#include <cs_equation_priv.h>
Collaboration diagram for cs_equation_t:| apply_stiffness |
Pointer of function given by the prototype cs_equation_apply_sitffness_t
| boundary_flux_id |
Id to the field storing the boundary flux asociated to variable field
| cs_equation_build_system_t* build_system |
| builder |
Common members for building the algebraic system between the numerical schemes
| compute_balance |
Pointer of function given by the prototype cs_equation_get_balance_t
| current_to_previous |
Pointer of function given by the prototype cs_equation_extra_op_t
| field_id |
Id of the variable field related to this equation (cf. cs_field_t)
| free_context |
Pointer of function given by the prototype cs_equation_free_context_t
| get_cell_values |
Pointer of function given by the prototype cs_equation_get_values_t
| get_cw_build_structures |
Retrieve local structures used to build the algebraic system. Pointer of function given by the prototype cs_equation_get_builders_t
| get_edge_values |
| get_face_values |
| get_vertex_values |
| int id |
Id of the current equation
| init_context |
Pointer of function given by the prototype cs_equation_init_context_t
| init_field_values |
Pointer of function given by the prototype cs_equation_init_values_t
| int main_ts_id |
Id of the main timer stats for this equation
| param |
Set of parameters related to an equation
| postprocess |
Additional predefined post-processing. Pointer of function given by the prototype cs_equation_extra_op_t
| cs_equation_prepare_solve_t* prepare_solving |
| read_restart |
Pointer of function given by the prototype cs_equation_restart_t
| scheme_context |
Data depending on the numerical scheme (cast on-the-fly)
| cs_equation_set_dir_bc_t* set_dir_bc |
| solve |
Pointer to a function given by the generic prototype cs_equation_solve_t Case of an unsteady solution
| solve_steady_state |
Case of steady-state solution. Pointer of function given by the prototype cs_equation_solve_t
| cs_equation_update_field_t* update_field |
| varname |
Name of the field of type variable associated to this equation
| write_restart |
