#include <ple_locator.h>#include "fvm_nodal.h"#include "cs_base.h"#include "cs_halo.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"
Include dependency graph for cs_porosity_from_scan.h:Go to the source code of this file.
| struct | cs_porosity_from_scan_opt_t |
| void | cs_porosity_from_scan_set_file_name (const char *file_name) |
| Set the file name of points for the computation of the porosity from scan. More... | |
| void | cs_porosity_from_scan_set_output_name (const char *output_name) |
| Set the output name for the FVM writer of scan points. More... | |
| void | cs_porosity_from_scan_add_source (const cs_real_t source[3], bool transform) |
| Add a scanner source point. More... | |
| void | cs_ibm_add_sources_by_file_name (const char *file_name) |
| Add the scanner sources from csv file to fill fluid space. More... | |
| void | cs_compute_porosity_from_scan (void) |
| Compute the porosity which is equal to one from a source, radiating sphericaly, and is 0 when touching points of the scan. More... | |
| cs_porosity_from_scan_opt_t * | cs_glob_porosity_from_scan_opt |
| void cs_compute_porosity_from_scan | ( | void | ) |
This function solves the following transport equation on
where
is the radial direction from the source
The boundary conditions on
is an homogeneous Neumann, and a penalisation term is impose in the cell of center
Remarks:
where
Remarks:
| void cs_ibm_add_sources_by_file_name | ( | const char * | file_name | ) |
| [in] | csv | file containing the (x,y,z) coordinates of each scanner |
| void cs_porosity_from_scan_add_source | ( | const cs_real_t | source[3], |
| bool | transform | ||
| [in] | source | source vector |
| [in] | transform | flag to apply the transformation matrix to the source |
| void cs_porosity_from_scan_set_file_name | ( | const char * | file_name | ) |
| [in] | file_name | name of the file. |
| void cs_porosity_from_scan_set_output_name | ( | const char * | output_name | ) |
| [in] | output_name | name of the output (a suffix will be added) |
extern |
