| integer, save | irom = -1 |
| | Density at the current time step (equal to icrom, kept for compatibility) More...
| integer, save | iviscl = -1 |
| | dynamic molecular viscosity (in kg/(m.s)) More...
| integer, save | ivisct = -1 |
| | dynamic turbulent viscosity More...
| integer, dimension(nestmx), save | iestim |
| | error estimator for Navier-Stokes More...
| integer, save | kimasf = -1 |
| | interior and boundary convective mass flux key ids of the variables More...
| integer, save | kbmasf = -1 |
| integer, save | kvisl0 = -1 |
| | constant diffusivity field id key for scalars More...
| integer, save | kivisl = -1 |
| | variable diffusivity field id key for scalars More...
| integer, save | kscacp = -1 |
| | do scalars behave as a temperature (regarding multiplication by Cp) ? More...
| integer, save | kromsl = -1 |
| | variable density field id key for scalars More...
| integer, save | kstprv = -1 |
| | source terms at previous time step for 2nd order More...
| integer, save | kst = -1 |
| | source terms at the current time step (used for limiters) More...
| integer, save | ksigmas = -1 |
| | turbulent schmidt key for scalars More...
| integer, save | kctheta = -1 |
| | turbulent flow models GGDH and AFM key for scalar More...
| integer, dimension(nvarmx), save | ifluaa |
| | convective mass flux of the variables at the previous time-step More...
| integer, save | icrom = -1 |
| | cell density field ids of the variables More...
| integer, save | ibrom = -1 |
| | boundary density field ids of the variables More...
| integer, save | ipori = -1 |
| | field ids of the cell porosity More...
| integer, save | iporf = -1 |
| integer, save | ismago = -1 |
| | dynamic constant of Smagorinsky More...
| integer, save | ivsten = -1 |
| | field ids of the anisotropic viscosity More...
| integer, save | ivstes = -1 |
| integer, save | icour = -1 |
| | Courant number. More...
| integer, save | ifour = -1 |
| | Fourier number. More...
| integer, save | iprtot = -1 |
| | Total pressure at cell centers . More...
| integer, save | ivisma = -1 |
| | Mesh velocity viscosity for the ALE module. More...
| integer, dimension(nscamx), save | iustdy |
| | pointer for dilatation source terms More...
| integer, save | itsrho = -1 |
| | pointer for global dilatation source terms More...
| integer, save | ibeta = -1 |
| | pointer for thermal expansion coefficient More...
| integer, save | iddgas = -1 |
| | pointer for deduced mass fraction in case of gas mix More...
| integer, save | igmxml = -1 |
| | pointer for gas mix molar mass More...
| integer, save | iforbr = -1 |
| | field id of the stresses at boundary (if post-processed) More...
| integer, save | iyplbr = -1 |
| | field id of at boundary (if post-processed) More...
| integer, save | itempb = -1 |
| | field id of temperature at boundary More...
