| integer, dimension(ncharm), save | if1m |
| | mean value of the tracer 1 representing the light volatiles released by the coal icha More...
| integer, dimension(ncharm), save | if2m |
| | mean value of the tracer 2 representing the heavy volatiles released by the coal icha More...
| integer, save | if3m |
| | mean value of the tracer 3 representing the carbon released as CO during coke burnout More...
| integer, save | if4m |
| | transported variable of countinuous phase (gas mixture) More...
| integer, save | if5m |
| integer, save | if6m |
| integer, save | if7m |
| integer, save | if8m |
| integer, save | if9m |
| integer, save | if4p2m |
| | the variance associated with the tracer 4 representing the air (the mean value of this tracer is not transported, it can be deduced directly from the three others) More...
| integer, save | ifvp2m |
| | f1f2 variance More...
| integer, dimension(nclcpm), save | ixck |
| | coke mass fraction related to the class icla More...
| integer, dimension(nclcpm), save | ixch |
| | reactive coal mass fraction related to the class icla More...
| integer, dimension(nclcpm), save | inp |
| | number of particles of the class icla per kg of air-coal mixture More...
| integer, dimension(nclcpm), save | ih2 |
| | mass enthalpy of the coal of class icla, if we are in permeatic conditions More...
| integer, dimension(nclcpm), save | ixwt |
| | transported variable of dispersed phase (particle class) More...
| integer, dimension(nclcpm), save | inagecp |
| | Pointer to Np*age(particles) More...
| integer, save | iage |
| | Pointer to age of bulk. More...
| integer, dimension(nclcpm), save | iv_p_x |
| integer, dimension(nclcpm), save | iv_p_y |
| integer, dimension(nclcpm), save | iv_p_z |
| integer, dimension(ngazem), save | iym1 |
| | mass fractions: More...
| integer, save | irom1 |
| | State variables of continuous phase (gas mixture) More...
| integer, save | immel |
| | molar mass of the gas mixture More...
| integer, dimension(nclcpm), save | itemp2 |
| | temperature of the particles of the class icla More...
| integer, dimension(nclcpm), save | irom2 |
| | density of the particles of the class icla More...
| integer, dimension(nclcpm), save | idiam2 |
| | diameter of the particles of the class icla More...
| integer, dimension(nclcpm), save | ix2 |
| | solid mass fraction of the class icla More...
| integer, dimension(nclcpm), save | igmdch |
| | disappearance rate of the reactive coal of the class icla More...
| integer, dimension(nclcpm), save | igmhet |
| | coke disappearance rate of the coke burnout of the class icla More...
| integer, dimension(nclcpm), save | igmtr |
| | Implicite part of the exchanges to the gas by molecular distribution. More...
| integer, dimension(nclcpm), save | ighco2 |
| | State variables of dispersed phase (particles class) More...
| integer, dimension(nclcpm), save | igmdv1 |
| | mass transfer caused by the release of light volatiles of the class icla More...
| integer, dimension(nclcpm), save | igmdv2 |
| | mass transfer caused by the release of heavy volatiles of the class icla More...
| integer, dimension(nclcpm), save | igmsec |
| integer, save | ibcarbone |
| | Used for bulk balance of Carbon. More...
| integer, save | iboxygen |
| | Used for bulk balance of Oxygen. More...
| integer, save | ibhydrogen |
| | Used for bulk balance of Hydrogen. More...
