilon$ or $R_{ij}-\varepsilon$).
◆ cs_turb_ce2
double cs_turb_ce2
extern
Constant $C_{\varepsilon 2}$ for the $k-\varepsilon$ and $R_{ij}-\varepsilon$ LRR models. Useful if and only if iturb = 20, 21 or 30 ( $k-\varepsilon$ or $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_ce4
double cs_turb_ce4
extern
Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment.
Constant $C_{\varepsilon 4}$ for the interfacial term (Lagrangian module) in case of two-way coupling. Useful in case of Lagrangian modelling, in $k-\varepsilon$ and $R_{ij}-\varepsilon$ with two-way coupling.
◆ cs_turb_cebme2
extern
Constant of the Rij-epsilon EBRSM.
◆ cs_turb_cebmmu
extern
◆ cs_turb_cebmr1
extern
◆ cs_turb_cebmr2
extern
◆ cs_turb_cebmr3
extern
◆ cs_turb_cebmr4
extern
◆ cs_turb_cebmr5
extern
◆ cs_turb_cebms1
extern
◆ cs_turb_cebms2
extern
◆ cs_turb_chtles_bt0
extern
Constant $ \beta_0 $ for the HTLES model. Useful if and only if iturb=60 ( $k-\omega$ SST) or if iturb=51 ( $BL-v^2-k$) and hybrid_turb=4.
◆ cs_turb_ckwa1
extern
Specific constant of k-omega SST. Constant $a_1$ for the $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST).
◆ cs_turb_ckwbt1
extern
Constant $\beta_1$ for the $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST).
◆ cs_turb_ckwbt2
extern
Constant $\beta_2$ for the $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST).
◆ cs_turb_ckwc1
extern
Constant $ c_1 $ for the $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST). Specific constant of k-omega SST.
◆ cs_turb_ckwgm1
extern
$\frac{\beta_1}{C_\mu}-\frac{\kappa^2}{\sqrt{C_\mu}\sigma_{\omega 1}}$. Constant $\gamma_1$ for the $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST).
Warning
: $\gamma_1$ is calculated before the call to usipsu. Hence, if $\beta_1$, $C_\mu$, $\kappa$ or $\sigma_{\omega 1}$ is modified in usipsu, cs_turb_ckwgm1 must also be modified in accordance.
◆ cs_turb_ckwgm2
extern
$\frac{\beta_2}{C_\mu}-\frac{\kappa^2}{\sqrt{C_\mu}\sigma_{\omega 2}}$. Constant $\gamma_2$ for the $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST).
Warning
: $\gamma_2$ is calculated before the call to usipsu. Hence, if $\beta_2$, $C_\mu$, $\kappa$ or $\sigma_{\omega 2}$ is modified in usipsu, cs_turb_ckwgm2 must also be modified in accordance.
◆ cs_turb_ckwsk1
extern
Constant $\sigma_{k1}$ for the $k-\omega$ SST model. Useful if and only if iturb=60.
◆ cs_turb_ckwsk2
extern
Constant $\sigma_{k2}$ for the $k-\omega$ SST model. Useful if and only if iturb=60.
◆ cs_turb_ckwsw1
extern
Constant $\sigma_{\omega 1}$ for the $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST).
◆ cs_turb_ckwsw2
extern
Constant $\sigma_{\omega 2}$ for the $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST).
◆ cs_turb_cmu
double cs_turb_cmu
extern
Constant $C_\mu$ for all the RANS turbulence models. Warning: different value for v2f models. Useful only for RANS models ( $k-\varepsilon$, $R_{ij}-\varepsilon$ or $k-\omega$).
◆ cs_turb_cmu025
extern
$ C_\mu^\frac{1}{4} $
◆ cs_turb_cnl1
double cs_turb_cnl1
extern
Constants for the Baglietto et al. quadratic k-epsilon model. Useful if and only if iturb = CS_TURB_K_EPSILON_QUAD
◆ cs_turb_cnl2
double cs_turb_cnl2
extern
◆ cs_turb_cnl3
double cs_turb_cnl3
extern
◆ cs_turb_cnl4
double cs_turb_cnl4
extern
◆ cs_turb_cnl5
double cs_turb_cnl5
extern
◆ cs_turb_cpalc1
extern
Specific constant of v2f "BL-v2k" (or phi-alpha).
◆ cs_turb_cpalc2
extern
◆ cs_turb_cpalcl
extern
◆ cs_turb_cpalct
extern
◆ cs_turb_cpale1
extern
◆ cs_turb_cpale2
extern
◆ cs_turb_cpale3
extern
◆ cs_turb_cpale4
extern
◆ cs_turb_cpalet
extern
◆ cs_turb_crij1
extern
Constant $C_1$ for the $R_{ij}-\varepsilon$ LRR model. Useful if and only if iturb=30 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_crij2
extern
Constant $C_2$ for the $R_{ij}-\varepsilon$ LRR model. Useful if and only if iturb=30 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_crij3
extern
Constant $C_3$ for the $R_{ij}-\varepsilon$ models. Value is 0.55 for SSG and LRR, 0.6 for EBRSM.
◆ cs_turb_crij_c0
extern
Rotta constant $C_0$ for the $R_{ij}-\varepsilon$ model. Useful for the Lagrangian model. The value is set from $C_1$ if and only if iturb=CS_TURB_RIJ_EPSILON_LRR ( $R_{ij}-\varepsilon$ LRR) and $C_2=0$.
◆ cs_turb_crijp1
extern
Constant $C_1^\prime$ for the $R_{ij}-\varepsilon$ LRR model, corresponding to the wall echo terms. Useful if and only if iturb=30 and cs_turb_rans_model_t::irijec=1 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_crijp2
extern
Constant $C_2^\prime$ for the $R_{ij}-\varepsilon$ LRR model, corresponding to the wall echo terms. Useful if and only if iturb=30 and cs_turb_rans_model_t::irijec=1 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_csab1
extern
Specific constant of Spalart-Allmaras.
◆ cs_turb_csab2
extern
◆ cs_turb_csas
double cs_turb_csas
extern
Constant $ C_{SAS}$ for the hybrid $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST) and hybrid_turb=3.
◆ cs_turb_csas_eta2
extern
constant $ C_{DDES}$ for the hybrid $k-\omega$ SST model. Useful if and only if iturb=60 ( $k-\omega$ SST) and hybrid_turb=3.
◆ cs_turb_csasig
extern
◆ cs_turb_csav1
extern
◆ cs_turb_csaw1
extern
◆ cs_turb_csaw2
extern
◆ cs_turb_csaw3
extern
◆ cs_turb_csmago
extern
Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by $\displaystyle\mu_{sg}= \rho C_{smago}^2\bar{\Delta}^2\sqrt{2\bar{S}_{ij}\bar{S}_{ij}}$ where $\bar{\Delta}$ is the width of the filter and $\bar{S}_{ij}$ the filtered strain rate.
Useful if and only if iturb = 40.
Note
In theory Smagorinsky constant is 0.18. For a channel, 0.065 value is rather taken.
◆ cs_turb_csmago_max
extern
Maximum allowed value for the variable $C$ appearing in the LES dynamic model. Any larger value yielded by the calculation procedure of the dynamic model will be clipped to $ smagmx$.
Useful if and only if iturb = 41.
◆ cs_turb_csmago_min
extern
Minimum allowed value for the variable $C$ appearing in the LES dynamic model. Any smaller value yielded by the calculation procedure of the dynamic model will be clipped to $ smagmn$.
◆ cs_turb_csrij
extern
Constant $C_s$ for the $R_{ij}-\varepsilon$ LRR model. Useful if and only if iturb=30 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_cssge2
extern
Constant $C_{\varepsilon 2}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if iturb=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgr1
extern
Constant $C_{r1}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if iturb=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgr2
extern
Constant $C_{r2}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if iturb=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgr3
extern
Constant $C_{r3}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if iturb=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgr4
extern
constant $C_{r4}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if iturb=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgr5
extern
◆ cs_turb_cssgs1
extern
Constant $C_{s1}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if iturb=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgs2
extern
Constant $C_{s2}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if iturb=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssr1
extern
Constant of the Spalart-Shur rotation/curvature correction.
◆ cs_turb_cssr2
extern
◆ cs_turb_cssr3
extern
◆ cs_turb_cstlog
extern
Constant of logarithmic smooth law function: $ \dfrac{1}{\kappa} \ln(y^+) + cstlog $ ( $ cstlog = 5.2 $).
Constant of the logarithmic wall function. Useful if and only if iturb >= 10 (mixing length, $k-\varepsilon$, $R_{ij}-\varepsilon$, LES, v2f or $k-\omega$).
◆ cs_turb_cstlog_alpha
extern
Constant $ \alpha $ for logarithmic law function switching from rough to smooth: $ \dfrac{1}{\kappa} \ln(y u_k/(\nu + \alpha \xi u_k)) + cstlog $ ( $ \alpha = \exp \left( -\kappa (8.5 - 5.2) \right) $).
◆ cs_turb_cstlog_rough
extern
Constant of logarithmic rough law function: $ \dfrac{1}{\kappa} \ln(y/\xi) + cstlog_{rough} $ ( $ cstlog_{rough} = 8.5 $).
◆ cs_turb_cthafm
extern
Constant of GGDH and AFM on the thermal scalar.
◆ cs_turb_cthdfm
extern
◆ cs_turb_cthebdfm
extern
◆ cs_turb_cv2fa1
extern
Constant $a_1$ for the v2f $\varphi$-model. Useful if and only if iturb=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fc1
extern
Constant $C_1$ for the v2f $\varphi$-model. Useful if and only if iturb=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fc2
extern
Constant $C_2$ for the v2f $\varphi$-model. Useful if and only if iturb=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fcl
extern
Constant $C_L$ for the v2f $\varphi$-model. Useful if and only if iturb=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fct
extern
Constant $C_T$ for the v2f $\varphi$-model. Useful if and only if iturb=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fe2
extern
Constant $C_{\varepsilon 2}$ for the v2f $\varphi$-model. Useful if and only if iturb=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fet
extern
Constant $C_\eta$ for the v2f $\varphi$-model. Useful if and only if iturb=50 (v2f $\varphi$-model).
◆ cs_turb_cwale
extern
Constant of the WALE LES method.
◆ cs_turb_dpow
double cs_turb_dpow
extern
◆ cs_turb_etaafm
extern
Coefficient of turbulent AFM flow model.
◆ cs_turb_vdriest
extern
Van Driest constant. (= 25.6)
Useful if and only if cs_glob_wall_functions::iwallf = CS_WALL_F_2SCALES_VDRIEST. (Two scales log law at the wall using Van Driest mixing length expression).
◆ cs_turb_xa1
double cs_turb_xa1
extern
Constant in the expression of Ce1' for the Rij-epsilon EBRSM.
◆ cs_turb_xceta
extern
◆ cs_turb_xcl
double cs_turb_xcl
extern
◆ cs_turb_xclt
double cs_turb_xclt
extern
constant of EB-AFM and EB-DFM (0.122*2.5, See F. Dehoux thesis)
◆ cs_turb_xct
double cs_turb_xct
extern
◆ cs_turb_xiafm
extern
◆ cs_turb_xkappa
extern
Karman constant. (= 0.42)
Useful if and only if iturb >= 10. (mixing length, $k-\varepsilon$, $R_{ij}-\varepsilon$, LES, v2f or $k-\omega$).
◆ cs_turb_xlesfd
extern
Ratio between explicit and explicit filter width for a dynamic model. Constant used to define, for each cell $\Omega_i$, the width of the explicit filter used in the framework of the LES dynamic model: $\widetilde{\overline{\Delta}}=xlesfd\overline{\Delta}$.
◆ cs_turb_xlesfl
extern
Constant used in the definition of LES filtering diameter: $ \delta = \text{xlesfl} . (\text{ales} . volume)^{\text{bles}}$ cs_turb_xlesfl is a constant used to define, for each cell $\Omega_i$, the width of the (implicit) filter: $\overline{\Delta}=xlesfl(ales*|\Omega_i|)^{bles}$
