#include "cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <mpi.h>#include <ple_locator.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_log.h"#include "cs_map.h"#include "cs_mesh.h"#include "cs_mesh_location.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_post.h"#include "cs_flag_check.h"
Include dependency graph for cs_flag_check.c:Functions | |
| int | cs_flag_check (const char *err_elt_descr, const char *flag_descr, const char *flag_label, const char *error_mesh_name, const char *valid_mesh_name, int location_id, int min_flag, const int elt_flag[]) |
| Check for and handle errors with an associated element flag. More... | |
| void | cs_flag_check_error_info (const char *err_elt_descr, const char *flag_descr, const char *flag_label, const char *error_mesh_name, const char *valid_mesh_name, int location_id, int min_flag, const int elt_flag[]) |
| Handle an error with an associated element flag. More... | |
Mesh element flag checking and error handling..
| int cs_flag_check | ( | const char * | err_elt_descr, |
| const char * | flag_descr, | ||
| const char * | flag_label, | ||
| const char * | error_mesh_name, | ||
| const char * | valid_mesh_name, | ||
| int | location_id, | ||
| int | min_flag, | ||
| const int | elt_flag[] | ||
It is assumed that element flags are usually positive integers, and that in case of a detected error, their signs have been set to a negative value.
A minimum allowed value may be specified, so for example 0 may be considered a valid or invalid flag depending on that minimum.
This function exits silently if no such marked elements are present in the computational domain.
Otherwise, it logs information on the first detected error location, and outputs postprocessing visualization information to assist debugging.
If the error status (i.e. negative flag) is known locally but not globally, use cs_flag_check.
Currently supported locations are CS_MESH_LOCATION_CELLS and CS_MESH_LOCATION_BOUNDARY_FACES.
| [in] | err_elt_descr | description for the first element with error |
| [in] | flag_descr | flag type description |
| [in] | flag_label | field label for flag postprocessing |
| [in] | error_mesh_name | postprocessing mesh name for elements with error |
| [in] | valid_mesh_name | postprocessing mesh name for valid elements |
| [in] | location_id | associated mesh location |
| [in] | min_flag | minimum allowed flag |
| [in] | elt_flag | current element flag |
| void cs_flag_check_error_info | ( | const char * | err_elt_descr, |
This function logs information on the first detected error location, and outputs postprocessing visualization information to assist debugging.
This function should be called when the error status has been previously checked, and all ranks know that an error is present.
