#include <errno.h>
#include <locale.h>
#include "fvm_io_num.h"
#include "cs_all_to_all.h"
#include "cs_block_dist.h"
#include "cs_block_to_part.h"
#include "cs_file.h"
#include "cs_io.h"
#include "cs_mesh_builder.h"
#include "cs_order.h"
#include "cs_part_to_block.h"
#include "cs_timer.h"
#include "cs_partition.h"
void | cs_partition_external_library_info (cs_log_t log_type) |
Print information on external libraries. More... | |
void | cs_partition_set_algorithm (cs_partition_stage_t stage, cs_partition_algorithm_t algorithm, int rank_step, bool ignore_perio) |
Set algorithm for domain partitioning. More... | |
void | cs_partition_set_write_level (int write_flag) |
Set partitioning write to file option. More... | |
void | cs_partition_set_preprocess_hints (bool join, bool join_periodic) |
Define hints indicating if initial partitioning fo a preprocessing stage is required. More... | |
void | cs_partition_set_preprocess (bool active) |
Activate or deactivate initial partitioning for preprocessing. More... | |
bool | cs_partition_get_preprocess (void) |
Indicate if re-partitiong for the computation stage is required. More... | |
void | cs_partition_add_partitions (int n_extra_partitions, int extra_partitions_list[]) |
Define list of extra partitionings to build. More... | |
void | cs_partition (cs_mesh_t *mesh, cs_mesh_builder_t *mb, cs_partition_stage_t stage) |
Partition mesh based on current options. More... | |
void cs_partition | ( | cs_mesh_t * | mesh, |
cs_mesh_builder_t * | mb, | ||
cs_partition_stage_t | stage | ||
[in] | mesh | pointer to mesh structure |
[in,out] | mb | pointer to mesh builder structure |
[in] | stage | associated partitioning stage |
void cs_partition_add_partitions | ( | int | n_extra_partitions, |
int | extra_partitions_list[] | ||
Partitionings in this list will be output to file, and may be used for subsequent calculations.
When partitioning for both preprocessing and calculation stages, output to file of partioning data or generation of additional partitionings (see cs_partition_add_partitions) will only be done for the second stage.
[in] | n_extra_partitions | number of extra partitionings to compute |
[in] | extra_partitions_list | list of extra partitions to compute |
void cs_partition_external_library_info | ( | cs_log_t | log_type | ) |
[in] | log_type | log type |
bool cs_partition_get_preprocess | ( | void | ) |
void cs_partition_set_algorithm | ( | cs_partition_stage_t | stage, |
cs_partition_algorithm_t | algorithm, | ||
int | rank_step, | ||
bool | ignore_perio | ||
[in] | algorithm | partitioning algorithm choice |
[in] | rank_step | if > 1, partitioning done on at most n_ranks / rank_step processes (for graph-based partitioning only) |
[in] | ignore_perio | if true, ignore periodicity information when present (for graph-based partitioning only) |
void cs_partition_set_preprocess | ( | bool | active | ) |
[in] | active | true to activate pre-partitiong for the preprocessing stage, false to de-activate it |
void cs_partition_set_preprocess_hints | ( | bool | join, |
bool | join_periodic | ||
[in] | join | true if a mesh joining operation is planned. |
[in] | join_periodic | true if a mesh periodic matching operation is planned |
void cs_partition_set_write_level | ( | int | write_flag | ) |
Partitioning information for subsequent calculations is written to file after the last partitioning stage depending on the output level.
Note that partitioning information for additional partitionings is always written to file, regardless of this option.
[in] | write_flag | option to save partitioning information: 0: never 1: for graph-based partitioning only 2: always |
