| integer(c_int), pointer, save | znmurx |
| | Maximal number of discretized points associated to the (ii)th face with the 1-D thermal model coupled with condensation More...
| integer, dimension(:), pointer, save | znmur |
| double precision, dimension(:,:), pointer, save | zdxp |
| | space step associated to the spatial discretization of the 1-D thermal model coupled with condensation model More...
| double precision, dimension(:), pointer, save | ztheta |
| | of the 1-D thermal model More...
| double precision, dimension(:), pointer, save | zdxmin |
| | the minimal space step of 1-D thermal model by default equal to 0 with a homogeneus space step. this numerical parameter is used to impose a geometric progression ratio of the mesh refinement associated to (ii)th face with the 1-D thermal model. More...
| double precision, dimension(:), pointer, save | zepais |
| | the wall thickness associated to the (ii)th face with 1-D thermal module More...
| double precision, dimension(:), pointer, save | zrob |
| | the concrete density associated to solid material More...
| double precision, dimension(:), pointer, save | zcondb |
| | the concrete conductivity coefficient associated to solid material More...
| double precision, dimension(:), pointer, save | zcpb |
| | the concrete specific heat coefficient associated to solid material More...
| double precision, dimension(:), pointer, save | zhext |
| | the exterior exchange coefficient associated to solid material More...
| double precision, dimension(:), pointer, save | ztext |
| | the exterior temperature associated to solid material More...
| double precision, dimension(:), pointer, save | ztpar0 |
| | the initial temperature associated to solid material More...
| double precision, dimension(:,:), pointer, save | ztmur |
| | the wall temperature computed with the 1-D thermal model associated to concrete solid material More...
