8.0
cs_turbulence_rij.h
1 #ifndef __CS_TURBULENCE_RIJ_H__
2 #define __CS_TURBULENCE_RIJ_H__
5  * Rij-epsilon turbulence model.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function prototypes
44 /*----------------------------------------------------------------------------*/
60 /*-----------------------------------------------------------------------------*/
61
62 void
64  cs_lnum_t icetsm[],
65  int itypsm[],
66  cs_real_t smacel[]);
67
68 /*----------------------------------------------------------------------------*/
76 /*----------------------------------------------------------------------------*/
77
78 void
80  cs_real_t c_durbin_l);
81
82 /*----------------------------------------------------------------------------*/
92 /*----------------------------------------------------------------------------*/
93
94 void
97
98 /*----------------------------------------------------------------------------*/
105 /*----------------------------------------------------------------------------*/
106
107 void
109
110 /*----------------------------------------------------------------------------*/
111
113
114 #endif /* __CS_TURBULENCE_RIJ_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_defs.h:313
void cs_turbulence_rij(cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], cs_real_t smacel[])
Solve the for incompressible flows or slightly compressible flows for one time step.
Definition: cs_turbulence_rij.c:2482
void cs_turbulence_rij_clip(cs_lnum_t n_cells)
Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version).
Definition: cs_turbulence_rij.c:3459
void cs_turbulence_rij_init_by_ref_quantities(cs_real_t uref, cs_real_t almax)
Initialize Rij-epsilon variables based on reference quantities.
Definition: cs_turbulence_rij.c:3401
void cs_turbulence_rij_solve_alpha(int f_id, cs_real_t c_durbin_l)
Solve the equation on alpha in the framework of the Rij-EBRSM model.
Definition: cs_turbulence_rij.c:3159
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:192
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:207
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:201
real(c_double), pointer, save almax
is a characteristic macroscopic length of the domain, used for the initialization of the turbulence a...
Definition: cstphy.f90:431
real(c_double), pointer, save uref
the characteristic flow velocity, used for the initialization of the turbulence. Negative value: not ...
Definition: cstphy.f90:440
