| integer(c_int), pointer, save | iilagr |
| | activates (>0) or deactivates (=0) the Lagrangian module the different values correspond to the following modellings: More...
| integer(c_int), pointer, save | ntersl |
| | More...
| double precision, dimension(:,:), pointer, save | ptsvar |
| | More...
| integer(c_int), pointer, save | idepst |
| integer(c_int), pointer, save | iflow |
| integer(c_int), pointer, save | ipreci |
| integer(c_int), pointer, save | ltsdyn |
| | activation (=1) or not (=0) of the two-way coupling on the dynamics of the continuous phase. Useful if iilagr = 2 and iccvfg = 0 More...
| integer(c_int), pointer, save | ltsmas |
| | activation (=1) or not (=0) of the two-way coupling on the mass. Useful if iilagr = 2, cs_lagr_model_t::physical_model = 1 and cs_lagr_specific_physics_t::impvar = 1 More...
| integer(c_int), pointer, save | ltsthe |
| | if cs_lagr_model_t::physical_model = 1 and cs_lagr_specific_physics_t::itpvar = 1, ltsthe !> activates (=1) or not (=0) the two-way coupling on temperature. if cs_lagr_model_t::physical_model = 2, ltsthe activates (=1) or not (=0) the two-way coupling on the eulerian variables related to pulverized coal combustion. Useful if iilagr = 2 More...
| integer(c_int), pointer, save | itsli |
| | implicit source term for the continuous phase velocity and for the turbulent energy if the model is used More...
| integer(c_int), pointer, save | itske |
| | explicit source term for the turbulent dissipation and the turbulent energy if the turbulence model is used for the continuous phase More...
| integer(c_int), pointer, save | itste |
| | explicit thermal source term for the thermal scalar of the continuous phase More...
| integer(c_int), pointer, save | itsti |
| | implicit thermal source term for the thermal scalar of the continuous phase More...
| integer(c_int), pointer, save | itsmas |
| | mass source term More...
| integer(c_int), dimension(:), pointer, save | itsmv1 |
| | source term for the light volatile matters More...
| integer(c_int), dimension(:), pointer, save | itsmv2 |
| | source term for the heavy volatile matters More...
| integer(c_int), pointer, save | itsco |
| | source term for the carbon released during heterogeneous combustion More...
Module for Lagrangian model.
