8.1
cs_saddle_itsol.h
1 #ifndef __CS_SADDLE_ITSOL_H__
2 #define __CS_SADDLE_ITSOL_H__
5  * In-house iterative solvers defined by blocks and associated to CDO
6  * discretizations for saddle-point system
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2023 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Standard C library headers
35  *----------------------------------------------------------------------------*/
36
37 /*----------------------------------------------------------------------------
38  * Local headers
39  *----------------------------------------------------------------------------*/
41 #include "cs_iter_algo.h"
42 #include "cs_matrix.h"
43 #include "cs_mesh_adjacencies.h"
44 #include "cs_param_sles.h"
45 #include "cs_range_set.h"
46 #include "cs_sles.h"
48 /*----------------------------------------------------------------------------*/
49
51
53  * Macro definitions
55
56 /*============================================================================
57  * Type definitions
59
60 typedef struct {
61
62  /*
63  * A hybrid storage is used to represent the system described below
64  *
65  * | M11 | M12 | | x1 | |rhs1 |
66  * M = |-----------| |----| = |-----|
67  * | M21 | 0 | | x2 | |rhs2 |
68  *
69  * One assumes that M12 = M21^T
70  */
71
72  int n_m11_matrices; /* 1, 3, 6 or 9 is expected */
74  cs_lnum_t x1_size; /* scatter view */
75  cs_lnum_t max_x1_size; /* max(x1_size, n_m11_cols) */
76
78
79  cs_lnum_t x2_size; /* scatter view */
80  cs_lnum_t max_x2_size; /* max(x2_size, n_m22_cols) */
82
85
86  /* Indexed list used to scan the unassembled m21 operator */
87
89
90  /* Structure used for synchronisation (parallel or periodic). Enable to
91  switch from a scatter view (the mesh view) to a gather view (the algebraic
92  view). This structure is shared. */
93
95
97
98 /* Structure handling the block preconditioning */
99
100 typedef struct {
101
102  /* Parameters */
103
106
107  /* Block 11 settings (mandatory) */
108
111
112  /* Schur complement settings (optional) */
113
118
119  /* Native arrays for the Schur matrix (optional) */
120
123
124  /* Diagonal approximations of block matrices (optional) */
125
128
130
131 /*============================================================================
132  * Public function prototypes
133  *============================================================================*/
134
135 /*----------------------------------------------------------------------------*/
147
150  cs_param_schur_approx_t schur_type,
151  cs_param_sles_t *m11_slesp,
152  cs_sles_t *m11_sles);
153
154 /*----------------------------------------------------------------------------*/
160 /*----------------------------------------------------------------------------*/
161
162 void
164
179 /*----------------------------------------------------------------------------*/
180
181 void
184  cs_real_t *x1,
185  cs_real_t *x2,
186  cs_iter_algo_t *algo);
187
188 /*----------------------------------------------------------------------------*/
205 /*----------------------------------------------------------------------------*/
206
207 void
208 cs_saddle_gcr(int restart,
209  cs_saddle_system_t *ssys,
211  cs_real_t *x1,
212  cs_real_t *x2,
213  cs_iter_algo_t *algo);
214
231 /*----------------------------------------------------------------------------*/
232
233 void
235  const cs_matrix_t *mat,
236  cs_real_t *vec,
237  cs_real_t *matvec);
238
239 /*----------------------------------------------------------------------------*/
256 /*----------------------------------------------------------------------------*/
257
258 void
260  const cs_matrix_t *mat,
261  cs_lnum_t vec_len,
262  cs_real_t *vec,
263  cs_real_t **p_matvec);
264
265 /*----------------------------------------------------------------------------*/
266
268
269 #endif /* __CS_SADDLE_ITSOL_H__ */
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
@ x2
Definition: cs_field_pointer.h:223
Definition: cs_matrix.h:110
Structure and routines handling the SLES settings stored inside a cs_param_sles_t structure.
cs_param_precond_block_t
Definition: cs_param_types.h:819
Strategy to build the Schur complement approximation. This appears in block preconditioning or Uzawa ...
Definition: cs_param_types.h:753
void cs_saddle_block_precond_free(cs_saddle_block_precond_t **p_sbp)
Free a cs_saddle_block_precond_t structure.
Definition: cs_saddle_itsol.c:1372
void cs_saddle_gcr(int restart, cs_saddle_system_t *ssys, cs_saddle_block_precond_t *sbp, cs_real_t *x1, cs_real_t *x2, cs_iter_algo_t *algo)
Apply the GCR algorithm to a saddle point problem (the system is stored in a hybrid way)....
Definition: cs_saddle_itsol.c:1633
void cs_matrix_vector_multiply_gs(const cs_range_set_t *rset, const cs_matrix_t *mat, cs_lnum_t vec_len, cs_real_t *vec, cs_real_t **p_matvec)
Perform a matrix-vector multiplication in case of scatter-view array as input parameter....
Definition: cs_saddle_itsol.c:1891
cs_saddle_block_precond_t * cs_saddle_block_precond_create(cs_param_precond_block_t block_type, cs_param_schur_approx_t schur_type, cs_param_sles_t *m11_slesp, cs_sles_t *m11_sles)
Create and initialize a cs_saddle_block_precond_t structure.
Definition: cs_saddle_itsol.c:1325
void cs_saddle_minres(cs_saddle_system_t *ssys, cs_saddle_block_precond_t *sbp, cs_real_t *x1, cs_real_t *x2, cs_iter_algo_t *algo)
Apply the MINRES algorithm to a saddle point problem (the system is stored in a hybrid way)....
Definition: cs_saddle_itsol.c:1408
void cs_matrix_vector_multiply_gs_allocated(const cs_range_set_t *rset, const cs_matrix_t *mat, cs_real_t *vec, cs_real_t *matvec)
Definition: cs_saddle_itsol.c:1836
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
Definition: cs_iter_algo.h:289
Definition: cs_param_sles.h:213
Definition: cs_range_set.h:57
Definition: cs_saddle_itsol.h:100
cs_real_t * schur_diag
Definition: cs_saddle_itsol.h:121
cs_real_t * m11_inv_diag
Definition: cs_saddle_itsol.h:126
Definition: cs_saddle_itsol.h:105
cs_sles_t * m11_sles
Definition: cs_saddle_itsol.h:110
cs_param_sles_t * m11_slesp
Definition: cs_saddle_itsol.h:109
Definition: cs_saddle_itsol.h:104
cs_matrix_t * schur_matrix
Definition: cs_saddle_itsol.h:114
cs_param_sles_t * schur_slesp
Definition: cs_saddle_itsol.h:115
double schur_scaling
Definition: cs_saddle_itsol.h:117
cs_sles_t * schur_sles
Definition: cs_saddle_itsol.h:116
cs_real_t * mass22_diag
Definition: cs_saddle_itsol.h:127
cs_real_t * schur_xtra
Definition: cs_saddle_itsol.h:122
Definition: cs_saddle_itsol.h:60
Definition: cs_saddle_itsol.h:75
cs_real_t * m21_unassembled
Definition: cs_saddle_itsol.h:83
cs_real_t * rhs1
Definition: cs_saddle_itsol.h:77
cs_real_t * rhs2
Definition: cs_saddle_itsol.h:81
const cs_range_set_t * rset
Definition: cs_saddle_itsol.h:94
int m21_stride
Definition: cs_saddle_itsol.h:84
cs_matrix_t ** m11_matrices
Definition: cs_saddle_itsol.h:73
cs_lnum_t x1_size
Definition: cs_saddle_itsol.h:74
const cs_adjacency_t * m21_adjacency
Definition: cs_saddle_itsol.h:88
cs_lnum_t x2_size
Definition: cs_saddle_itsol.h:79
int n_m11_matrices
Definition: cs_saddle_itsol.h:72
Definition: cs_saddle_itsol.h:80
