8.0
fvm_periodicity.h File Reference
#include "fvm_defs.h"
+ Include dependency graph for fvm_periodicity.h:
Typedefs
typedef struct _fvm_periodicity_t fvm_periodicity_t
Enumerations
enum  fvm_periodicity_type_t { FVM_PERIODICITY_NULL , FVM_PERIODICITY_TRANSLATION , FVM_PERIODICITY_ROTATION , FVM_PERIODICITY_MIXED }
fvm_periodicity_tfvm_periodicity_create (double equiv_tolerance)
fvm_periodicity_tfvm_periodicity_destroy (fvm_periodicity_t *this_periodicity)
int fvm_periodicity_get_n_transforms (const fvm_periodicity_t *this_periodicity)
int fvm_periodicity_get_n_levels (const fvm_periodicity_t *this_periodicity)
void fvm_periodicity_get_tr_level_idx (const fvm_periodicity_t *this_periodicity, int tr_level_index[4])
int fvm_periodicity_add_by_matrix (fvm_periodicity_t *this_periodicity, int external_num, fvm_periodicity_type_t type, double matrix[3][4])
int fvm_periodicity_add_translation (fvm_periodicity_t *this_periodicity, int external_num, const double translation[3])
int fvm_periodicity_add_rotation (fvm_periodicity_t *this_periodicity, int external_num, double angle, const double axis[3], const double invariant_point[3])
int fvm_periodicity_get_transform_id (const fvm_periodicity_t *this_periodicity, int external_num, int direction)
fvm_periodicity_type_t fvm_periodicity_get_type (const fvm_periodicity_t *this_periodicity, int tr_id)
int fvm_periodicity_get_reverse_id (const fvm_periodicity_t *this_periodicity, int tr_id)
void fvm_periodicity_get_parent_ids (const fvm_periodicity_t *this_periodicity, int tr_id, int parent_ids[2])
void fvm_periodicity_get_components (const fvm_periodicity_t *this_periodicity, int tr_id, int component_ids[3])
int fvm_periodicity_get_equiv_id (const fvm_periodicity_t *this_periodicity, int tr_id)
void fvm_periodicity_get_matrix (const fvm_periodicity_t *this_periodicity, int tr_id, double matrix[3][4])
void fvm_periodicity_set_matrix (const fvm_periodicity_t *this_periodicity, int tr_id, double matrix[3][4])
void fvm_periodicity_combine (fvm_periodicity_t *this_periodicity, int abort_on_error)
void fvm_periodicity_dump (const fvm_periodicity_t *this_periodicity)
const char * fvm_periodicity_type_name []
Typedef Documentation
◆ fvm_periodicity_t
◆ fvm_periodicity_type_t
Enumerator
◆ fvm_periodicity_add_by_matrix()
int fvm_periodicity_add_by_matrix ( fvm_periodicity_t this_periodicity,
int  external_num,
double  matrix[3][4]
◆ fvm_periodicity_add_rotation()
int fvm_periodicity_add_rotation ( fvm_periodicity_t this_periodicity,
int  external_num,
double  angle,
◆ fvm_periodicity_add_translation()
int fvm_periodicity_add_translation ( fvm_periodicity_t this_periodicity,
int  external_num,
◆ fvm_periodicity_combine()
void fvm_periodicity_combine ( fvm_periodicity_t this_periodicity,
int  abort_on_error
◆ fvm_periodicity_create()
fvm_periodicity_t* fvm_periodicity_create ( double  equiv_tolerance)
◆ fvm_periodicity_destroy()
fvm_periodicity_t* fvm_periodicity_destroy ( fvm_periodicity_t this_periodicity)
◆ fvm_periodicity_dump()
void fvm_periodicity_dump ( const fvm_periodicity_t this_periodicity)
◆ fvm_periodicity_get_components()
void fvm_periodicity_get_components ( const fvm_periodicity_t this_periodicity,
int  tr_id,
◆ fvm_periodicity_get_equiv_id()
int fvm_periodicity_get_equiv_id ( const fvm_periodicity_t this_periodicity,
int  tr_id
◆ fvm_periodicity_get_matrix()
void fvm_periodicity_get_matrix ( const fvm_periodicity_t this_periodicity,
int  tr_id,
double  matrix[3][4]
◆ fvm_periodicity_get_n_levels()
int fvm_periodicity_get_n_levels ( const fvm_periodicity_t this_periodicity)
◆ fvm_periodicity_get_n_transforms()
int fvm_periodicity_get_n_transforms ( const fvm_periodicity_t this_periodicity)
◆ fvm_periodicity_get_parent_ids()
void fvm_periodicity_get_parent_ids ( const fvm_periodicity_t this_periodicity,
int  tr_id,
int  parent_ids[2]
◆ fvm_periodicity_get_reverse_id()
int fvm_periodicity_get_reverse_id ( const fvm_periodicity_t this_periodicity,
int  tr_id
◆ fvm_periodicity_get_tr_level_idx()
void fvm_periodicity_get_tr_level_idx ( const fvm_periodicity_t this_periodicity,
◆ fvm_periodicity_get_transform_id()
int fvm_periodicity_get_transform_id ( const fvm_periodicity_t this_periodicity,
int  external_num,
int  direction
◆ fvm_periodicity_get_type()
fvm_periodicity_type_t fvm_periodicity_get_type ( const fvm_periodicity_t this_periodicity,
int  tr_id
◆ fvm_periodicity_set_matrix()
void fvm_periodicity_set_matrix ( const fvm_periodicity_t this_periodicity,
int  tr_id,
double  matrix[3][4]
◆ fvm_periodicity_type_name
const char* fvm_periodicity_type_name[]
extern
