8.0
cs_turbulence_sa.h
1 #ifndef __CS_TURBUBELNCE_SA_H__
2 #define __CS_TURBUBELNCE_SA_H__
5  * nu_tilda turbulence model.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function prototypes
44 /*----------------------------------------------------------------------------*/
63
64 void
66  cs_lnum_t icetsm[],
67  int itypsm[],
68  const cs_real_t dt[],
69  cs_real_t smacel[],
70  const int b_face_type[]);
71
73
75
76 #endif /* __CS_TURBUBELNCE_SA_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_defs.h:313
@ dt
void cs_turbulence_sa(cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t dt[], cs_real_t smacel[], const int b_face_type[])
Solve the equations.
Definition: cs_turbulence_sa.c:415
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:192
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:207
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:201
