Local variables to be added for the Fortran examples
integer ifac, ii
integer izone
integer ilelt, nlelt
integer f_id_rough, f_id_t_rough
double precision d2s3
double precision zref, xuref
double precision ustar, rugd, rugt
double precision zent, xuent, xvent
double precision xkent, xeent
integer, pointer, dimension(:,:) :: icodcl
double precision, pointer, dimension(:,:,:) :: rcodcl
integer, allocatable, dimension(:) :: lstelt
double precision, dimension(:), pointer :: bpro_roughness
double precision, dimension(:), pointer :: bpro_roughness_t
Example 1 (Fortran)
For boundary faces of color 11, assign an inlet boundary condition prescribed from the meteo profile with automatic choice between inlet/ outlet according to the meteo profile.
call getfbr(
'11',nlelt,lstelt)
izone = maxval(izfppp) + 1
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
izfppp(ifac) = izone
iprofm(izone) = 1
itypfb(ifac) = ientre
iautom(ifac) = 1
enddo
subroutine getfbr(fstr, facnb, faces)
Build the list of boundary faces matching a criteria string.
Definition: cs_selector_f2c.f90:111
Example 2 (Fortran)
For boundary faces of color 21, assign an inlet boundary condition prescribed from the meteo profile.
call getfbr(
'21',nlelt,lstelt)
do ilelt = 1, nlelt
iprofm(izone) = 1
enddo
Example 3
For boundary faces of zone "inlet_3", assign an inlet boundary condition. Here, all other variables prescribed from the meteo profile are assumed to be managed by the GUI, except for dynamic variables which are prescribed with a rough log law.
const cs_lnum_t n_b_faces = domain->mesh->n_b_faces;
for (
cs_lnum_t e_idx = 0; e_idx < zn->n_elts; e_idx++) {
const cs_real_t zent = b_face_cog[face_id][2];
CS_F_(
k)->bc_coeffs->rcodcl1[face_id] = xkent;
CS_F_(
eps)->bc_coeffs->rcodcl1[face_id] = xeent;
for (int ii = 0; ii< 3; ii++)
CS_F_(
rij)->bc_coeffs->rcodcl1[n_b_faces*ii + face_id] = d2o3*xkent;
for (int ii = 3; ii< 6; ii++)
CS_F_(
rij)->bc_coeffs->rcodcl1[n_b_faces*ii + face_id] = 0;
CS_F_(
CS_F_(
CS_F_(
CS_F_(
phi)->bc_coeffs->rcodcl1[face_id] = d2o3;
CS_F_(
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:319
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:334
Definition: cs_defs.h:313
@ nusa
Definition: cs_field_pointer.h:81
@ k
@ eps
Definition: cs_field_pointer.h:71
@ omg
Definition: cs_field_pointer.h:80
@ rij
Definition: cs_field_pointer.h:73
@ phi
Definition: cs_field_pointer.h:75
@ f_bar
Definition: cs_field_pointer.h:76
#define CS_F_(e)
static cs_real_t cs_math_pow2(cs_real_t x)
Definition: cs_math.h:238
static cs_real_t cs_math_pow3(cs_real_t x)
Compute the cube of a real value.
Definition: cs_math.h:254
@ CS_INLET
Definition: cs_parameters.h:83
double cs_turb_cmu
Definition: cs_turbulence_model.c:503
double cs_turb_xkappa
Definition: cs_turbulence_model.c:444
const cs_turb_model_t * cs_glob_turb_model
@ CS_TURB_SPALART_ALLMARAS
Definition: cs_turbulence_model.h:69
@ CS_TURB_V2F_PHI
Definition: cs_turbulence_model.h:66
@ CS_TURB_K_OMEGA
Definition: cs_turbulence_model.h:68
int iturb
Definition: cs_turbulence_model.h:117
int itytur
Definition: cs_turbulence_model.h:139
const cs_lnum_t * elt_ids
Definition: cs_zone.h:65
Example 4
Define a rough wall at boundary faces of zone 'b_5'.
if (bpro_roughness != NULL)
bpro_roughness[face_id] = rugd;
if (bpro_roughness_t != NULL)
bpro_roughness_t[face_id] = 0.01;
Return a pointer to a field based on its name if present.
Definition: cs_field.c:2370
@ CS_ROUGHWALL
Definition: cs_parameters.h:88
cs_real_t * val
Definition: cs_field.h:152
cs_lnum_t n_elts
Definition: cs_zone.h:64
