8.0
Gaz combustion variables pointers
+ Collaboration diagram for Gaz combustion variables pointers:
integer, save ifm
 pointer to specify the mixing rate in isca(ifm) More...
integer, save ifp2m
 pointer to specify the variance of the mixing rate in isca(ifp2m) More...
integer, save ifsqm
 pointer to specify the second moment of the mixing rate in isca(ifsqm): More...
integer, save ipvm
 pointer to specify the transported progress variable ippmod(islfm) >= 2: More...
integer, save iygfm
 pointer to specify the fresh gas mass fraction in isca(iygfm) More...
integer, save icm
 the intersection computation mode. If its value is: More...
integer, save icp2m
 transported variable More...
integer, save ifpcpm
integer, save iyfm
integer, save iyfp2m
integer, save icoyfp
integer, dimension(ngazgm), save iym
 mass fractions : More...
integer, dimension(ngazgm), save ibym
integer, save itemp
 state variable (temperature) More...
integer, save ifmin
 state variable More...
integer, save ifmax
integer, save irecvr
 state variable: Pointer to the reconstructed variance in case of mode_fp2m = 1 More...
integer, save itotki
 state variable: Pointer to the total scalar dissipation rate More...
integer, save ihrr
 state variable: Pointer to volumetric heat release rate More...
integer, save ixr
 state variable: Pointer to enthalpy defect More...
integer, save iomgc
integer, save ickabs
 state variable: absorption coefficient, when the radiation modelling is activated More...
integer, save it2m
 state variable: $T^2$ term More...
integer, save it3m
 state variable: $T^3$ term, when the radiation modelling is activated More...
integer, save it4m
 state variable: $T^4$ term, when the radiation modelling is activated More...
integer, save itsc
integer, save inpm
 pointer for soot precursor number in isca (isoot = 1) More...
integer, save ifsm
 pointer for soot mass fraction in isca (isoot = 1) More...
◆ ibym
◆ ickabs
◆ icm
integer, save icm
  • 1 (default), the original algorithm is used. Care should be taken to clip the intersection on an extremity.
  • 2, a new intersection algorithm is used. Caution should be used to avoid to clip the intersection on an extremity.
◆ icoyfp
◆ icp2m
integer, save icp2m
◆ ifm
integer, save ifm
◆ ifmax
integer, save ifmax
state variable
◆ ifmin
integer, save ifmin
state variable
◆ ifp2m
integer, save ifp2m
◆ ifpcpm
◆ ifsm
integer, save ifsm
◆ ifsqm
integer, save ifsqm
◆ ihrr
integer, save ihrr
◆ inpm
integer, save inpm
◆ iomgc
integer, save iomgc
◆ ipvm
integer, save ipvm
◆ irecvr
◆ it2m
integer, save it2m
◆ it3m
integer, save it3m
◆ it4m
integer, save it4m
◆ itemp
integer, save itemp
◆ itotki
◆ itsc
integer, save itsc
◆ ixr
integer, save ixr
◆ iyfm
integer, save iyfm
◆ iyfp2m
◆ iygfm
integer, save iygfm
◆ iym
mass fractions :
  • iym(1): is fuel mass fraction
  • iym(2): oxidiser mass fraction
  • iym(3): product mass fraction ibym() contains the matching field ids at boundary faces
