◆ cs_mobile_structures_add_n_structures()
| void cs_mobile_structures_add_n_structures |
int |
n_structures | ) |
Add internal mobile structures.
This function may be called multiple time to change the number of mobile structures.
- Parameters
| [in] | n_structures | number of internal mobile structures |
◆ cs_mobile_structures_displacement()
| void cs_mobile_structures_displacement |
int |
itrale, |
int |
italim, |
int * |
itrfin |
Displacement of mobile structures with ALE for internal coupling.
- Parameters
| [in] | itrale | ALE iteration number |
| [in] | italim | implicit coupling iteration number |
| [in,out] | itrfin | indicator for last iteration of implicit coupling |
◆ cs_mobile_structures_finalize()
| void cs_mobile_structures_finalize |
void |
Finalize mobile structures with ALE for internal coupling.
◆ cs_mobile_structures_get_n_structures()
| int cs_mobile_structures_get_n_structures |
void |
Query number of internal mobile structures defined.
- Returns
- number of internal mobile structures
◆ cs_mobile_structures_initialize()
| void cs_mobile_structures_initialize |
void |
Initialize mobile structures with ALE for internal coupling.
◆ cs_mobile_structures_log_setup()
| void cs_mobile_structures_log_setup |
void |
Log structures and coupling information.
◆ cs_mobile_structures_prediction()
| void cs_mobile_structures_prediction |
int |
itrale, |
int |
italim, |
int |
ineefl, |
int |
impale[] |
Predict displacement of mobile structures with ALE.
- Parameters
| [in] | ineefl | indicate whether fluxes should be saved |
| [out] | impale | imposed displacement indicator |
◆ cs_mobile_structures_restart_read()
Read mobile structures data to checkpoint.
- Parameters
| [in,out] | r | associated restart file pointer |
◆ cs_mobile_structures_restart_write()
Write mobile structures data to checkpoint.
- Parameters
◆ cs_mobile_structures_set_newmark_coefficients()
Set Newmark coefficients for internal mobile structures.
- Parameters
| [in] | alpha | alpha coefficient for Newmark algorithm |
| [in] | beta | beta coefficient for Newmark algorithm |
| [in] | gamma | gamma coefficient for Newmark algorithm |
◆ cs_mobile_structures_setup()
| void cs_mobile_structures_setup |
void |
◆ cs_glob_mobile_structures_i_eps
| double cs_glob_mobile_structures_i_eps |
extern |
Relative precision of implicitation of the structure displacement
◆ cs_glob_mobile_structures_i_max
| int cs_glob_mobile_structures_i_max |
extern |
maximum number of implicitation iterations of the structure displacement
