1 #ifndef __CS_TURBULENCE_KE_H__
2 #define __CS_TURBULENCE_KE_H__
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:334
Definition: cs_defs.h:313
@ rij
Definition: cs_field_pointer.h:73
@ dt
void cs_turbulence_ke_q(cs_real_6_t rij[])
Calculation of non linear terms of the quadratic k-epsilon model (Baglietto et al....
Definition: cs_turbulence_ke.c:2376
void cs_turbulence_ke_q_mu_t(void)
Calculation of turbulent viscosity for the non-linear quadratic K-epsilon from Baglietto et al....
Definition: cs_turbulence_ke.c:2287
void cs_turbulence_ke(cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t *dt, cs_real_t smacel[], cs_real_t *prdv2f)
Solve the k-epsilon equations.
void cs_turbulence_ke_clip(cs_lnum_t n_cells, int iclip)
Clipping of the turbulent kinetic energy and turbulent dissipation.
Definition: cs_turbulence_ke.c:2062
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:192
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:207
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:201
