if (domain->time_step->nt_prev > 0)
return;
const cs_real_t n_cells = domain->mesh->n_cells;
coefe[ige] = 0.;
const int ioxy = 0;
void cs_array_real_set_scalar(cs_lnum_t n_elts, cs_real_t ref_val, cs_real_t a[restrict])
Assign a constant scalar value to an array.
Definition: cs_array.c:550
cs_combustion_model_t * cs_glob_combustion_model
Definition: cs_combustion_model.c:117
#define CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES
Definition: cs_combustion_model.h:52
Definition: cs_defs.h:319
@ h
Definition: cs_field_pointer.h:91
@ yco2
Definition: cs_field_pointer.h:153
#define CS_F_(e)
const double cs_physical_constants_celsius_to_kelvin
Definition: cs_physical_constants.c:388
cs_real_t cs_fuel_t2h_gas(cs_real_t xesp[], cs_real_t tp)
Calculation of the gas enthalpy from temperature and concentrations for fuel combustion.
real(c_double), dimension(:), pointer, save wmole
molar mass of an elementary gas component
Definition: ppthch.f90:134
double precision trefth
reference temperature for the specific physics, in K
Definition: ppthch.f90:44
integer(c_int), pointer, save ico2
Definition: cpincl.f90:231
integer(c_int), pointer, save in2
integer(c_int), pointer, save ih2o
integer(c_int), pointer, save io2
real(c_double), dimension(:), pointer, save oxyco2
Definition: ppcpfu.f90:180
real(c_double), dimension(:), pointer, save oxyn2
real(c_double), dimension(:), pointer, save oxyo2
real(c_double), dimension(:), pointer, save oxyh2o
double cp2fol
Definition: cs_combustion_model.h:152
double h02fol
Definition: cs_combustion_model.h:151
Definition: cs_combustion_model.h:159
int ico2
Definition: cs_combustion_model.h:176
int in2
Definition: cs_combustion_model.h:175
int ih2o
Definition: cs_combustion_model.h:177
double wmole[CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS]
Definition: cs_combustion_model.h:186
double oxyo2[CS_COMBUSTION_MAX_OXYDANTS]
Definition: cs_combustion_model.h:189
double oxyh2o[CS_COMBUSTION_MAX_OXYDANTS]
Definition: cs_combustion_model.h:195
cs_combustion_fuel_model_t fuel
Definition: cs_combustion_model.h:163
double oxyco2[CS_COMBUSTION_MAX_OXYDANTS]
Definition: cs_combustion_model.h:198
int io2
Definition: cs_combustion_model.h:174
double oxyn2[CS_COMBUSTION_MAX_OXYDANTS]
Definition: cs_combustion_model.h:192
