8.1
cs_solidification.h
1 #ifndef __CS_SOLIDIFICATION_H__
2 #define __CS_SOLIDIFICATION_H__
5  * Header to handle the solidification module with CDO schemes
29  * Local headers
32 #include "cs_base.h"
33 #include "cs_boundary.h"
34 #include "cs_equation.h"
35 #include "cs_iter_algo.h"
36 #include "cs_navsto_param.h"
37 #include "cs_time_plot.h"
38 #include "cs_time_step.h"
45  * Macro definitions
92 #define CS_SOLIDIFICATION_POST_CELL_STATE (1 << 0) /* = 1 */
93 #define CS_SOLIDIFICATION_POST_ENTHALPY (1 << 1) /* = 2 */
94 #define CS_SOLIDIFICATION_POST_CBULK_ADIM (1 << 2) /* = 4 */
95 #define CS_SOLIDIFICATION_POST_CLIQ (1 << 3) /* = 8 */
96 #define CS_SOLIDIFICATION_POST_LIQUIDUS_TEMPERATURE (1 << 4) /* = 16 */
97 #define CS_SOLIDIFICATION_POST_SEGREGATION_INDEX (1 << 5) /* = 32 */
98 #define CS_SOLIDIFICATION_POST_SOLIDIFICATION_RATE (1 << 6) /* = 64 */
99 #define CS_SOLIDIFICATION_ADVANCED_ANALYSIS (1 << 7) /* = 128 */
100
132 #define CS_SOLIDIFICATION_USE_ENTHALPY_VARIABLE (1 << 0) /*= 1 */
133 #define CS_SOLIDIFICATION_NO_VELOCITY_FIELD (1 << 1) /*= 2 */
134 #define CS_SOLIDIFICATION_WITH_SOLUTE_SOURCE_TERM (1 << 2) /*= 4 */
135 #define CS_SOLIDIFICATION_USE_EXTRAPOLATION (1 << 3) /*= 8 */
136 #define CS_SOLIDIFICATION_WITH_PENALIZED_EUTECTIC (1 << 4) /*= 16 */
137
138 /* Automatically set by the code if user functions are used
139  * The following flags are set when calling \ref cs_solidification_set_functions
140  *
141  * \def CS_SOLIDIFICATION_BINARY_ALLOY_M_FUNC
142  * \brief the update of the forcing term (penalization) in the momentum equation
143  * is defined using a user function
144  *
145  * \def CS_SOLIDIFICATION_BINARY_ALLOY_C_FUNC
146  * \brief the update of the liquid concentration of the binary alloy is defined
147  * using a user function
148  *
149  * \def CS_SOLIDIFICATION_BINARY_ALLOY_G_FUNC
150  * \brief the update of the liquid fraction is defined using a user function
151  *
152  * \def CS_SOLIDIFICATION_BINARY_ALLOY_T_FUNC
153  * \brief the update of the thermal source term is defined using a user function
154  */
155 #define CS_SOLIDIFICATION_BINARY_ALLOY_M_FUNC (1 << 7) /*= 128 */
156 #define CS_SOLIDIFICATION_BINARY_ALLOY_C_FUNC (1 << 8) /*= 256 */
157 #define CS_SOLIDIFICATION_BINARY_ALLOY_G_FUNC (1 << 9) /*= 512 */
158 #define CS_SOLIDIFICATION_BINARY_ALLOY_T_FUNC (1 <<10) /*= 1024 */
159
164 /*=============================================================================
165  * Structure and type definitions
166  *============================================================================*/
167
195 typedef enum {
196
201
203
205
225 typedef enum {
226
231
233
235
243 typedef enum {
244
248
250
252
253 /*----------------------------------------------------------------------------*/
264 /*----------------------------------------------------------------------------*/
265
266 typedef void
268  const cs_cdo_connect_t *connect,
269  const cs_cdo_quantities_t *quant,
270  const cs_time_step_t *ts);
271
272 /* Structure storing physical parameters related to a choice of solidification
273  modelling */
274
275 /*----------------------------------------------------------------------------
276  * Stefan model
277  *----------------------------------------------------------------------------
278  *
279  * Neither advection nor segregation is taken into account.
280  * The liquid fraction is a step function w.r.t. the temperature.
281  */
282
283 typedef struct {
284
285  /* Physical parameters to specify the law of variation of the liquid fraction
286  * with respect to the temperature
287  *
288  * gl(T) = 1 if T > T_change
289  * Otherwise:
290  * gl(T) = 0
291  */
292
294
295  /* Function pointers */
296  /* ----------------- */
297
298  /* Function to update the liquid fraction */
299
301
302  /* Function to update the source term for the thermal equation */
303
305
306  /* Numerical parameters */
307  /* -------------------- */
308
310  double max_delta_h;
311
313
314
315 /* Voller and Prakash model "A fixed grid numerical modelling methodology for
316  * convection-diffusion mushy region phase-change problems" Int. J. Heat
317  * Transfer, 30 (8), 1987.
318  * No tracer. Only physical constants describing the solidification process are
319  * used.
320  */
321
322 /*----------------------------------------------------------------------------
323  * Solidification without segregation (Voller & Prakash'87 model)
324  *----------------------------------------------------------------------------*/
325
326 typedef struct {
327
328  /* Secondary dendrite arm spacing */
329
331
332  /* Physical parameters to specify the law of variation of the liquid fraction
333  * with respect to the temperature
334  *
335  * gl(T) = 1 if T > t_liquidus and gl(T) = 0 if T < t_solidus
336  * Otherwise:
337  * gl(T) = (T - t_solidus)/(t_liquidus - t_solidus)
338  */
339
342
343  /* Function pointers */
344  /* ----------------- */
345
346  /* Function to update the liquid fraction */
347
349
350  /* Function to update the source term for the thermal equation */
351
353
354  /* Numerical parameters */
355  /* -------------------- */
356
359
361
362
363 /*----------------------------------------------------------------------------
364  * Solidification of a binary alloy with segregation (Voller & Prakash'89 model)
365  *----------------------------------------------------------------------------*/
366
367 typedef struct {
368
369  /* Alloy features */
370  /* -------------- */
371
372  /* Reference mixture concentration (used in the Boussinesq approximation and
373  * for normalization */
374
376
377  /* Phase diagram features for an alloy with the component A and B */
378  /* -------------------------------------------------------------- */
379
380  /* Secondary dendrite arm spacing */
381
383
384  /* Physical parameters */
385
386  cs_real_t kp; /* distribution coefficient */
387  cs_real_t inv_kp; /* reciprocal of kp */
388  cs_real_t inv_kpm1; /* 1/(kp - 1) */
389  cs_real_t ml; /* Liquidus slope \frac{\partial g_l}{\partial C} */
390  cs_real_t inv_ml; /* reciprocal of ml */
391
392  /* Temperature of phase change for the pure material (conc = 0) */
393
395
396  /* Eutectic point: temperature and concentration */
397
401
405
406  /* The variable related to this equation in the solute concentration of
407  * the mixture: c_bulk (c_s in the solid phase and c_l in the liquid phase)
408  * c_bulk = gs*c_s + gl*c_l where gs + gl = 1
409  * gl is the liquid fraction and gs the solid fraction
410  * c_s = kp * c_l (lever rule is assumed up to now)
411  *
412  * --> c_bulk = (gs*kp + gl)*c_l
413  */
414
415  /* Function to update the liquid fraction */
416
418
419  /* Function to update the source term for the thermal equation */
420
422
423  /* Function to update the velocity forcing in the momentum equation */
424
426
427  /* Function to update c_l in each cell */
428
430
431  /* Drive the convergence of the coupled system (solute transport and thermal
432  * equation) with respect to the following criteria (taken from Voller and
433  * Swaminathan'91)
434  * max_{c\in C} |Temp^(k+1) - Temp^(k)| < delta_tolerance
435  * max_{c\in C} |Cbulk^(k+1) - Cbulk*^(k)| < delta_tolerance
436  * n_iter < n_iter_max
437  *
438  * eta_relax: add a relaxation in the update of the eta coefficient
439  * conc_liq = eta_coef * conc_bulk
440  * eta_relax = 0. --> No relaxation (default choice)
441  *
442  * gliq_relax: idem but for the liquid fraction
443  */
444
445  int iter;
448  double eta_relax;
449  double gliq_relax;
450
451  /* During the non-linear iteration process one needs:
452  * temp_{n} --> stored in field->val_pre
453  * temp_{n+1}^k --> stored in tk_bulk (in this structure)
454  * temp_{n+1}^{k+1} --> stored in field->val
455  *
456  * Optionally one may consider an extrapolated temperature and bulk
457  * concentration
458  * temp_{n+1}^{extrap} = 2*temp_{n} - temp_{n-1}
459  *
460  * Same thing for the bulk concentration.
461  */
462
467
468  /* Solute concentration in the liquid phase
469  * 1) array of the last computed values at cells
470  * 2) array of the last computed values at faces (interior and border) */
471
474
475  /* Temperature values at faces (this is not owned by the structure) */
476
478
479  /* Equation for the solute transport and related quantities */
480
483
484  /* Diffusion coefficient for the solute in the liquid phase
485  * diff_pty_val = rho * g_l * diff_coef */
486
490
493
494  /* Optional post-processing arrays */
495  /* ------------------------------ */
496
497  /* Liquidus temperature (values at cell centers) */
498
500
501  /* Quantities for advanced analysis */
502
505
507
508 /*----------------------------------------------------------------------------
509  * Main structure to manage the solidification process
510  *----------------------------------------------------------------------------*/
511
512 typedef struct {
513
514  cs_flag_t model; /* Modelling for the solidification module */
515  cs_flag_t options; /* Flag dedicated to general options to handle
516  * the solidification module*/
517  cs_flag_t post_flag; /* Flag dedicated to the post-processing
518  * of the solidification module */
519  int verbosity; /* Level of verbosity */
520
521  /* Physical properties common to all models */
522  /* ---------------------------------------- */
523
524  /* Mass density of the liquid/solid media */
525
527
528  /* Reference value for the heat capacity in the solidification/melting area
529  * (assumed to be uniform) */
530
532
533  /* Viscosity (pointer to the total viscosity which should be equal to the
534  * laminar viscosity since no turbulence modelling is usually taken into
535  * account */
536
538
539  /* Physical parameter for computing the source term in the energy equation
540  * Latent heat between the liquid and solid phase
541  */
542
544
545
546  /* Liquid fraction of the mixture */
547  /* ------------------------------ */
548
549  cs_field_t *g_l_field; /* field storing the values of the liquid
550  fraction at each cell */
551  cs_property_t *g_l; /* liquid fraction property */
552
553  /* array storing the state (solid, mushy, liquid) for each cell */
554
556
557  /* Plot evolution of the solidification process */
558
560
561  /* Monitoring related to this module */
562
565
566  /* Quantities related to the energy equation */
567  /* ----------------------------------------- */
568
570
571  /* Fields associated to this module */
572
574
575  /* Enthalpy (by default this a derived field which can be used to update of
576  the liquid fraction) */
577
579
580
581  /* A reaction term and source term are introduced in the thermal model */
582
586
587  /* Additional settings related to the choice of solidification modelling */
588
590
591  /* Strategy to update quantities during the solidification process. These
592  * quantities are the liquid fraction, the thermal source term for
593  * instance */
594
596
597  /* A reaction term is introduced in the momentum equation. This terms tends to
598  * a huge number when the liquid fraction tends to 0 in order to penalize
599  * the velocity to zero when the whole cell is solid
600  */
601
602  cs_real_t *forcing_mom_array; /* values of the forcing reaction
603  coefficient in each cell */
605
606  /* Porous media like reaction term in the momentum equation:
607  *
608  * forcing_coef = 180 * visco0 / s_das^2
609  * where visco0 is the laminar viscosity and s_das is the secondary
610  * dendrite arm spacing
611  * F(u) = forcing_coef * (1- gl)^2/(gl^3 + forcing_eps) * u
612  */
613
615
616  /* First cell associated to a fluid/solid area (i.e. not associated to
617  * a permanent solid zone) */
618
620
622
623 /*============================================================================
624  * Public function prototypes
625  *============================================================================*/
626
627 /*----------------------------------------------------------------------------*/
631 /*----------------------------------------------------------------------------*/
632
633 bool
635
636 /*----------------------------------------------------------------------------*/
642 /*----------------------------------------------------------------------------*/
643
646
647 /*----------------------------------------------------------------------------*/
653 /*----------------------------------------------------------------------------*/
654
655 void
656 cs_solidification_set_verbosity(int verbosity);
657
658 /*----------------------------------------------------------------------------*/
666 /*----------------------------------------------------------------------------*/
667
668 void
670
671 /*----------------------------------------------------------------------------*/
686 /*----------------------------------------------------------------------------*/
687
690  cs_flag_t options,
691  cs_flag_t post_flag,
692  const cs_boundary_t *boundaries,
693  cs_navsto_param_model_t ns_model,
694  cs_navsto_param_model_flag_t ns_model_flag,
695  cs_navsto_param_coupling_t algo_coupling,
696  cs_navsto_param_post_flag_t ns_post_flag);
697
698 /*----------------------------------------------------------------------------*/
704 /*----------------------------------------------------------------------------*/
705
708
709 /*----------------------------------------------------------------------------*/
715 /*----------------------------------------------------------------------------*/
716
719
720 /*----------------------------------------------------------------------------*/
727 /*----------------------------------------------------------------------------*/
728
729 void
731  cs_real_t latent_heat);
732
733 /*----------------------------------------------------------------------------*/
739 /*----------------------------------------------------------------------------*/
740
743
744 /*----------------------------------------------------------------------------*/
750 /*----------------------------------------------------------------------------*/
751
754
755 /*----------------------------------------------------------------------------*/
767 /*----------------------------------------------------------------------------*/
768
769 void
771  cs_real_t t_ref,
772  cs_real_t t_solidus,
773  cs_real_t t_liquidus,
774  cs_real_t latent_heat,
775  cs_real_t s_das);
776
777 /*----------------------------------------------------------------------------*/
786 /*----------------------------------------------------------------------------*/
787
788 void
790  cs_real_t t_liquidus,
791  cs_real_t latent_heat);
792
793 /*----------------------------------------------------------------------------*/
799 /*----------------------------------------------------------------------------*/
800
803
804 /*----------------------------------------------------------------------------*/
811 /*----------------------------------------------------------------------------*/
812
815
816 /*----------------------------------------------------------------------------*/
838 /*----------------------------------------------------------------------------*/
839
840 void
842  const char *varname,
843  cs_real_t beta_t,
844  cs_real_t temp0,
845  cs_real_t beta_c,
846  cs_real_t conc0,
847  cs_real_t kp,
848  cs_real_t mliq,
849  cs_real_t t_eutec,
850  cs_real_t t_melt,
851  cs_real_t solute_diff,
852  cs_real_t latent_heat,
853  cs_real_t s_das);
854
855 /*----------------------------------------------------------------------------*/
862 /*----------------------------------------------------------------------------*/
863
864 void
866
867 /*----------------------------------------------------------------------------*/
884 /*----------------------------------------------------------------------------*/
885
886 void
888  cs_solidification_func_t *cliq_update,
889  cs_solidification_func_t *gliq_update,
890  cs_solidification_func_t *thm_st_update);
891
892 /*----------------------------------------------------------------------------*/
898 /*----------------------------------------------------------------------------*/
899
902
903 /*----------------------------------------------------------------------------*/
907 /*----------------------------------------------------------------------------*/
908
909 void
911
912 /*----------------------------------------------------------------------------*/
920 /*----------------------------------------------------------------------------*/
921
922 void
924  const cs_cdo_quantities_t *quant);
925
926 /*----------------------------------------------------------------------------*/
931 /*----------------------------------------------------------------------------*/
932
933 void
935
936 /*----------------------------------------------------------------------------*/
946 /*----------------------------------------------------------------------------*/
947
948 void
950  const cs_cdo_connect_t *connect,
951  const cs_cdo_quantities_t *quant,
952  const cs_time_step_t *time_step);
953
954 /*----------------------------------------------------------------------------*/
963 /*----------------------------------------------------------------------------*/
964
965 void
967  const cs_cdo_connect_t *connect,
968  const cs_cdo_quantities_t *quant,
969  const cs_time_step_t *time_step);
970
971 /*----------------------------------------------------------------------------*/
979 /*----------------------------------------------------------------------------*/
980
981 void
983  const cs_cdo_quantities_t *quant,
984  const cs_time_step_t *ts);
985
986 /*----------------------------------------------------------------------------*/
1008 /*----------------------------------------------------------------------------*/
1009
1010 void
1011 cs_solidification_extra_post(void *input,
1012  int mesh_id,
1013  int cat_id,
1014  int ent_flag[5],
1015  cs_lnum_t n_cells,
1016  cs_lnum_t n_i_faces,
1017  cs_lnum_t n_b_faces,
1018  const cs_lnum_t cell_ids[],
1019  const cs_lnum_t i_face_ids[],
1020  const cs_lnum_t b_face_ids[],
1021  const cs_time_step_t *time_step);
1022
1023 /*----------------------------------------------------------------------------*/
1024
1026
1027 #endif /* __CS_SOLIDIFICATION_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:298
Definition: cs_defs.h:515
Definition: cs_defs.h:313
unsigned short int cs_flag_t
Definition: cs_defs.h:321
cs_flag_t cs_navsto_param_post_flag_t
Definition: cs_navsto_param.h:59
Definition: cs_navsto_param.h:577
Describe the system of equations related to the Navier-Stokes to be solved.
Definition: cs_navsto_param.h:82
cs_flag_t cs_navsto_param_model_flag_t
Definition: cs_navsto_param.h:58
cs_param_nl_algo_t
Class of non-linear iterative algorithm.
Definition: cs_param_types.h:552
void cs_solidification_compute(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Solve equations related to the solidification module.
Definition: cs_solidification.c:5035
void cs_solidification_set_strategy(cs_solidification_strategy_t strategy)
Set the strategy to update quantitiess (liquid fraction and the thermal source term for the two main ...
Definition: cs_solidification.c:3988
cs_solidification_stefan_t * cs_solidification_check_stefan_model(void)
Sanity checks on the consistency of the Stefan's model settings.
Definition: cs_solidification.c:3591
void cs_solidification_set_voller_model(cs_real_t beta, cs_real_t t_ref, cs_real_t t_solidus, cs_real_t t_liquidus, cs_real_t latent_heat, cs_real_t s_das)
Set the main physical parameters which describe the Voller and Prakash modelling.
Definition: cs_solidification.c:3699
void() cs_solidification_func_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
Function pointer associated to a solidification model aiming at updating/initializing the solidificat...
Definition: cs_solidification.h:267
void cs_solidification_extra_op(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
Predefined extra-operations for the solidification module.
Definition: cs_solidification.c:5090
void cs_solidification_init_values(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Set an initial values for all quantities related to this module This is done after the setup step.
Definition: cs_solidification.c:4823
cs_solidification_binary_alloy_t * cs_solidification_get_binary_alloy_struct(void)
Get the structure defining the binary alloy model.
Definition: cs_solidification.c:3769
cs_solidification_voller_t * cs_solidification_check_voller_model(void)
Sanity checks on the consistency of the Voller's model settings.
Definition: cs_solidification.c:3667
cs_solidification_t * cs_solidification_activate(cs_solidification_model_t model, cs_flag_t options, cs_flag_t post_flag, const cs_boundary_t *boundaries, cs_navsto_param_model_t ns_model, cs_navsto_param_model_flag_t ns_model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t ns_post_flag)
Activate the solidification module.
Definition: cs_solidification.c:3251
Type of physical model used to simulate the solidifcation/fusion process.
Definition: cs_solidification.h:195
@ CS_SOLIDIFICATION_MODEL_BINARY_ALLOY
Definition: cs_solidification.h:200
@ CS_SOLIDIFICATION_MODEL_VOLLER_NL
Definition: cs_solidification.h:199
@ CS_SOLIDIFICATION_MODEL_VOLLER_PRAKASH_87
Definition: cs_solidification.h:198
@ CS_SOLIDIFICATION_N_MODELS
Definition: cs_solidification.h:202
@ CS_SOLIDIFICATION_MODEL_STEFAN
Definition: cs_solidification.h:197
cs_solidification_binary_alloy_t * cs_solidification_check_binary_alloy_model(void)
Sanity checks on the consistency of the settings of the binary alloy model.
Definition: cs_solidification.c:3798
void cs_solidification_init_setup(void)
Setup equations/properties related to the solidification module.
Definition: cs_solidification.c:4240
void cs_solidification_set_binary_alloy_model(const char *name, const char *varname, cs_real_t beta_t, cs_real_t temp0, cs_real_t beta_c, cs_real_t conc0, cs_real_t kp, cs_real_t mliq, cs_real_t t_eutec, cs_real_t t_melt, cs_real_t solute_diff, cs_real_t latent_heat, cs_real_t s_das)
Set the main physical parameters which describe a solidification process with a binary alloy (with co...
Definition: cs_solidification.c:3853
Kind of strategy to use to model the segregation/solidification process. This implies a setting of fu...
Definition: cs_solidification.h:243
@ CS_SOLIDIFICATION_STRATEGY_LEGACY
Definition: cs_solidification.h:245
@ CS_SOLIDIFICATION_STRATEGY_TAYLOR
Definition: cs_solidification.h:246
@ CS_SOLIDIFICATION_STRATEGY_PATH
Definition: cs_solidification.h:247
@ CS_SOLIDIFICATION_N_STRATEGIES
Definition: cs_solidification.h:249
cs_solidification_voller_t * cs_solidification_get_voller_struct(void)
Get the structure defining the Voller model.
Definition: cs_solidification.c:3638
void cs_solidification_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Finalize the setup stage for equations related to the solidification module.
Definition: cs_solidification.c:4419
void cs_solidification_set_verbosity(int verbosity)
Set the level of verbosity for the solidification module.
Definition: cs_solidification.c:3207
void cs_solidification_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the solidification module. Prototype of this function is fixed ...
Definition: cs_solidification.c:5253
cs_solidification_state_t
Kind of state in which a cell or an entity is.
Definition: cs_solidification.h:225
@ CS_SOLIDIFICATION_STATE_SOLID
Definition: cs_solidification.h:227
@ CS_SOLIDIFICATION_N_STATES
Definition: cs_solidification.h:232
@ CS_SOLIDIFICATION_STATE_LIQUID
Definition: cs_solidification.h:229
@ CS_SOLIDIFICATION_STATE_MUSHY
Definition: cs_solidification.h:228
@ CS_SOLIDIFICATION_STATE_EUTECTIC
Definition: cs_solidification.h:230
bool cs_solidification_is_activated(void)
Test if solidification module is activated.
Definition: cs_solidification.c:3176
void cs_solidification_set_stefan_model(cs_real_t t_change, cs_real_t latent_heat)
Set the main physical parameters which describe the Stefan model.
Definition: cs_solidification.c:3617
void cs_solidification_log_setup(void)
Summarize the solidification module in the log file dedicated to the setup.
Definition: cs_solidification.c:4619
void cs_solidification_set_voller_model_no_velocity(cs_real_t t_solidus, cs_real_t t_liquidus, cs_real_t latent_heat)
Definition: cs_solidification.c:3740
void cs_solidification_set_segr_functions(cs_solidification_func_t *vel_forcing, cs_solidification_func_t *cliq_update, cs_solidification_func_t *gliq_update, cs_solidification_func_t *thm_st_update)
Set the functions to perform the update of physical properties and/or the computation of the thermal ...
Definition: cs_solidification.c:4101
cs_solidification_t * cs_solidification_destroy_all(void)
Free the main structure related to the solidification module.
Definition: cs_solidification.c:4145
void cs_solidification_set_forcing_eps(cs_real_t forcing_eps)
Set the value of the epsilon parameter used in the forcing term of the momentum equation.
Definition: cs_solidification.c:3227
cs_solidification_stefan_t * cs_solidification_get_stefan_struct(void)
Get the structure defining the Stefan model.
Definition: cs_solidification.c:3563
cs_solidification_t * cs_solidification_get_structure(void)
Retrieve the main structure to deal with solidification process.
Definition: cs_solidification.c:3193
Definition: cs_time_plot.h:48
double precision, dimension(ncharm), save beta
Definition: cpincl.f90:96
Definition: mesh.f90:26
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:155
Definition: cs_cdo_quantities.h:137
Definition: cs_field.h:131
Definition: cs_iter_algo.h:289
Definition: cs_mesh.h:85
Definition: cs_solidification.h:367
cs_real_t * c_l_faces
Definition: cs_solidification.h:473
cs_real_t t_eut_inf
Definition: cs_solidification.h:399
cs_solidification_func_t * update_clc
Definition: cs_solidification.h:429
cs_real_t ml
Definition: cs_solidification.h:389
cs_real_t kp
Definition: cs_solidification.h:386
cs_real_t * eta_coef_array
Definition: cs_solidification.h:492
const cs_real_t * temp_faces
Definition: cs_solidification.h:477
cs_real_t inv_ml
Definition: cs_solidification.h:390
cs_field_t * c_bulk
Definition: cs_solidification.h:482
cs_real_t * c_l_cells
Definition: cs_solidification.h:472
cs_solidification_func_t * update_velocity_forcing
Definition: cs_solidification.h:425
cs_solidification_func_t * update_thm_st
Definition: cs_solidification.h:421
cs_equation_t * solute_equation
Definition: cs_solidification.h:481
cs_real_t * t_liquidus
Definition: cs_solidification.h:499
cs_real_t t_melt
Definition: cs_solidification.h:394
cs_real_t * cliq_minus_cbulk
Definition: cs_solidification.h:504
cs_real_t dgldC_eut
Definition: cs_solidification.h:404
cs_real_t * tk_bulk
Definition: cs_solidification.h:463
double gliq_relax
Definition: cs_solidification.h:449
cs_real_t inv_kpm1
Definition: cs_solidification.h:388
cs_real_t inv_kp
Definition: cs_solidification.h:387
cs_real_t t_eut
Definition: cs_solidification.h:398
cs_real_t cs1
Definition: cs_solidification.h:403
cs_real_t t_eut_sup
Definition: cs_solidification.h:400
cs_real_t * tx_bulk
Definition: cs_solidification.h:465
cs_property_t * diff_pty
Definition: cs_solidification.h:488
double delta_tolerance
Definition: cs_solidification.h:447
cs_real_t diff_coef
Definition: cs_solidification.h:487
cs_real_t * tbulk_minus_tliq
Definition: cs_solidification.h:503
int n_iter_max
Definition: cs_solidification.h:446
cs_real_t ref_concentration
Definition: cs_solidification.h:375
cs_real_t * ck_bulk
Definition: cs_solidification.h:464
int iter
Definition: cs_solidification.h:445
cs_real_t c_eut
Definition: cs_solidification.h:402
cs_real_t * diff_pty_array
Definition: cs_solidification.h:489
cs_solidification_func_t * update_gl
Definition: cs_solidification.h:417
cs_real_t * cx_bulk
Definition: cs_solidification.h:466
cs_real_t s_das
Definition: cs_solidification.h:382
cs_property_t * eta_coef_pty
Definition: cs_solidification.h:491
double eta_relax
Definition: cs_solidification.h:448
Definition: cs_solidification.h:283
Definition: cs_solidification.h:304
int n_iter_max
Definition: cs_solidification.h:309
Definition: cs_solidification.h:300
cs_real_t t_change
Definition: cs_solidification.h:293
double max_delta_h
Definition: cs_solidification.h:310
Definition: cs_solidification.h:512
cs_property_t * mass_density
Definition: cs_solidification.h:526
Definition: cs_solidification.h:595
int verbosity
Definition: cs_solidification.h:519
cs_property_t * g_l
Definition: cs_solidification.h:551
cs_flag_t options
Definition: cs_solidification.h:515
cs_time_plot_t * plot_state
Definition: cs_solidification.h:559
cs_real_t forcing_coef
Definition: cs_solidification.h:614
cs_field_t * g_l_field
Definition: cs_solidification.h:549
cs_field_t * enthalpy
Definition: cs_solidification.h:578
cs_property_t * viscosity
Definition: cs_solidification.h:537
cs_real_t * forcing_mom_array
Definition: cs_solidification.h:602
Definition: cs_solidification.h:543
cs_real_t * thermal_source_term_array
Definition: cs_solidification.h:585
cs_flag_t post_flag
Definition: cs_solidification.h:517
cs_field_t * temperature
Definition: cs_solidification.h:573
cs_thermal_system_t * thermal_sys
Definition: cs_solidification.h:569
cs_solidification_state_t * cell_state
Definition: cs_solidification.h:555
cs_flag_t model
Definition: cs_solidification.h:514
cs_real_t * thermal_reaction_coef_array
Definition: cs_solidification.h:584
cs_property_t * forcing_mom
Definition: cs_solidification.h:604
cs_property_t * thermal_reaction_coef
Definition: cs_solidification.h:583
cs_lnum_t first_cell
Definition: cs_solidification.h:619
cs_property_t * cp
Definition: cs_solidification.h:531
void * model_context
Definition: cs_solidification.h:589
Definition: cs_solidification.h:326
Definition: cs_solidification.h:352
cs_iter_algo_t * nl_algo
Definition: cs_solidification.h:358
cs_real_t t_solidus
Definition: cs_solidification.h:340
Definition: cs_solidification.h:348
cs_real_t s_das
Definition: cs_solidification.h:330
Definition: cs_solidification.h:341
cs_param_nl_algo_t nl_algo_type
Definition: cs_solidification.h:357
Definition: cs_thermal_system.h:132
time step descriptor
Definition: cs_time_step.h:64
