8.0
and thermal exchange coefficients
+ Collaboration diagram for and thermal exchange coefficients:
integer(c_int), pointer, save nfbpcd
  number of faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine cs_user_wall_condensation More...
integer, dimension(:,:), pointer, save itypcd
  type of condensation source terms for each variable More...
double precision, dimension(:), pointer, save thermal_condensation_flux
  value of the thermal flux for the condensation model. See the user subroutine cs_user_wall_condensation More...
double precision, dimension(:), pointer, save flthr
  external heat flux used as flux conditions of the 1d thermal model (in unit $W.m^{-2}$). More...
double precision, dimension(:), pointer, save dflthr
  external heat flux derivative used as flux conditions of the 1d thermal model (in unit $W.m^{-3}$). More...
double precision, dimension(:,:), pointer, save spcond
  value of the condensation source terms for pressure. For the other variables, eventual imposed specific value. See the user subroutine cs_user_wall_condensation More...
double precision, dimension(:), pointer, save twall_cond
  Temperature at condensing wall faces (for post-processing purposes) More...
double precision, dimension(:), pointer, save hpcond
 value of the thermal exchange coefficient associated to the condensation model used. See the user subroutine cs_user_wall_condensation More...
integer, dimension(:), pointer, save ifbpcd
 list on the nfbpcd faces in which a condensation source terms is imposed. See ifbpcd and the user subroutine cs_user_wall_condensation More...
integer(c_int), pointer, save nzones
  number of the zones with a specific condensation source terms depending on the wall temperature and material properties. by default (nzones = 1) if the user does not specified different zones in the user subroutine cs_user_wall_condensation.f90 . More...
integer, dimension(:), pointer, save izzftcd
  list of the zones associated to the faces where a condensation source term is imposed. On each zone a specific wall temperature and material properties can be specified by the user. More...
integer, dimension(:), pointer, save izcophc
  choice the way to compute the exchange coefficient of the condensation source term used by the copain model. More...
integer, dimension(:), pointer, save izcophg
  choice the way to compute the thermal exchange coefficient associated to the heat transfer to the wall due to the condensation phenomenon. More...
◆ dflthr
◆ flthr
◆ hpcond
◆ ifbpcd
◆ itypcd
◆ izcophc
  • 1: the turbulent exchange coefficient of the flow
  • 2: the exchange coefficient of the copain correlation
  • 3: the maximal value between the two previous exchange coefficients
◆ izcophg
  • 2: the thermal exchange coefficient of the copain correlation
  • 3: the maximal value between the current and previous thermal exchange coefficient evaluated by the copain correlation
◆ izzftcd
◆ nfbpcd
◆ nzones
◆ spcond
◆ thermal_condensation_flux
◆ twall_cond
