8.0
cs_gwf_saturated_single_phase_t Struct Reference
Structure to handle the modelling of a single-phase flows in a porous media considered as saturated. More...
#include <cs_gwf_priv.h>
+ Collaboration diagram for cs_gwf_saturated_single_phase_t:
Data Fields
Equation
cs_equation_trichards
Darcy (advection) field
cs_gwf_darcy_flux_tdarcy
Properties related to the model
cs_property_tmoisture_content
Additional fields/arrays
cs_field_tpermeability_field
cs_field_tpressure_head
Several simplifications are operated in this context. Only the liquid phase is taken into account.
Field Documentation
◆ darcy
darcy
Pointer to a cs_gwf_darcy_flux_t structure. Darcy advective flux in the liquid phase. This structure is used to define the advective term in tracer equations.
◆ moisture_content
moisture_content
This quantity describes the level of saturation in a soil. This is a constant value in case of a satured soil and variable one in case of a unsaturated soil.
◆ permeability_field
permeability_field
Pointer to a cs_field_t structure. May be not allocated according to the postprocessing options. Store the value of the absolute permeability field in each cell
◆ pressure_head
pressure_head
Pointer to a cs_field_t structure. Allocated only if the gravitation effect is active. Location of this field depends on the discretization scheme used to solve the Richards equation. The pressure head is denoted by h, hydraulic head (unknowns solved in the Richards eq.) is denoted by H and there are linked by: h = H - gravity_potential
◆ richards
richards
The Richards equation is the governing equation which corresponds to the mass conservation of water. "hydraulic_head" is the associated variable "permeability" is the diffusion property related to this equation.
