Calculation of the particle relaxation time
Modification of the calculation of the particle relaxation time with respect to the chosen formulation for the drag coefficient
This function is called in a loop on the particles, so be careful to avoid too costly operations.
: Thermal relaxation time (value to be computed)
: Particle mass
: Particle specific heat
d_p : Particle diameter
h_e : Coefficient of thermal exchange
The coefficient of thermal exchange is calculated from a Nusselt number, itself evaluated by a correlation (Ranz-Marshall by default)
: Thermal conductivity of the carrier field
: Particle Reynolds number
P_{rt} : Prandtl number
In the next example we compute the relaxation time with two different formulations of the drag coefficient:
void
if (re_p <= 1000)
fdr = 18.0 * nu_f * (1.0 + cd1 * pow(re_p, cd2)) / (p_diam * p_diam);
else
fdr = (0.44 * 3.0 / 4.0) * uvwr / p_diam;
taup[id_p] = rho_p / rho_f / fdr;
if (re_p <= rec1)
fdr = 18.0 * nu_f / dd2;
else if (re_p <= rec2)
fdr = 3.0/4.0 * nu_f / dd2 * (22.73 + 0.0903 / re_p + 3.69 * re_p);
else if (re_p <= rec3)
fdr = 3.0/4.0 * nu_f / dd2 * (29.1667 - 3.8889 / re_p + 1.222 * re_p);
else if (re_p <=rec4)
fdr = 18.0 * nu_f / dd2 *(1.0 + 0.15 * pow(re_p, 0.687));
else
Definition: cs_defs.h:319
Definition: cs_defs.h:313
@ dt
cs_lagr_particle_set_t * cs_lagr_get_particle_set(void)
Return pointer to the main cs_lagr_particle_set_t structure.
Definition: cs_lagr_particle.c:1153
@ CS_LAGR_DIAMETER
Definition: cs_lagr_particle.h:93
static cs_real_t cs_lagr_particle_get_real(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle in a set.
Definition: cs_lagr_particle.h:1241
void cs_user_lagr_rt(cs_lnum_t id_p, cs_real_t re_p, cs_real_t uvwr, cs_real_t rho_f, cs_real_t rho_p, cs_real_t nu_f, cs_real_t taup[], const cs_real_t dt[])
Modification of the calculation of the particle relaxation time with respect to the chosen formulatio...
Definition: cs_user_lagr_particle.c:239
Definition: cs_lagr_particle.h:188
size_t extents
Definition: cs_lagr_particle.h:190
Definition: cs_lagr_particle.h:222
unsigned char * p_buffer
Definition: cs_lagr_particle.h:246
const cs_lagr_attribute_map_t * p_am
Definition: cs_lagr_particle.h:244
Computation of the thermal relaxation time of the particles
Modification of the computation of the thermal relaxation time of the particles with respect to the chosen formulation of the Nusselt number.
void
cs_real_t fnus = 2.0 + 0.55 * sqrt(re_p) * pow(prt, 1./3.);
tauc[id_p]= diam * diam * rho_p * cp_p / ( fnus * 6.0 * rho_f * cp_f * k_f);
@ CS_LAGR_CP
Definition: cs_lagr_particle.h:149
void cs_user_lagr_rt_t(cs_lnum_t id_p, cs_real_t re_p, cs_real_t uvwr, cs_real_t rho_f, cs_real_t rho_p, cs_real_t nu_f, cs_real_t cp_f, cs_real_t k_f, cs_real_t tauc[], const cs_real_t dt[])
Modification of the calculation of the thermal relaxation time of the particles with respect to the c...
Definition: cs_user_lagr_particle.c:283
