Collaboration diagram for Module for turbulence constants:Variables | |
| double precision, save | xkappa = 0.42d0 |
| double precision, save | cstlog = 5.2d0 |
| constant of logarithmic law function: | |
| real(c_double), pointer, save | ypluli |
| limit value of | |
| double precision, pointer, save | apow |
| Werner and Wengle coefficient. More... | |
| double precision, pointer, save | bpow |
| real(c_double), pointer, save | cmu |
| constant | |
| real(c_double), pointer, save | cmu025 |
| real(c_double), pointer, save | crij1 |
| Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment. More... | |
| real(c_double), pointer, save | crij2 |
| constant | |
| real(c_double), pointer, save | crij3 |
| constant | |
| real(c_double), pointer, save | csrij |
| constant | |
| double precision, save | xcl = 0.122d0 |
| constant of the Rij-epsilon EBRSM More... | |
| double precision, save | xa1 = 0.1d0 |
| constant in the expression of Ce1' for the Rij-epsilon EBRSM More... | |
| double precision, save | xct = 6.d0 |
| double precision, save | xceta = 80.d0 |
| double precision, save | ckwsk1 = 1.d0/0.85d0 |
| constant | |
| double precision, save | ckwsk2 = 1.d0 |
| constant | |
| double precision, save | ckwsw1 = 2.d0 |
| constant | |
| double precision, save | ckwsw2 = 1.d0/0.856d0 |
| constant | |
| double precision, save | ckwbt1 = 0.075d0 |
| constant | |
| double precision, save | ckwbt2 = 0.0828d0 |
| constant | |
| double precision, save | ckwgm1 |
| double precision, save | ckwgm2 |
| double precision, save | ckwa1 = 0.31d0 |
| specific constant of k-omega SST constant | |
| double precision, save | ckwc1 = 10.d0 |
| constant | |
| double precision, save | csab1 = 0.1355d0 |
| specific constant of Spalart-Allmaras More... | |
| double precision, save | csab2 = 0.622d0 |
| double precision, save | csasig = 2.d0/3.d0 |
| double precision, save | csav1 = 7.1d0 |
| double precision, save | csaw1 |
| double precision, save | csaw2 = 0.3d0 |
| double precision, save | csaw3 = 2.d0 |
| real(c_double), pointer, save | almax |
| is a characteristic macroscopic length of the domain, used for the initialization of the turbulence and the potential clipping (with iclkep=1) More... | |
| real(c_double), pointer, save | uref |
| the characteristic flow velocity, used for the initialization of the turbulence. Negative value: not initialized. More... | |
| real(c_double), pointer, save | xlomlg |
| mixing length for the mixing length model More... | |
| real(c_double), pointer, save | xlesfl |
| constant used in the definition of LES filtering diameter: Useful if and only if iturb = 40 or 41 More... | |
| real(c_double), pointer, save | ales |
| constant used to define, for each cell | |
| real(c_double), pointer, save | bles |
| real(c_double), pointer, save | csmago |
| Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by | |
| real(c_double), pointer, save | xlesfd |
| ratio between explicit and explicit filter width for a dynamic model constant used to define, for each cell | |
| real(c_double), pointer, save | cdries |
| van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant: More... | |
| double precision, save | volmin |
| minimal control volume More... | |
| double precision, save | volmax |
| maximal control volume More... | |
| double precision, save | voltot |
| total domain volume More... | |
| double precision, save | xclt = 0.305d0 |
| constant of EB-AFM and EB-DFM (0.122*2.5d0, See F. Dehoux thesis) More... | |
| real(c_double), pointer, save ales |
, the width of the (implicit) filter:
Useful if and only if iturb = 40 or 41.
| real(c_double), pointer, save almax |
Useful if and only if iturb = 20, 21, 30, 31, 50 or 60 (RANS models)
| double precision, pointer, save apow |
| real(c_double), pointer, save bles |
| double precision, pointer, save bpow |
| real(c_double), pointer, save cdries |
| double precision, save ckwa1 = 0.31d0 |
for the
SST model. Useful if and only if iturb=60 (
SST)
| double precision, save ckwbt1 = 0.075d0 |
constant
for the
SST)
| double precision, save ckwbt2 = 0.0828d0 |
constant
for the
SST)
| double precision, save ckwc1 = 10.d0 |
constant
for the
SST) specific constant of k-omega SST
| double precision, save ckwgm1 |
| double precision, save ckwgm2 |
| double precision, save ckwsk1 = 1.d0/0.85d0 |
constant
for the
| double precision, save ckwsk2 = 1.d0 |
constant
for the
| double precision, save ckwsw1 = 2.d0 |
constant
for the
SST)
| double precision, save ckwsw2 = 1.d0/0.856d0 |
constant
for the
SST)
| real(c_double), pointer, save cmu |
constant
for all the RANS turbulence models Warning, different values for the v2f model Useful if and only if iturb = 20, 21, 30, 31, 50, 51 or 60 (
or
| real(c_double), pointer, save cmu025 |
| real(c_double), pointer, save crij1 |
constant
for the
LRR model. Useful if and only if iturb=30 (
LRR)
| real(c_double), pointer, save crij2 |
constant
for the
LRR)
| real(c_double), pointer, save crij3 |
constant
for the buoyant production term
models.
| double precision, save csab1 = 0.1355d0 |
| double precision, save csab2 = 0.622d0 |
| double precision, save csasig = 2.d0/3.d0 |
| double precision, save csav1 = 7.1d0 |
| double precision, save csaw1 |
| double precision, save csaw2 = 0.3d0 |
| double precision, save csaw3 = 2.d0 |
| real(c_double), pointer, save csmago |
where
is the width of the filter and
the filtered strain rate.
| real(c_double), pointer, save csrij |
constant
for the
models.
| double precision, save cstlog = 5.2d0 |
) constant of the logarithmic wall function. Useful if and only if iturb >= 10 (mixing length,
, LES, v2f or
| real(c_double), pointer, save uref |
Useful if and only if iturb= 20, 21, 30, 31, 50 or 60 (RANS model) and the turbulence is not initialized somewhere else (restart file or subroutine cs_user_initialization)
| double precision, save volmax |
| double precision, save volmin |
| double precision, save voltot |
total domain volume
| double precision, save xa1 = 0.1d0 |
| double precision, save xceta = 80.d0 |
| double precision, save xcl = 0.122d0 |
| double precision, save xclt = 0.305d0 |
| double precision, save xct = 6.d0 |
| double precision, save xkappa = 0.42d0 |
Karman constant. (= 0.42) Useful if and only if iturb >= 10. (mixing length,
, LES, v2f or
| real(c_double), pointer, save xlesfd |
, the width of the explicit filter used in the framework of the LES dynamic model:
Useful if and only if iturb = 41
| real(c_double), pointer, save xlesfl |
| real(c_double), pointer, save xlomlg |
Useful if and only if iturb= 10 (mixing length)
