8.0
cs_rank_neighbors.h
1 #ifndef __CS_RANK_NEIGHBORS_H__
2 #define __CS_RANK_NEIGHBORS_H__
5  * Management of parallel rank neighbors.
30 #if defined(HAVE_MPI)
31 #include <mpi.h>
32 #endif
35  * Local headers
38 #include "cs_defs.h"
39 #include "cs_block_dist.h"
46  * Macro definitions
48
50  * Type definitions
52
53 /* Exchange algorithm choice */
54
55 typedef enum {
56
60
62
63 #if defined(HAVE_MPI)
64
65 /* Rank neighbors structure */
66
67 typedef struct {
68
69  int size;
70  int *rank;
73
74 #endif
75
76 /*=============================================================================
77  * Global variables
78  *============================================================================*/
79
80 extern const char *cs_rank_neighbors_exchange_name[];
81
82 /*=============================================================================
83  * Public function prototypes
84  *============================================================================*/
85
86 #if defined(HAVE_MPI)
87
88 /*----------------------------------------------------------------------------*/
98
100 cs_rank_neighbors_create(size_t n_elts,
101  const int elt_rank[]);
102
103 /*----------------------------------------------------------------------------*/
109 /*----------------------------------------------------------------------------*/
110
111 void
113
114 /*----------------------------------------------------------------------------*/
129
130 void
132  size_t n_elts,
133  const int elt_rank[],
134  int *elt_rank_index);
135
136 /*----------------------------------------------------------------------------*/
147
148 void
150  MPI_Comm comm);
151
152 /*----------------------------------------------------------------------------*/
164 /*----------------------------------------------------------------------------*/
165
166 void
168  size_t n_elts,
169  const int *elt_rank_index,
170  cs_lnum_t *elt_rank_count);
171
172 /*----------------------------------------------------------------------------*/
185 /*----------------------------------------------------------------------------*/
186
187 void
189  cs_rank_neighbors_t **n_recv,
190  const cs_lnum_t *send_count,
191  cs_lnum_t **recv_count,
192  MPI_Comm comm);
193
194 /*----------------------------------------------------------------------------*/
209 /*----------------------------------------------------------------------------*/
210
211 void
213  cs_rank_neighbors_t **n_recv,
214  const cs_lnum_t *send_count,
215  cs_lnum_t **recv_count,
216  cs_rank_neighbors_exchange_t exchange_type,
217  MPI_Comm comm);
218
219 #endif /* defined(HAVE_MPI) */
220
221 /*----------------------------------------------------------------------------*/
227 /*----------------------------------------------------------------------------*/
228
231
232 /*----------------------------------------------------------------------------*/
238 /*----------------------------------------------------------------------------*/
239
240 void
242
243 /*----------------------------------------------------------------------------*/
244
246
247 #endif /* __CS_RANK_NEIGHBORS_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:313
@ t
cs_rank_neighbors_t * cs_rank_neighbors_create(size_t n_elts, const int elt_rank[])
Create a rank neighbors structure base on a list of element ranks.
Definition: cs_rank_neighbors.c:344
void cs_rank_neighbors_set_exchange_type(cs_rank_neighbors_exchange_t t)
Set current type of rank neighbors collective algorithm choice.
Definition: cs_rank_neighbors.c:1025
void cs_rank_neighbors_destroy(cs_rank_neighbors_t **n)
Destroy a rank neighborhood structure.
Definition: cs_rank_neighbors.c:389
void cs_rank_neighbors_to_index(const cs_rank_neighbors_t *n, size_t n_elts, const int elt_rank[], int *elt_rank_index)
Given a list of element ranks, determine the associated element rank indexes in a rank neighborhood s...
Definition: cs_rank_neighbors.c:425
void cs_rank_neighbors_sync_count_m(const cs_rank_neighbors_t *n_send, cs_rank_neighbors_t **n_recv, const cs_lnum_t *send_count, cs_lnum_t **recv_count, cs_rank_neighbors_exchange_t exchange_type, MPI_Comm comm)
Exchange send and receive counts for rank neighborhoods, using a given method.
Definition: cs_rank_neighbors.c:792
void cs_rank_neighbors_symmetrize(cs_rank_neighbors_t *n, MPI_Comm comm)
Symmetrize a rank neighborhood structure.
Definition: cs_rank_neighbors.c:511
void cs_rank_neighbors_count(const cs_rank_neighbors_t *n, size_t n_elts, const int *elt_rank_index, cs_lnum_t *elt_rank_count)
Given a list of element rank indexes, count occurences for a rank neighborhood structure.
Definition: cs_rank_neighbors.c:717
const char * cs_rank_neighbors_exchange_name[]
cs_rank_neighbors_exchange_t cs_rank_neighbors_get_exchange_type(void)
Get current type of rank neighbors collective algorithm choice.
Definition: cs_rank_neighbors.c:1011
Definition: cs_rank_neighbors.h:55
@ CS_RANK_NEIGHBORS_PEX
Definition: cs_rank_neighbors.h:57
@ CS_RANK_NEIGHBORS_NBX
Definition: cs_rank_neighbors.h:58
@ CS_RANK_NEIGHBORS_CRYSTAL_ROUTER
Definition: cs_rank_neighbors.h:59
void cs_rank_neighbors_sync_count(const cs_rank_neighbors_t *n_send, cs_rank_neighbors_t **n_recv, const cs_lnum_t *send_count, cs_lnum_t **recv_count, MPI_Comm comm)
Exchange send and receive counts for rank neighborhoods.
Definition: cs_rank_neighbors.c:760
Definition: cs_rank_neighbors.h:67
int size
Definition: cs_rank_neighbors.h:69
int * rank
Definition: cs_rank_neighbors.h:70
