#include "cs_boundary.h"
#include "cs_zone.h"
◆ cs_gui_boundary_add_meg_context()
Add new MEG-based cs_dof_func_t context info.
- Parameters
| [in] | zone | pointer to associated zone |
| [in] | name | name of associated field or array |
| [in] | condition | associated condition type |
| [in] | dim | associated dimension |
- Returns
- : pointer to cs_dof_func_t context info
◆ cs_gui_boundary_conditions_define()
Define boundary conditions based on setup file.
- Parameters
| [in,out] | bdy | boundaries structure to update (if NULL, default to cs_glob_domain->boundaries) |
◆ cs_gui_boundary_conditions_dof_func_meg()
| void cs_gui_boundary_conditions_dof_func_meg |
cs_lnum_t |
n_elts, |
const cs_lnum_t * |
elt_ids, |
bool |
dense_output, |
void * |
input, |
cs_real_t * |
retval |
cs_dof_func_t function to compute a boundary profiles using a MEG generated function.
For the calling function, elt_ids is optional. If not NULL, array(s) should be accessed with an indirection. The same indirection can be applied to fill retval if dense_output is set to false. In the current case, retval is allocated to mesh->n_b_faces
- Parameters
| [in,out] | retval | resulting value(s). Must be allocated. |
- Parameters
◆ cs_gui_boundary_conditions_free_memory()
| void cs_gui_boundary_conditions_free_memory |
void |
Free GUI boundary condition structures.
◆ cs_gui_boundary_conditions_processing()
| void cs_gui_boundary_conditions_processing |
int * |
itypfb | ) |
◆ cs_gui_boundary_conditions_verify()
| void cs_gui_boundary_conditions_verify |
void |
