#include <cs_stl.h>
Collaboration diagram for cs_stl_mesh_t:Data Fields | |
| char | name [20] |
| char | header [80] |
| cs_lnum_t | n_faces |
| cs_real_3_t * | coords |
| cs_real_3_t * | coords_ini |
| int | n_seeds |
| cs_real_t * | seed_coords |
| bool | is_porous |
| fvm_nodal_t * | ext_mesh |
| cs_real_3_t* coords |
Array of face vertex coordinates coord[n_vertices][3]
| cs_real_3_t* coords_ini |
Array of face vertex coordinates at init coord_ini[n_vertices][3]
| fvm_nodal_t* ext_mesh |
Associated external mesh
| char header[80] |
Header of the STL file
| bool is_porous |
If true the STL is used for porosity computation. (Default : False)
| cs_lnum_t n_faces |
Number of triangles
| int n_seeds |
Number of prescribed points outside the STL
| char name[20] |
Name identifier of the STL file
| cs_real_t* seed_coords |
Coordinates of the reference seed points seed_coords[n_seed][3]
