8.0
+ Collaboration diagram for Time stepping:
integer(c_int), pointer, save ischtp
 Time order of time stepping (see cs_time_scheme_t::time_order). More...
integer(c_int), pointer, save istmpf
 Time order of the mass flux scheme. (see cs_time_scheme_t::istmpf). More...
integer(c_int), pointer, save nterup
 number of iterations on the velocity-pressure coupling on Navier-Stokes (for the U/P inner iterations scheme) More...
integer(c_int), pointer, save isno2t
 Time scheme for source terms of momentum equations (see cs_time_scheme_t::isno2t). More...
integer(c_int), pointer, save isto2t
 Time scheme for source terms of turbulence equations (see cs_time_scheme_t::isto2t). More...
integer, save initvi = 0
 initvi : =1 if total viscosity read from checkpoint file More...
integer, save initro = 0
 initro : =1 if density read from checkpoint file More...
integer, save initcp = 0
 initcp : =1 if specific heat read from checkpoint file More...
real(c_double), pointer, save thetsn
 Value of $theta_S$ (see cs_time_scheme_t::thetsn). More...
real(c_double), pointer, save thetst
 Value of $theta$ (see cs_time_scheme_t::thetst). More...
real(c_double), pointer, save thetvi
 Value of $theta$ for total viscoity (see cs_time_scheme_t::thetvi). More...
real(c_double), pointer, save thetcp
 Value of $theta$ for specific heat (see cs_time_scheme_t::thetcp). More...
real(c_double), pointer, save epsup
 relative precision for the convergence test of the iterative process on velocity-pressure coupling (inner iterations) More...
real(c_double), pointer, save xnrmu
 norm of the increment $ \vect{u}^{k+1} - \vect{u}^k $ of the iterative process on velocity-pressure coupling (inner iterations) More...
real(c_double), pointer, save xnrmu0
 norm of $ \vect{u}^0 $ (used by velocity-pressure inner iterations) More...
◆ epsup
◆ initcp
◆ initro
◆ initvi
◆ ischtp
◆ isno2t
◆ istmpf
◆ isto2t
◆ nterup
◆ thetcp
◆ thetsn
◆ thetst
◆ thetvi
◆ xnrmu
◆ xnrmu0
