Introduction
User subroutine for the atmospheric model.
Atmospheric module
imode corresponds to the number of calls of the usatdv function. Depending on the value of imode , different operations are performed in the following example.
imode = 0
if (imode.eq.0) then
write(nfecra,*) 'defining the dimensions of the 1D vertical arrays'
else
write(nfecra,*) 'defining the coordinates and levels of the 1D vertical arrays'
endif
nvert = 1
kvert = 50
kmx = kvert
zvmax = 1975.d0
if (iatra1.gt.0) then
ztop = 11000.d0
zzmax = (int(zvmax)/1000)*1000.d0
do while(zzmax.le.(ztop-1000.d0))
zzmax = zzmax + 1000.d0
kmx = kmx + 1
enddo
endif
imode = 1
zvert(1) = 0.d0
zvert(2) = 5.d0
zvert(3) = 20.5d0
zvert(4) = 42.0d0
zvert(5) = 65.0d0
zvert(6) = 89.5d0
zvert(7) = 115.0d0
zvert(8) = 142.0d0
zvert(9) = 170.5d0
zvert(10) = 199.5d0
zvert(11) = 230.0d0
zvert(12) = 262.0d0
zvert(13) = 294.5d0
zvert(14) = 328.5d0
zvert(15) = 363.5d0
zvert(16) = 399.0d0
zvert(17) = 435.5d0
zvert(18) = 473.5d0
zvert(19) = 512.0d0
zvert(20) = 551.0d0
zvert(21) = 591.5d0
zvert(22) = 632.5d0
zvert(23) = 674.0d0
zvert(24) = 716.0d0
zvert(25) = 759.0d0
zvert(26) = 802.5d0
zvert(27) = 846.5d0
zvert(28) = 891.5d0
zvert(29) = 936.5d0
zvert(30) = 982.0d0
zvert(31) = 1028.0d0
zvert(32) = 1074.5d0
zvert(33) = 1122.0d0
zvert(34) = 1169.5d0
zvert(35) = 1217.0d0
zvert(36) = 1265.5d0
zvert(37) = 1314.5d0
zvert(38) = 1363.5d0
zvert(39) = 1413.0d0
zvert(40) = 1462.5d0
zvert(41) = 1512.5d0
zvert(42) = 1563.0d0
zvert(43) = 1613.5d0
zvert(44) = 1664.5d0
zvert(45) = 1715.5d0
zvert(46) = 1767.0d0
zvert(47) = 1818.5d0
zvert(48) = 1870.0d0
zvert(49) = 1922.5d0
zvert(50) = 1975.0d0
ztop = 11000.d0
ii = kvert
zzmax = (int(zvert(ii))/1000)*1000.d0
zzmax = zzmax+1000.d0
ii = ii + 1
zvert(ii) = zzmax
enddo
endif
do iiv = 1, nvert
xyvert(iiv,1) = 50.d0
xyvert(iiv,2) = 50.d0
xyvert(iiv,3) = 1.d0
soilvert(iiv)%albedo = 0.25d0
soilvert(iiv)%emissi = 0.965d0
soilvert(iiv)%ttsoil = 14.77d0
soilvert(iiv)%totwat = 0.0043d0
soilvert(iiv)%pressure = 1023.d0
soilvert(iiv)%density = 1.23d0
soilvert(iiv)%foir = 0.d0
soilvert(iiv)%fos = 0.d0
enddo
endif
Data Entry for the atmospheric soil model
To activate the model, the user has to set the and to specify the zone id on which the soil model is applied in cs_user_parameters.c, routine cs_user_model:
@ CS_ATMO_SOIL_5_CAT
Definition: cs_atmo.h:106
cs_atmo_option_t * cs_glob_atmo_option
int soil_zone_id
Definition: cs_atmo.h:281
cs_atmo_soil_cat_t soil_cat
Definition: cs_atmo.h:279
int soil_model
Definition: cs_atmo.h:274
int id
Definition: cs_zone.h:59
Then the user may change default coefficient values for soil categories in cs_user_parameters.f90, routine usipsu
if (iatsoil.eq.1) then
tab_sol(4)%csol = 1.7e-5
tab_sol(4)%rugthe = 0.0012
tab_sol(4)%rugdyn = 0.0012
endif
Initialization of atmospheric
The user has to specify the percentage of each categories for all faces of the soil zone in cs_user_initialization.c:
f->
val[soil_id + f->
dim * elt_id] = 0.;
f->
val[4 + f->
dim * elt_id] = 100.;
const cs_zone_t * cs_boundary_zone_by_id(int id)
Return a pointer to a boundary zone based on its id.
Definition: cs_boundary_zone.c:687
Definition: cs_defs.h:313
Definition: cs_field.c:2340
Definition: cs_field.h:130
cs_real_t * val
Definition: cs_field.h:151
int dim
Definition: cs_field.h:137
cs_lnum_t n_elts
Definition: cs_zone.h:64
