8.0
ppphyv.f90 File Reference
These subroutineS fill physical properties which are variable in time for the dedicated physics modules (BEFORE and AFTER the user surbroutines). More...
Functions/Subroutines
subroutine cs_physical_properties1 (mbrom)
subroutine cs_physical_properties2
Warning
  • it is forbidden to modify the turbulent viscosity here.
  • icp must be set to 1 if one wants the specific heat to be variable in space
  • it is necessary to call field_set_key_int(ivarfl(isca(iscal)), kivisl, 0) if one wants the specific heat to be variable in space
Remarks
  • this routine is called at the begining of each time step, thus, at the first time step, the only initialized variables are:
    • in usipsu.f90:
      • the density (set at ro0)
      • the molecular viscosity (set to viscl0)
    • in usppiv.f90:
      • the variables (0 by default)
Here can be given:
  • the cell density in kg/m3 (and eventually the boundary density)
  • the dynamic molecular viscosity in kg/(m s)
  • the specific heat Cp in J/(kg degres)
  • scalars diffusivities in kg/(m s)
◆ cs_physical_properties1()
subroutine cs_physical_properties1 ( integer  mbrom)
[in]mbromindicator of prescribed density at the boundary
◆ cs_physical_properties2()
