1 #ifndef __CS_TURBULENCE_KW_H__
2 #define __CS_TURBULENCE_KW_H__
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
@ dt
void cs_turbulence_kw_mu_t(int phase_id)
Calculation of turbulent viscosity for the SST model.
Definition: cs_turbulence_kw.c:1747
void cs_turbulence_kw(int phase_id, cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t dt[], cs_real_t smacel[])
Solve the k-omega equations.
Definition: cs_turbulence_kw.c:140
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:191
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:185
