8.0
parall.f90 File Reference
Module for basic MPI and OpenMP parallelism-related values. More...
Data Types
interface  parcmx
 Compute the global maximum of an integer in case of parellism. More...
interface  parmax
 Compute the global maximum of a real number in case of parellism. More...
interface  parcmn
 Compute the global minimum of an integer in case of parellism. More...
interface  parmin
 Compute the global minimum of a real number in case of parellism. More...
interface  parcpt
 Compute the global sum of an integer in case of parellism. More...
interface  parsom
 Compute the global sum of a real number in case of parellism. More...
interface  parimx
 Compute the global maxima of an array of integers in case of parellism. More...
interface  parrmx
 Compute the global maxima of an array of real numbers in case of parellism. More...
interface  parimn
 Compute the global minima of an array of integers in case of parellism. More...
interface  parrmn
 Compute the global minima of an array of real numbers in case of parellism. More...
interface  parism
 Compute the global sums of an array of integers in case of parellism. More...
interface  parrsm
 Compute the global sums of an array of real numbers in case of parellism. More...
interface  parall_bcast_i
 Broadcast an integer in case of parellism. More...
interface  parall_bcast_r
 Broadcast a real number in case of parellism. More...
interface  parbci
 Broadcast an array of integers in case of parellism. More...
interface  parbcr
 Broadcast an array of real numbers in case of parellism. More...
interface  parmxl
 Maximum value of a real and the value of related array on all default communicator processes. More...
interface  parmnl
 Minimum value of a real and the value of related array on all default communicator processes. More...
interface  parfpt
 Given an (id, rank, value) tuple, return the local id, rank, and value corresponding to the global minimum value. More...
interface  cs_parall_allgather_r
 Build a global array from each local array in each domain. More...
interface  parbar
 Set a barrier on all default communicator processes. More...
Modules
module  parall
Functions/Subroutines
subroutine paragv (n_elts, n_g_elts, array, g_array)
integer thr_n_min
 thr_n_min : minimum number of elements for loops on threads More...
integer, save irangp = -1
 process rank More...
integer, save nrangp = 1
 number of processes (=1 if sequental) More...
integer(kind=8), save ncelgb = 0
 global number of cells More...
integer(kind=8), save nfacgb = 0
 global number of interior faces More...
integer(kind=8), save nfbrgb = 0
 global number of boundary faces More...
integer(kind=8), save nsomgb = 0
 global number of vertices More...
