Include dependency graph for cs_gwf_param.h:Go to the source code of this file.
Macros | |
Flags specifying the kind of post-processing to perform in | |
the groundwater flow module | |
| #define | CS_GWF_POST_SOIL_CAPACITY (1 << 0) |
| Activate the post-processing of the soil capacity (property in front of the unsteady term in Richards equation) More... | |
| #define | CS_GWF_POST_LIQUID_SATURATION (1 << 1) |
| Activate the post-processing of the liquid saturation (also nammed "moisture content" in case of single phase flow) More... | |
| #define | CS_GWF_POST_PERMEABILITY (1 << 2) |
| Activate the post-processing of the permeability field. More... | |
| #define | CS_GWF_POST_DARCY_FLUX_BALANCE (1 << 3) |
| Compute the overall balance at the different boundaries of the Darcy flux. More... | |
| #define | CS_GWF_POST_DARCY_FLUX_DIVERGENCE (1 << 4) |
| Compute in each control volume (vertices or cells w.r.t the space scheme) the divergence of the Darcy flux. More... | |
| #define | CS_GWF_POST_DARCY_FLUX_AT_BOUNDARY (1 << 5) |
| Define a field at boundary faces for the Darcy flux and activate the post-processing. More... | |
| #define | CS_GWF_POST_GAS_MASS_DENSITY (1 << 6) |
| Compute the mass density of the gas component for a miscible or immiscible two-phase flow model. One recalls that one assumes that there is no water in the gas phase and that the mass density is a function of the gas pressure through a perfect gas law. More... | |
| #define | CS_GWF_POST_SOIL_STATE (1 << 7) |
| State of the soil among "saturated", "unsaturated", "dry". More... | |
| #define | CS_GWF_POST_SOIL_MINMAX (1 << 8) |
| Output the min./max. of all pressures and the liquid saturation in each soil for each time step. The output file is named 'gwf.log'. More... | |
Soil modelling | |
| enum | cs_gwf_soil_model_t { CS_GWF_SOIL_SATURATED , CS_GWF_SOIL_VGM_SINGLE_PHASE , CS_GWF_SOIL_VGM_TWO_PHASE , CS_GWF_SOIL_USER , CS_GWF_SOIL_N_HYDRAULIC_MODELS } |
| Predefined hydraulic model of soils used in the groundwater flow module. More... | |
Tracer modelling | |
| enum | cs_gwf_tracer_model_bit_t { CS_GWF_TRACER_USER = 1<< 0 , CS_GWF_TRACER_SORPTION_EK_3_PARAMETERS = 1<< 2 , CS_GWF_TRACER_SORPTION_EK_5_PARAMETERS = 1<< 3 , CS_GWF_TRACER_PRECIPITATION = 1<< 4 } |
| Flags specifying the general behavior of a tracer associated to the groundwater flow module. More... | |
| typedef cs_flag_t | cs_gwf_tracer_model_t |
| #define CS_GWF_POST_DARCY_FLUX_AT_BOUNDARY (1 << 5) |
| #define CS_GWF_POST_DARCY_FLUX_BALANCE (1 << 3) |
| #define CS_GWF_POST_DARCY_FLUX_DIVERGENCE (1 << 4) |
| #define CS_GWF_POST_GAS_MASS_DENSITY (1 << 6) |
| #define CS_GWF_POST_LIQUID_SATURATION (1 << 1) |
| #define CS_GWF_POST_PERMEABILITY (1 << 2) |
| #define CS_GWF_POST_SOIL_CAPACITY (1 << 0) |
| #define CS_GWF_POST_SOIL_MINMAX (1 << 8) |
| #define CS_GWF_POST_SOIL_STATE (1 << 7) |
| typedef cs_flag_t cs_gwf_tracer_model_t |
| enum cs_gwf_model_bit_t |
Additional modelling options either from the physical viewpoint or the numerical viewpoint.
| enum cs_gwf_model_type_t |
| Enumerator | |
| CS_GWF_MODEL_SATURATED_SINGLE_PHASE | Single phase (liquid phase) model in a saturated porous media. All soils are assumed to be saturated. This yields several simplifications in the Richards equation governing the water conservation. The Richards equation is steady. The saturation is constant and there is no relative permeability. |
| CS_GWF_MODEL_UNSATURATED_SINGLE_PHASE | Single phase (liquid phase) model in an unsaturated porous media. All soils are considered as unsaturated and are described by a more complex modelling such as the Van Genuchten-Mualem model. Simplifications made in the case of CS_GWF_MODEL_SATURATED_SINGLE_PHASE do not hold anymore. Richards equation is unsteady and there can be a non-linearity to handle according to the type of soil model. Soil properties such as permeability, soil capacity and liquid saturation (also called moisture content) are neither uniform nor steady. |
| CS_GWF_MODEL_MISCIBLE_TWO_PHASE | Miscible two phase flow modelling (gaseous and liquid phases) in porous media. A Richards-like equation is considered in each phase to take into account the mass conservation of water and one other component. The component can be disolved in the liquid phase. No water vapour is taken into account. Please refer to cs_gwf_tpf_t for more details. |
| CS_GWF_MODEL_IMMISCIBLE_TWO_PHASE | Immiscible two phase flow modelling (gaseous and liquid phases) in porous media. A Richards-like equation is considered in each phase to take into account the mass conservation of water in the liquid phase and the conservation of the other component in the gaseous phase. The model context is shared with the miscible two-phase flow model. Please refer to cs_gwf_tpf_t for more details. |
| CS_GWF_N_MODEL_TYPES | Number of predefined models (not a model) |
| enum cs_gwf_soil_model_t |
Elemental modelling choice either from the physical viewpoint or the numerical viewpoint for the transport of a tracer
| enum cs_gwf_tracer_unit_t |
