◆ cs_atmo_aerosol_finalize()
| void cs_atmo_aerosol_finalize |
void |
This function finalizes the external aerosol code.
◆ cs_atmo_aerosol_get_aero()
| void cs_atmo_aerosol_get_aero |
cs_real_t * |
array | ) |
This function fills the given array with aerosol concentrations and numbers from the external aerosol code..
- Parameters
| [out] | array | aerosol concentrations and numbers |
- Parameters
◆ cs_atmo_aerosol_get_gas()
| void cs_atmo_aerosol_get_gas |
cs_real_t * |
array | ) |
This function fills the given array with gas concentrations from the external aerosol code.
- Parameters
| [out] | array | gas concentrations |
◆ cs_atmo_aerosol_initialize()
| void cs_atmo_aerosol_initialize |
void |
This function initializes the external aerosol code.
◆ cs_atmo_aerosol_nuclea()
Compute aerosol cloud droplets nucleation when using the atmospheric humid model using a microphysical model.
It is taken into account as an additional step split from advection-diffusion equation, hence the droplet number is first clipped if necessary.
- Parameters
| [out] | nc | droplet number (scalar) in 1/cm**3 |
| [in] | rom | density of air in kg/m**3 |
| [in] | qldia | mass fraction of liquid water in kg/kg |
| [in] | pphy | true pressure in pascals |
| [in] | refrad | radiative cooling |
◆ cs_atmo_aerosol_time_advance()
| void cs_atmo_aerosol_time_advance |
void |
This function computes a time step of gaseous chemistry and aerosols dynamic using the external aerosol code.
