8.0
cs_rad_transfer_bcs.h
1 #ifndef __CS_RAD_TRANSFER_BCS_H__
2 #define __CS_RAD_TRANSFER_BCS_H__
5  * Radiation solver boundary conditions treatment.
31  * Local headers
34 /*----------------------------------------------------------------------------*/
38 /*=============================================================================
39  * Local Macro definitions
40  *============================================================================*/
43  * Type definition
45
47  * Global variables
49
51  * Public function prototypes for Fortran API
53
54 /*=============================================================================
55  * Public function prototypes
57
58 /*----------------------------------------------------------------------------*/
98 /*----------------------------------------------------------------------------*/
99
100 void
102  int bc_type[],
103  int icodcl[],
104  cs_real_t dt[],
105  cs_real_t rcodcl[]);
106
107 /*----------------------------------------------------------------------------*/
137 /*----------------------------------------------------------------------------*/
138
139 void
140 cs_rad_transfer_bc_coeffs(int bc_type[],
141  cs_real_t vect_s[3],
142  cs_real_t ckmel[],
143  cs_real_t bpro_eps[],
144  cs_real_t w_gg[],
145  int gg_id,
146  cs_real_t coefap[],
147  cs_real_t coefbp[],
148  cs_real_t cofafp[],
149  cs_real_t cofbfp[]);
150
151 /*----------------------------------------------------------------------------*/
152
154
155 #endif /* __CS_RAD_TRANSFER_BCS_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
@ dt
void cs_rad_transfer_bcs(int nvar, int bc_type[], int icodcl[], cs_real_t dt[], cs_real_t rcodcl[])
Compute wall temperature for radiative transfer, and update BCs.
Definition: cs_rad_transfer_bcs.c:267
void cs_rad_transfer_bc_coeffs(int bc_type[], cs_real_t vect_s[3], cs_real_t ckmel[], cs_real_t bpro_eps[], cs_real_t w_gg[], int gg_id, cs_real_t coefap[], cs_real_t coefbp[], cs_real_t cofafp[], cs_real_t cofbfp[])
Boundary conditions for DO and P-1 models.
Definition: cs_rad_transfer_bcs.c:1213
integer, save nvar
number of solved variables (must be lower than nvarmx)
Definition: dimens.f90:42
