8.1
cs_turbulence_init.h File Reference
+ Include dependency graph for cs_turbulence_init.h:
void cs_turbulence_init_by_ref_quantities (void)
 First pass at initialization of turbulence variables. More...
int cs_turbulence_init_clip_and_verify (void)
 Clipping of turbulence variables initialization. More...
◆ cs_turbulence_init_by_ref_quantities()
void cs_turbulence_init_by_ref_quantities ( void  )
If the reference velocity is negative (incorrect or not initialized), values of k, Rij, epsilon, and omega are set to -10*cs_math_big_r. We will later test if those values were modified by user initialization or reading a restart file.
◆ cs_turbulence_init_clip_and_verify()
int cs_turbulence_init_clip_and_verify ( void  )
If the user has prescribed "correct" values (in the sense that k, eps, Rii, ... > 0), we clip these values if needed for consistency.
If the prescribed values are manifestly incorrect (negative values), we assume this is an error, print warnings, and return a positive error count.
The same logic is applied to computation restarts.
