Source terms for transported scalars may be defined using the cs_user_source_terms user-defined function.
Field access and information
The following initialization block or portions thereof needs to be added for the following examples:
Definition: cs_defs.h:319
Definition: cs_defs.h:313
Definition: cs_field.c:2316
double precision, dimension(:), pointer cell_f_vol
fluid volume of each cell
Definition: mesh.f90:156
Definition: cs_field.h:130
Indicator of variance scalars: To determine whether a scalar is a variance, the following info can be accessed:
Definition: cs_field.c:3064
Definition: cs_field.c:2570
- If
var_f_id == -1 , the scalar is not a variance
- If
var_f_id >= 0 , the field is the variance of the scalar with field id var_f_id
Density
@ rho
#define CS_F_(e)
Example 1
Example of arbitrary source term for the scalar f, named "scalar_2" in the calculation.
appearing in the equation under the form
In the following example:
with:
- tauf = 10.0 (in
) (dissipation time for
- prodf = 100.0 (in
) (production of
by unit of time)
which yields:
st_imp[i] = volume[i]*A = -volume[i]*rho/tauf
st_exp[i] = volume[i]*B = volume[i]*rho*prod_f
Body
Source term applied to second scalar
if (strcmp(f->
name,
"scalar_2") == 0) {
bft_printf(
" User source terms for variable %s\n",
Definition: bft_printf.c:140
const char * cs_field_get_label(const cs_field_t *f)
Return a label associated with a field.
Definition: cs_field.c:4365
const cs_equation_param_t * cs_field_get_equation_param_const(const cs_field_t *f)
Access a field's equation parameters for read only.
Definition: cs_field_default.c:312
int verbosity
Definition: cs_equation_param.h:212
const char * name
Definition: cs_field.h:132
Example 2
Example of arbitrary volumic heat term in the equation for enthalpy h.
In the considered example, a uniform volumic source of heating is imposed in the cells with coordinate X in [0;1.2] and Y in [3.1;4].
The global heating power if Pwatt (in
) and the total volume of the selected cells is volf (in
This yields:
st_imp[i] = 0
st_exp[i] = volume[i]* pwatt/volf
Body
- Warning
- It is assumed here that the thermal scalar is an enthalpy. If the scalar is a temperature. PWatt does not need to be divided by
because
is put outside the diffusion term and multiplied in the temperature equation as follows:
with pwatt = 100.0
Apply source term
bft_printf(
if (z != NULL) {
@ h
Definition: cs_field_pointer.h:91
const cs_zone_t * cs_volume_zone_by_name_try(const char *name)
Return a pointer to a volume zone based on its name if present.
Definition: cs_volume_zone.c:706
const cs_lnum_t * elt_ids
Definition: cs_zone.h:65
cs_lnum_t n_elts
Definition: cs_zone.h:64
cs_real_t f_measure
Definition: cs_zone.h:75
