8.0
cs_time_control.h
1 #ifndef __CS_TIME_CONTROL_H__
2 #define __CS_TIME_CONTROL_H__
5  * Time dependency control for variables or properties.
34 #include <stdarg.h>
37  * Local headers
40 #include "cs_defs.h"
42 #include "cs_time_step.h"
44 /*----------------------------------------------------------------------------*/
45
49  * Macro definitions
51
53  * Type definitions
55
56 /*----------------------------------------------------------------------------*/
73 /*----------------------------------------------------------------------------*/
74
75 typedef bool
77  void *input);
78
79 /* Time control types */
80 /*--------------------*/
81
82 /* Datatype enumeration */
83
84 typedef enum {
85
91
92 /*----------------------------------------------------------------------------
93  * Time control structure
94  *----------------------------------------------------------------------------*/
95
96 typedef struct {
97
98  /* Type and control parameters */
99
100  cs_time_control_type_t type; /* control type */
101
102  bool at_start; /* always active at start ? */
103  bool at_end; /* always active at end ? */
104
105  union {
106  int start_nt; /* update start time step */
107  double start_t; /* update start physical time */
108  };
109
110  union {
111  int end_nt; /* update end time step */
112  double end_t; /* update end physical time */
113  };
114
115  union {
116  int interval_nt; /* interval, in time steps */
117  double interval_t; /* interval, in physical time units */
118  };
119
120  cs_time_control_func_t *control_func; /* function for advanced control */
121  void *control_input; /* input associated function */
122
123  /* Current state */
124
125  bool current_state; /* query return value of current time step */
126  int current_time_step; /* last time step queried */
127
128  int last_nt; /* last active time step */
129  double last_t; /* last active physical time */
130
132
133 /*============================================================================
134  * Global variables
135  *============================================================================*/
136
137 /*=============================================================================
138  * Public function prototypes
139  *============================================================================*/
140
141 /*----------------------------------------------------------------------------
142  *!
143  * \brief Indicate if a time control is active or not at the given time.
144  *
145  * If the time control or time step argument is NULL, true is returned.
146  *
147  * \param[in] tc time control structure
148  * \param[in] ts time step structure
149  *
150  * \return true if active, false if inactive
151  */
152 /*----------------------------------------------------------------------------*/
153
154 bool
156  const cs_time_step_t *ts);
157
158 /*----------------------------------------------------------------------------
159  *!
160  * \brief Simple time control initialization based on time step options.
161  *
162  * \param[in] tc pointer to time control structure.
163  * \param[in] nt_start start time step (or < 0 for unlimited)
164  * \param[in] nt_end end time step (or < 0 for unlimited)
165  * \param[in] at_start always active at start ?
166  * \param[in] at_start always active at end ?
167  */
168 /*----------------------------------------------------------------------------*/
169
170 void
172  int nt_start,
173  int nt_end,
174  int nt_interval,
175  bool at_start,
176  bool at_end);
177
178 /*----------------------------------------------------------------------------
179  *!
180  * \brief Simple time control initialization based on physical time options.
181  *
182  * \param[in] tc pointer to time control structure.
183  * \param[in] t_start start time (or < 0 for unlimited)
184  * \param[in] t_end end time (or < 0 for unlimited)
185  * \param[in] at_start always active at start ?
186  * \param[in] at_start always active at end ?
187  */
188 /*----------------------------------------------------------------------------*/
189
190 void
192  double t_start,
193  double t_end,
194  double t_interval,
195  bool at_start,
196  bool at_end);
197
198 /*----------------------------------------------------------------------------
199  *!
200  * \brief Simple time control initialization based on external function.
201  *
202  * \remark: if the input pointer is non-NULL, it must point to valid data
203  * when the control function is called, so that value or structure
204  * should not be temporary (i.e. local);
205  *
206  * \param[in] tc pointer to time control structure.
207  * \param[in] control_func pointer to time control funcction.
208  * \param[in] control_input pointer to optional (untyped) value or structure,
209  * or NULL.
210  * \param[in] at_start always active at start ?
211  * \param[in] at_start always active at end ?
212  */
213 /*----------------------------------------------------------------------------*/
214
215 void
217  cs_time_control_func_t *control_func,
218  void *control_input,
219  bool at_start,
220  bool at_end);
221
222 /*----------------------------------------------------------------------------
223  *!
224  * \brief Get text description of time control configuration.
225  *
226  * If the time control or time step argument is NULL, true is returned.
227  *
228  * \param[in] tc time control structure
229  * \param[out] desc description string
230  * \param[in] desc_size description string maximum size
231  *
232  * \return true if active, false if inactive
233  */
234 /*----------------------------------------------------------------------------*/
235
236 void
238  char *desc,
239  size_t desc_size);
240
241 /*----------------------------------------------------------------------------*/
242
244
245 #endif /* __CS_TIME_CONTROL_H__ */
Definition: cs_defs.h:509
Definition: cs_time_control.h:84
@ CS_TIME_CONTROL_FUNCTION
Definition: cs_time_control.h:88
@ CS_TIME_CONTROL_TIME
Definition: cs_time_control.h:87
@ CS_TIME_CONTROL_TIME_STEP
Definition: cs_time_control.h:86
bool cs_time_control_is_active(cs_time_control_t *tc, const cs_time_step_t *ts)
Definition: cs_time_control.c:153
bool() cs_time_control_func_t(const cs_time_step_t *ts, void *input)
Function pointer to a time control function.
Definition: cs_time_control.h:76
void cs_time_control_get_description(const cs_time_control_t *tc, char *desc, size_t desc_size)
Definition: cs_time_control.c:335
void cs_time_control_init_by_time_step(cs_time_control_t *tc, int nt_start, int nt_end, int nt_interval, bool at_start, bool at_end)
Definition: cs_time_control.c:229
void cs_time_control_init_by_time(cs_time_control_t *tc, double t_start, double t_end, double t_interval, bool at_start, bool at_end)
Definition: cs_time_control.c:265
void cs_time_control_init_by_func(cs_time_control_t *tc, cs_time_control_func_t *control_func, void *control_input, bool at_start, bool at_end)
Definition: cs_time_control.c:306
Definition: cs_time_control.h:96
bool current_state
Definition: cs_time_control.h:125
double interval_t
Definition: cs_time_control.h:117
int interval_nt
Definition: cs_time_control.h:116
int end_nt
Definition: cs_time_control.h:111
bool at_end
Definition: cs_time_control.h:103
Definition: cs_time_control.h:100
Definition: cs_time_control.h:126
double last_t
Definition: cs_time_control.h:129
cs_time_control_func_t * control_func
Definition: cs_time_control.h:120
double start_t
Definition: cs_time_control.h:107
void * control_input
Definition: cs_time_control.h:121
int last_nt
Definition: cs_time_control.h:128
bool at_start
Definition: cs_time_control.h:102
int start_nt
Definition: cs_time_control.h:106
double end_t
Definition: cs_time_control.h:112
time step descriptor
Definition: cs_time_step.h:64
