Specific physic subroutine: diffusion flame. More...
Functions/Subroutines | |
| subroutine | cs_steady_laminar_flamelet_physical_prop (mbrom, izfppp) |
| subroutine | filtered_physical_prop (zm0, zvar0, kim0, xrm0, phim, rad_work, update_rad) |
| subroutine | filtered_density (zm0, zvar0, kim0, xrm0, rhom) |
| subroutine | filtered_physical_prop_progvar (zm0, zvar0, cm0, xrm0, phim, rad_work, update_rad) |
| subroutine | filtered_density_progvar (zm0, zvar0, cm0, xrm0, rhom) |
| subroutine | max_mid_min_progvar (zm0, cmax, cmid, cmin) |
| subroutine | scalar_dissipation_rate () |
| subroutine | combustion_reconstruct_variance (iprev) |
Calculation of mean thermophysic properties
Interpolation of mean thermophysic properties as a function of fm, fp2m, ki, xr
Interpolation of mean density as a function of fm, fp2m, ki, xr
Interpolation of mean thermophysic properties as a function of fm, fp2m, c, xr
Interpolation of mean density as a function of fm, fp2m, c, xr
Calculation of Min/Max of progress variable as a function of fm
Calculation of total scalar dissipation rate
Calculation of reconstructed variance of mixture fraction
| subroutine combustion_reconstruct_variance | ( | integer | iprev | ) |
| subroutine cs_steady_laminar_flamelet_physical_prop | ( | integer | mbrom, |
| integer, dimension(nfabor) | izfppp | ||
| [in] | mbrom | indicator of prescribed density at the boundary |
| [in] | izfppp | area number of the edge face for the specific physic module |
| subroutine filtered_density | ( | double precision | zm0, |
| double precision | zvar0, | ||
| double precision | kim0, | ||
| double precision | xrm0, | ||
| double precision | rhom | ||
| subroutine filtered_density_progvar | ( | double precision | zm0, |
| double precision | cm0, | ||
| subroutine filtered_physical_prop | ( | double precision | zm0, |
| double precision, dimension(nlibvar) | phim, | ||
| double precision, dimension(2, nwsgg) | rad_work, | ||
| logical | update_rad | ||
| subroutine filtered_physical_prop_progvar | ( | double precision | zm0, |
| subroutine max_mid_min_progvar | ( | double precision | zm0, |
| double precision | cmax, | ||
| double precision | cmid, | ||
| double precision | cmin | ||
| subroutine scalar_dissipation_rate |
