Enumerations | |
enum | cs_turbomachinery_model_t { CS_TURBOMACHINERY_NONE , CS_TURBOMACHINERY_FROZEN , CS_TURBOMACHINERY_TRANSIENT } |
void | cs_turbomachinery_set_model (cs_turbomachinery_model_t model) |
Define rotor/stator model. More... | |
cs_turbomachinery_model_t | cs_turbomachinery_get_model (void) |
Return rotor/stator model. More... | |
int | cs_turbomachinery_get_n_couplings (void) |
Return number of boundary couplings used for rotor/stator model. More... | |
void | cs_turbomachinery_add_rotor (const char *cell_criteria, double rotation_velocity, const double rotation_axis[3], const double rotation_invariant[3]) |
Define a rotor by its axis and cell selection criteria. More... | |
int | cs_turbomachinery_join_add (const char *sel_criteria, float fraction, float plane, int verbosity, int visualization) |
Add a cs_join_t structure to the list of rotor/stator joinings. More... | |
int | cs_turbomachinery_coupling_add (const char *sel_criteria, float tolerance, int verbosity) |
Add a boundary coupling to the list of rotor/stator couplings. More... | |
void | cs_turbomachinery_define (void) |
Definitions for turbomachinery computation. More... | |
void | cs_turbomachinery_initialize (void) |
Initializations for turbomachinery computation. More... | |
void | cs_turbomachinery_finalize (void) |
Free turbomachinery structure. More... | |
void | cs_turbomachinery_update_mesh (double *t_elapsed) |
Update mesh for unsteady rotor/stator computation. More... | |
void | cs_turbomachinery_restart_mesh (void) |
Update mesh for unsteady rotor/stator computation in case of restart. More... | |
void | cs_turbomachinery_reinit_i_face_fields (void) |
Reinitialize interior face-based fields. More... | |
void | cs_turbomachinery_resize_cell_fields (void) |
Resize cell-based fields. More... | |
void | cs_turbomachinery_rotation_matrix (int rotor_num, double theta, cs_real_t matrix[3][4]) |
Compute rotation matrix. More... | |
int | cs_turbomachinery_n_rotors (void) |
Return number of rotors. More... | |
const int * | cs_turbomachinery_get_cell_rotor_num (void) |
Return cell rotor number. More... | |
void | cs_turbomachinery_get_wall_bc_coeffs (cs_real_t **coftur, cs_real_t **hfltur) |
Get arrays associated to wall BC update. More... | |
double | cs_turbomachinery_get_rotation_velocity (int rotor_num) |
Return rotation velocity. More... | |
void | cs_turbomachinery_set_rotation_velocity (int rotor_num, double omega) |
Set rotation velocity. More... | |
cs_real_34_t * | cs_turbomachinery_get_rotation_matrices (double dt) |
Build rotation matrices for a given time interval. More... | |
void | cs_turbomachinery_set_rotation_retry (int n_max_join_retries, double dt_retry_multiplier) |
Set turbomachinery joining retry parameters. More... | |
void | cs_turbomachinery_rotate_fields (const cs_real_t dt[]) |
Rotation of vector and tensor fields. More... | |
void | cs_turbomachinery_relative_velocity (int rotor_num, const cs_real_t coords[3], cs_real_t velocity[3]) |
Compute velocity relative to fixed coordinates at a given point. More... | |
void | cs_turbomachinery_restart_read (cs_restart_t *r) |
Read turbomachinery metadata from restart file. More... | |
void | cs_turbomachinery_restart_write (cs_restart_t *r) |
Write turbomachinery metadata to checkpoint file. More... | |
void | cs_turbomachinery_define_functions (void) |
Create or access function objects specific to turbomachinery models (relative_pressure, relative_velocity). More... | |
void cs_turbomachinery_add_rotor | ( | const char * | cell_criteria, |
double | rotation_velocity, | ||
const double | rotation_axis[3], | ||
const double | rotation_invariant[3] | ||
[in] | cell_criteria | cell selection criteria string |
[in] | rotation_velocity | rotation velocity, in radians/second |
[in] | rotation_axis | rotation axis vector |
[in] | rotation_invariant | rotation invariant point |
int cs_turbomachinery_coupling_add | ( | const char * | sel_criteria, |
float | tolerance, | ||
int | verbosity | ||
[in] | sel_criteria | boundary face selection criteria |
[in] | tolerance | value of the search tolerance |
[in] | verbosity | level of verbosity required |
void cs_turbomachinery_define | ( | void | ) |
void cs_turbomachinery_define_functions | ( | void | ) |
void cs_turbomachinery_finalize | ( | void | ) |
const int* cs_turbomachinery_get_cell_rotor_num | ( | void | ) |
Each cell may be associated with a given rotor, or rotation, with 0 indicating that that cell does not rotate.
cs_turbomachinery_model_t cs_turbomachinery_get_model | ( | void | ) |
int cs_turbomachinery_get_n_couplings | ( | void | ) |
Joining-based definitions are not counted here.
cs_real_34_t* cs_turbomachinery_get_rotation_matrices | ( | double | dt | ) |
The caller is responsible for freeing the array when not needed.
[in] | dt | associated time delta (0 for current, unmodified time) |
double cs_turbomachinery_get_rotation_velocity | ( | int | rotor_num | ) |
[in] | rotor_num | rotor number (1 to n numbering) |
[out] | coftur | values of "cofimp" term before geometry update |
[out] | hfltur | local exchange coefficient before geometry update |
void cs_turbomachinery_initialize | ( | void | ) |
int cs_turbomachinery_join_add | ( | const char * | sel_criteria, |
float | fraction, | ||
float | plane, | ||
int | verbosity, | ||
int | visualization | ||
[in] | fraction | value of the fraction parameter |
[in] | plane | value of the plane parameter |
[in] | visualization | level of visualization required |
int cs_turbomachinery_n_rotors | ( | void | ) |
Note that the number of associated rotations is n_rotors + 1, as the first rotation id is reserved for the fixed portion of the domain.
void cs_turbomachinery_reinit_i_face_fields | ( | void | ) |
void cs_turbomachinery_relative_velocity | ( | int | rotor_num, |
const cs_real_t | coords[3], | ||
cs_real_t | velocity[3] | ||
[in] | coords | point coordinates |
[out] | velocity | velocity relative to fixed coordinates |
void cs_turbomachinery_resize_cell_fields | ( | void | ) |
This function only handles fields owning their values.
void cs_turbomachinery_restart_mesh | ( | void | ) |
Reads mesh from checkpoint when available.
void cs_turbomachinery_restart_read | ( | cs_restart_t * | r | ) |
The mesh is handled separately.
[in,out] | r | associated restart file pointer |
void cs_turbomachinery_restart_write | ( | cs_restart_t * | r | ) |
void cs_turbomachinery_rotate_fields | ( | const cs_real_t | dt[] | ) |
void cs_turbomachinery_rotation_matrix | ( | int | rotor_num, |
double | theta, | ||
cs_real_t | matrix[3][4] | ||
[in] | theta | rotation angle, in radians |
[out] | matrix | resulting rotation matrix |
void cs_turbomachinery_set_model | ( | cs_turbomachinery_model_t | model | ) |
void cs_turbomachinery_set_rotation_retry | ( | int | n_max_join_retries, |
double | dt_retry_multiplier | ||
When a joing leads to a different number of boundary faces from the previous position, the rotor positions may be perturbed by a small quantity to try to obtain a better joining.
param[in] n_max_join_retries maximum number of retries before considering the joining has failed param[in] dt_retry_multiplier time step multiplier for new position retry
void cs_turbomachinery_set_rotation_velocity | ( | int | rotor_num, |
double | omega | ||
param[in] rotor_num rotor number (1 to n numbering) param[in] omega rotation velocity
void cs_turbomachinery_update_mesh | ( | double * | t_elapsed | ) |
[out] | t_elapsed | elapsed computation time |
