| int | cs_gas_mix_get_field_key (void) |
| | Get the field key for gas mix properties. More...
| void | cs_gas_mix_add_species (int f_id) |
| | Add a species field to the gas mix (set of fields). More...
| void | cs_gas_mix_add_species_with_properties (int f_id, cs_real_t mol_mass, cs_real_t cp, cs_real_t vol_diff, cs_real_t mu_a, cs_real_t mu_b, cs_real_t lambda_a, cs_real_t lambda_b, cs_real_t mu_ref, cs_real_t lambda_ref, cs_real_t tref_mu, cs_real_t tref_lambda, cs_real_t s_mu, cs_real_t s_lambda) |
| void | cs_gas_mix_add_property_fields (void) |
| | Add property fields specific to a gas mix. More...
| void | cs_gas_mix_finalize (void) |
| | Free array mapping gas mix species ids to field ids. More...
◆ cs_gas_mix_type_t
| Enumerator |
| CS_GAS_MIX_OFF | gas mix model off
| CS_GAS_MIX_AIR_HELIUM | air/helium, helium deduced
| CS_GAS_MIX_AIR_HYDROGEN | air/hydrogen, hydrogen deduced
| CS_GAS_MIX_AIR_STEAM | air/steam, steam deduced
| CS_GAS_MIX_AIR_HELIUM_STEAM | helium/steam, steam deduced
| CS_GAS_MIX_AIR_HYDROGEN_STEAM | hydrogen/steam, steam deduced
| CS_GAS_MIX_HELIUM_AIR | helium/air, O2 from air deduced
| CS_GAS_MIX_USER | user defined
◆ cs_gas_mix_add_property_fields()
| void cs_gas_mix_add_property_fields |
void |
◆ cs_gas_mix_add_species()
| void cs_gas_mix_add_species |
int |
f_id | ) |
- Parameters
| [in] | f_id | field id of an already created scalar model field |
◆ cs_gas_mix_add_species_with_properties()
| void cs_gas_mix_add_species_with_properties |
int |
f_id, |
cs_real_t |
mol_mass, |
cs_real_t |
cp, |
cs_real_t |
vol_diff, |
cs_real_t |
mu_a, |
cs_real_t |
mu_b, |
cs_real_t |
lambda_a, |
cs_real_t |
lambda_b, |
cs_real_t |
mu_ref, |
cs_real_t |
lambda_ref, |
cs_real_t |
tref_mu, |
cs_real_t |
tref_lambda, |
cs_real_t |
s_mu, |
cs_real_t |
s_lambda |
- Parameters
| [in] | f_id | id of field representing species mixture fraction. |
| [in] | mol_mass | molar mass |
| [in] | cp | specific heat |
| [in] | col_diff | volume diffusion |
| [in] | mu_a | dynamic viscosity a |
| [in] | mu_b | dynamic viscosity b |
| [in] | lambda_a | thermal conductivity a |
| [in] | lambda_b | thermal conductivity b |
| [in] | mu_ref | reference viscosity (Sutherland) |
| [in] | lambda_ref | reference conductivity (Sutherland) |
| [in] | tref_mu | reference temperature for viscosity |
| [in] | tref_lambda | reference temperature for conductivity |
| [in] | s_mu | Sutherland temperature for viscosity |
| [in] | s_lambda | Sutherland temperature for conductivity |
◆ cs_gas_mix_finalize()
| void cs_gas_mix_finalize |
void |
◆ cs_gas_mix_get_field_key()
| int cs_gas_mix_get_field_key |
void |
- Returns
- field key id for gas mix properties
◆ cs_glob_gas_mix
