393 const char *property_name,
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:514
Definition: cs_defs.h:319
#define CS_PROCF(x, y)
Definition: cs_defs.h:528
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:334
Definition: cs_defs.h:515
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:343
@ vel
void cs_gui_porous_model(void)
Definition: cs_gui.c:4259
cs_equation_param_t * cs_gui_get_equation_param(const char *name)
Definition: cs_gui.c:2403
void cs_gui_initial_conditions(void)
Apply initial conditions based on GUI-defined settings.
Definition: cs_gui.c:2901
void uiporo(void)
Definition: cs_gui.c:1993
void cs_gui_equation_parameters(void)
Definition: cs_gui.c:2281
void cs_gui_time_tables(void)
Read GUI defined time tables.
Definition: cs_gui.c:5603
void cs_gui_pressure_drop_by_zone(void)
Definition: cs_gui.c:5169
void cs_gui_checkpoint_parameters(void)
Read GUi-defined Checkpoint parameters.
Definition: cs_gui.c:2245
void cs_gui_parallel_io(void)
Definition: cs_gui.c:3874
void cs_gui_finalize(void)
Definition: cs_gui.c:2380
void uiexop(void)
Definition: cs_gui.c:2228
void cs_gui_internal_coupling(void)
Definition: cs_gui.c:5309
void cs_gui_properties_value(const char *property_name, double *value)
Definition: cs_gui.c:4295
void cscpva(void)
Definition: cs_gui.c:1717
void cs_gui_turb_model(void)
Definition: cs_gui.c:4713
void csiphy(void)
Definition: cs_gui.c:1861
void cstime(void)
Definition: cs_gui.c:1913
void cs_gui_time_moments(void)
Definition: cs_gui.c:4507
void csnum2(double *relaxp, int *imrgra)
void cs_gui_properties_value_by_fluid_id(const int fluid_id, const char *property_name, double *value)
Definition: cs_gui.c:4321
void uiphyv(const int *iviscv)
Definition: cs_gui.c:2075
void cs_gui_physical_properties(void)
Definition: cs_gui.c:4101
void cs_gui_user_variables(void)
Definition: cs_gui.c:4892
void cs_gui_scalar_source_terms(cs_field_t *f, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
Definition: cs_gui.c:5439
void cscfgp(int *icfgrp)
Definition: cs_gui.c:1889
void cs_gui_linear_solvers(void)
Definition: cs_gui.c:3466
void cs_gui_scalar_model_settings(void)
Definition: cs_gui.c:4356
void cs_gui_fluid_properties_value(const char *param, double *value)
Definition: cs_gui.c:2426
void csidtv(void)
Definition: cs_gui.c:1837
void cs_gui_turbomachinery(void)
Definition: cs_gui.c:4607
void cs_gui_numerical_options(void)
Definition: cs_gui.c:3749
void cs_gui_user_arrays(void)
Definition: cs_gui.c:4952
int cs_gui_thermal_model_code(void)
Definition: cs_gui.c:4470
void cs_gui_thermal_source_terms(cs_field_t *f, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
Definition: cs_gui.c:5523
void cs_gui_zones(void)
Definition: cs_gui.c:4995
void cs_gui_define_fans(void)
Definition: cs_gui.c:5191
void csvvva(int *iviscv)
Definition: cs_gui.c:1742
void cs_gui_balance_by_zone(void)
Definition: cs_gui.c:5140
void cs_gui_error_estimator(void)
Definition: cs_gui.c:5257
void cs_gui_usage_log(void)
Definition: cs_gui.c:4864
void csivis(void)
Definition: cs_gui.c:1764
const cs_gui_volume_meg_context_t * cs_gui_add_volume_meg_context(const cs_zone_t *zone, const cs_field_t *fields[], const int n_fields)
Add new volume MEG function context info.
Definition: cs_gui.c:5394
void cs_gui_turb_ref_values(void)
Definition: cs_gui.c:4825
void cs_gui_turbomachinery_rotor(void)
Definition: cs_gui.c:4622
void cs_gui_partition(void)
Definition: cs_gui.c:3941
void cs_gui_momentum_source_terms(const cs_real_3_t *restrict vel, cs_real_3_t *restrict tsexp, cs_real_33_t *restrict tsimp)
Definition: cs_gui.c:3638
void cs_gui_head_losses(const cs_zone_t *zone, const cs_real_3_t *cvara_vel, cs_real_t cku[][6])
Compute GUI-defined head losses for a given volume zone.
Definition: cs_gui.c:2830
void cs_gui_mpi_algorithms(void)
Definition: cs_gui.c:4037
void cs_gui_physical_constants(void)
Definition: cs_gui.c:4062
void cs_gui_thermal_model(void)
Definition: cs_gui.c:4426
void cs_gui_groundwater_property_laws(int permeability, int diffusion, int unsaturated)
Definition: cs_gui.c:2446
integer, save icfgrp
indicates if the boundary conditions should take into account (=1) or not (=0) the hydrostatic balanc...
Definition: ppincl.f90:659
integer, save iviscv
additional property:
Definition: ppincl.f90:599
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:137
Definition: cs_field.h:131
const cs_zone_t * zone
Definition: cs_gui.h:51
const cs_field_t ** fields
Definition: cs_gui.h:52
